Like Tree23Likes
Old 07-04-2010, 03:29 AM   #586
Does anybody know what kind of alu servo posts i can use on a FF03 chassis?
addicted2blue is offline   Reply With Quote
Old 07-04-2010, 03:52 AM   #587
How do you manage to fit 46mm universals in the FF03? I have mounted the differential the correct way, but on the right side it is just to tight to get it in. The left side is OK though.
Fabiz
Fabiz is offline   Reply With Quote
Old 07-04-2010, 05:49 AM   #588
old-man's Avatar
Tamiya 416 servo mounts fits like a glove. Use only the straight one and not the "L" shaped one.
old-man is offline   Reply With Quote
Old 07-04-2010, 08:12 AM   #589
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Fabiz
You have the diff nut on the wrong side of the diff,
tamiyarcracer is offline   Reply With Quote
Old 07-04-2010, 08:55 AM   #590
Thx for the info, but they are not that easy to find
Old 07-04-2010, 11:49 AM   #591
The FF03 is starting to look like a car. Only need some fine adjustments and some electronics. The body is still at the paint shop, but I'll get it back within two weeks.
Fabiz
Old 07-04-2010, 02:21 PM   #592
rtypec's Avatar
TB03 aluminum servo mounts. I think there were two packages...a left side and a right side. You can see them partially see them in the pics of my car a few page back.
rtypec is offline   Reply With Quote
Old 07-04-2010, 08:01 PM   #593
Default universals binding
Originally Posted by rtypec View Post
That dude had IFS and an FF03 two years before anybody else
*edit: I checked my universals and they are indeed 46mm.
and here's the rest of it...
RedBullfiXX, does that battery look familiar?
Hey rtype, I have a question for you. What susspension blocks did you use so that you could fit the 46 mm universals. I have an aluminum diff and the diff nut side binds into the end of the bone, and I am using 42mm half shafts. I checked to make sure the diff was installed properly and it is, the only thing that I can think of is that the 1xd set up is to narrow. What do you think and what did you use?
Thanks, any help will be appreciated.
mrod is offline   Reply With Quote
Old 07-04-2010, 08:52 PM   #594
rtypec's Avatar
I'm using a 1xd in the front/front and the split 1xd/1d in the front/rear. Also, I only used a half sponge on one side and nothing on the other. As for the diff nut binding, I had the same problem and fixed it by putting the diff nut/holder on the other side (maybe it's in the instructions but I didn't see it lol) In any event, gotta go get my pyro on.
Happy 4th everybody.
Old 07-04-2010, 09:53 PM   #595
beaim's Avatar
Trader Rating: 8 (90%+)
Send a message via MSN to beaim
Ceramic greese the gear is a good idea?
beaim is offline   Reply With Quote
Old 07-04-2010, 11:03 PM   #596
old-man's Avatar
Totally agree with you. They are hard to come by.
http://www.rc-mushroom.com/product_i...ducts_id=16929
However the other option is;
http://www.rc-mushroom.com/product_i...ducts_id=18890
Its half the price of the originals and you get the "L" shaped one too
Old 07-05-2010, 02:51 AM   #597
It's not in the instructions, but it is the solution when using 46's. They should put it in the manual.
I'm also using 1XD both front and 1XD/1A in the rear.
Fabian
Old 07-05-2010, 09:32 AM   #598
foampervert's Avatar
Send a message via MSN to foampervert
Default Oh... But it is in the instructions.... Teehee
Fabian
Right between the pictures of the semi built diff halves and the picture of the fully built diff where you put the diff screw in, it says 'turn the diff around'...
That's why it's a 'pro' kit...
-Alexander
During heats, i use durex for both front and rear, with Hard inserts.
Sorex, i meant Sorex.
foampervert is offline   Reply With Quote
Old 07-05-2010, 09:53 AM   #599
-Alexander
Sure did! I didn't notice that, haha.
Fabiz
Old 07-05-2010, 09:56 AM   #600
@Old man,
Thx a lot for the info.
Those 416 servo posts look the same as TB03 ones, but i could be wrong.
Tamiya Championship Series Neil Rabara Racing Forum 21025 Yesterday 02:38 PM
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5789 04-27-2017 10:11 PM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 724 04-03-2017 12:43 PM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 11:28 AM
