Like Tree24Likes
Old 06-23-2010, 01:50 PM   #466
NiMo's Avatar
got as far as building the front end, but am now thinking that there are further wheelbase adjustments ?
Looks like it may be adjustable from 225mm through to 260mm using the 3 main chassis lengths and then the swing arm spacers.
NiMo is offline   Reply With Quote
Old 06-23-2010, 05:04 PM   #467
rtypec's Avatar
Originally Posted by OSherman View Post
it accomodates TAMIYAs brushless motor..
Oddly enough, A silver can fits perfectly...imagine that but sadly, it doesn't come with one
rtypec is offline   Reply With Quote
Old 06-23-2010, 06:21 PM   #468
ShadowAu's Avatar
I can't wait to get one of these but none of the shops I regularly/reliably get stuff from has it... just have to wait a bit longer
looking at some stuff I read it may use the new m05 diff?
I am quite content with doing what I do
Don't mistake not being happy for unhappiness - its not the same thing
ShadowAu is offline   Reply With Quote
Old 06-23-2010, 06:55 PM   #469
old-man's Avatar
Originally Posted by old-man View Post
One of my buddy have the citrix stock spec combo. The motor fits. I have not seen it yet but I guess the mounting holes on the pressed sheet metal can is different on the aluminium caned motors.
I have a Team Powers 17.5T and I have to re-drill and tap new holes on the front motor end bell to fit the queer FF03 motor bay.
I am getting my citrix combo today and lets see how it goes.
Confirmed!!! The 17.5T sheet metal can of the Citrix stock spec combo fits perfectly.
old-man is offline   Reply With Quote
Old 06-23-2010, 08:08 PM   #470
reenmachine's Avatar
Trader Rating: 26 (100%+)
It appears to be the gearbox from the new TRF201, although I don't yet have mine to compare.
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 06-23-2010, 09:12 PM   #471
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
It is the same gear set, but the housing is not the same, nor is the upper lay shaft.
tamiyarcracer is offline   Reply With Quote
Old 06-24-2010, 06:46 AM   #472
Barry White's Avatar
Will a Peugeot 306 maxi fit if you cut/remove the front bumper?
Barry White is offline   Reply With Quote
Old 06-24-2010, 06:52 AM   #473
NiMo's Avatar
Not yet finished build but do have both the 306 and 406 shells unpainted.
Had a quick measure up with the Vectra, and it looks to fit if you trim the bumper.
Old 06-24-2010, 01:08 PM   #474
Hebiki's Avatar
Default More in Stock....
They're flying off the shelves... but SpeedtechRC.com has more in stock.
http://www.speedtechrc.com/store/ebp...il.asp?id=9625
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 06-24-2010, 01:13 PM   #475
My LHS up here sold out the day he got them in as well. Where are they all going? I'm sure Jeff is shipping tons of them all over. Hopefully enough stay here in SoCal for us to get some good fields together.
If all goes well, I'll debut mine this Sunday at Camarillo.
Silver can.
Pete Waydo
Old 06-24-2010, 01:49 PM   #476
NiMo's Avatar
just goes to show it is a long overdue car that many have wanted
Old 06-24-2010, 08:09 PM   #477
Civic with Scirocco theme.
Old 06-24-2010, 09:51 PM   #478
Default Porsche body fitment
When I use the Porsche body the rear wheelwell does not line up properly in the long setup- body seems short. If I switch to medium wheelbase setup the body seems too long and the wheelwell does not line up also. Anyone else have this issue?
Budster is offline   Reply With Quote
Old 06-25-2010, 06:19 AM   #479
NiMo's Avatar
Why would you want to use a Porsche shell?
and if you must, then try using different spacers on the suspension shaft pins.
My working out shows that you can have any wheelbase size between 225mm and 260mm by using the 3 main chassis lengths and the suspension pin spacers and the rear hub spacers.
Old 06-25-2010, 06:27 AM   #480
I use the Porsche body because that is what the TCS rules call for and I am getting it set up for that exhibition class.
Tamiya Championship Series Neil Rabara Racing Forum 21085 07-20-2017 05:34 PM
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5790 06-17-2017 05:27 PM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 724 04-03-2017 12:43 PM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 11:28 AM
