Old 07-12-2010, 01:50 PM   #661
NiMo's Avatar
26mm is the standard basic Tamiya width.
24mm is the worldwide recognised legal race tyre for most championships.
NiMo is offline   Reply With Quote
Old 07-12-2010, 02:18 PM   #662
superspeed's Avatar
Remember the super narrow that people used to run 8 - 10 years ago? I recall there were 21mm.
This chassis looks pretty solid, much improved compares to FF02. Although FF01 was still a decent chassis.
Civic body is a nice touch, Tamiya defintely picked the right one for re-release. Too bad they did not choose the other Civic kits, I recall there was a Mugen, Jaccs, etc.
superspeed is offline   Reply With Quote
Old 07-12-2010, 02:24 PM   #663
drbelleville's Avatar
Weren't those HPI's and HotLaps?
R/C'ing since 1982, Pro-10 racing in Germany and Italy in the early 90's, Keil DTM Cup.
The Pro-10 Pusher.
drbelleville is offline   Reply With Quote
Old 07-12-2010, 02:25 PM   #664
encore75's Avatar
Trader Rating: 26 (100%+)
Send a message via AIM to encore75
Originally Posted by izzyracer View Post
Nice Run! where is that holy grail of a track at?
Race World Hawaii, in Kunia (near Honolulu).
Tamiya TB-Evolution V & TA05-R | Kyosho Ultima SC & RB5 | Associated FT RC18T
encore75 is offline   Reply With Quote
Old 07-13-2010, 02:25 AM   #665
izzyracer's Avatar
Trader Rating: 27 (100%+)
So it's in Island if Oahu, Common everyone, let's go!
izzyracer is offline   Reply With Quote
Old 07-13-2010, 02:31 AM   #666
izzyracer's Avatar
I wonder if this will work?
Tamiya #50959 BODY SET TOYOTA MR-S RACING
Convert it to short wheel base?
Old 07-13-2010, 07:57 AM   #667
NiMo's Avatar
Should work, even if you have to play with the swing arm spacers.
Old 07-13-2010, 08:06 AM   #668
Trader Rating: 44 (100%+)
Any idea what motor may be chosen for the GT4 class at the TCS Nats? Was there a Fred sighting at the track this past weekend?
My FF03 should be arriving at my LHS today.
M03R, M04L, TT-01R Type E, Midnight Pumpkin,
Lunch Box, CC-01 Wrangler, SC10.2FT,
SC10B, Traxxas Slash
minimadman2003 is offline   Reply With Quote
Old 07-13-2010, 02:32 PM   #669
I've build my FF03 and it was a plesure to build, i've installed some electronics but still have to solder the wires to my ESC.
I will be testing the car tomorrow with a silvercan motor and with a nissan GT-R body (had to remove the foam bumper to make the body fit).
I know it's not a front wheel drive but i like that body a lot
I think i need to add an extra spacer on the front upper link (on the side of the diff housing) as the camber is to much when it turns into corners.
But i need to test it first before i make some changes to the car settings
addicted2blue is offline   Reply With Quote
Old 07-13-2010, 02:38 PM   #670
Questions??
This may sound a bit "STUPID" but has anyone tried running the trf 201 slipper to prevent idler gear failure? Being that the tranny was designed with one and the TRF201 runs on dirt/grass (depending on where you live) therefore the grip is not as extreme as with the FF03 cars running on asphalt with rubber tires (with no slipper).
Just a weird thought.
The Pro-10 Pusher.
Old 07-13-2010, 03:16 PM   #671
you had idle gear gear failure?
i do reverse and then jam into drive all day and i have no problems
tpsolid is offline   Reply With Quote
Old 07-13-2010, 07:30 PM   #672
reenmachine's Avatar
That's what you do all day?
I'm jealous!
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 07-13-2010, 11:52 PM   #673
I'm jealous!
yea pretty much. I Let my buddies drive it on weekends when we wait for people to show up at my place. They usually crash it into a tire, do crazy burnouts reverse and forward for life of the battery. So maybe 30 min or so of beating on the car and its still holding up pretty well.
Old 07-14-2010, 05:11 AM   #674
foampervert's Avatar
Send a message via MSN to foampervert
Default Trf201 slipper in a ff03
Hiya folks,
A slipper might be an interesting add-on if you run super hot motors like 4.5-5.5 brushless... However, do realize that it's technically disallowed in on-road(no traction control device).
If anything, I think it would help save your tranny and diff halves( those alu diff halves would butterfly if you whack hard).
However, you might actually lose front traction. Already, it being a fwd, forward acceleration is limited, a slipper may or may not aggravate it.
Do try it and share your findings!
-Alexander
During heats, i use durex for both front and rear, with Hard inserts.
Sorex, i meant Sorex.
foampervert is offline   Reply With Quote
Old 07-14-2010, 07:19 AM   #675
Lightbulb
Well I have "talked" (emailed) with Tamiya Japan, being that the US tech support is so awesome And they have stated that they are looking into it as it seems to be a recurring problem. I also asked, as I stated before the correlation between Offroad w/ slipper vs. Onroad w/o Slipper. So once i hear anything I will let you guys know. I am sure it will trickle through Tamiya USA should there be a recourse.
The Pro-10 Pusher.
Tamiya Championship Series Neil Rabara Racing Forum 20851 01-17-2017 10:21 PM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 711 01-08-2017 09:27 AM
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5774 09-23-2016 10:49 PM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 12:28 PM
SEO by vBSEO 3.5.0
