Old 06-22-2010, 09:48 AM   #451
Originally Posted by Hebiki View Post
+1
i did some searching by myself and rcmart sells em.
I got my ff03 last night but havent started building it yet. Didnt know it did not come with tires I gotta goto the shop and buy a set now.
tpsolid is offline   Reply With Quote
Old 06-22-2010, 11:10 AM   #452
Got my kit last night too. Some things I have noticed.
1. The new ball diff is smooth. But still uses no D-ring and tells you to glue it on to the outdrives. I can't understand why their diff rings are not D-cut in this day and age.
2. The transmission is smooth too. I had to add some shims on the diff and the top shaft. The top shaft had excessive play so I added a .2 mm shim. I think it was .3 for the diff.
3. The steering is different from the old TA/TB style, but closer to the 416 style if you know what I mean.
4. I am using hex screws where ever I can. Fine threaded Phillips are not friendly screwing into plastic. There are some high stress points that you should use steel screws instead of Al or even Ti.
5. Some brushless motors may not fit properly! That structural beam that runs above the endbell gets in the way of the solder tabs. This is with a trinity DUO motor style. I was able to get it to fit after hacking the A tab...
Other than that, the build is nice. Hope to get it running in a few days.
redbones is offline   Reply With Quote
Old 06-22-2010, 11:36 AM   #453
I wonder why Tamiya did away with self tapping screws? Everything is machine screws now.
Old 06-22-2010, 11:43 AM   #454
OSherman's Avatar
I noticed the same thing.. LRP X11 motors fit with no modification needed.. SpeedPassions would be a nice choice.. plugs are on endbell..
Ballistic nope, ORION close but nope..
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 06-22-2010, 03:42 PM   #455
Trader Rating: 69 (100%+)
I should be getting my kit tomorrow.
what have you guys been doing as far as setup?
springs, oil, pistons?
I was planning on reverting back to my old days setups with my TA02 FWD but since people have been running these new cars already.... what seems to work?
Ideally, I can build it with an already decent setup instead of the box stock setup (which usually is good to begin with).
Markus is offline   Reply With Quote
Old 06-22-2010, 05:31 PM   #456
I assume the new cirtix stock spec motor won't too then.
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 06-22-2010, 07:35 PM   #457
old-man's Avatar
One of my buddy have the citrix stock spec combo. The motor fits. I have not seen it yet but I guess the mounting holes on the pressed sheet metal can is different on the aluminium caned motors.
I have a Team Powers 17.5T and I have to re-drill and tap new holes on the front motor end bell to fit the queer FF03 motor bay.
I am getting my citrix combo today and lets see how it goes.
old-man is offline   Reply With Quote
Old 06-22-2010, 09:17 PM   #458
reenmachine's Avatar
Trader Rating: 26 (100%+)
Originally Posted by kentech View Post
Originally Posted by tamiyarcracer View Post
51339 Volkswagen Golf - GTI cup
Thanks again -- just ordered one. Do you know what wheelbase to build the chassis to for this body? Any other considerations?
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 06-22-2010, 09:31 PM   #459
old-man's Avatar
257mm - Long wheel base
Old 06-22-2010, 09:45 PM   #460
Thanks!
Pete Waydo
Old 06-23-2010, 11:53 AM   #461
stitchy's Avatar
FF-03 Pros back in stock at Speedtech!
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 06-23-2010, 12:02 PM   #462
NiMo's Avatar
mine arrived in England yesterday, was posted Friday, so very good service
NiMo is offline   Reply With Quote
Old 06-23-2010, 01:53 PM   #463
Built the gearbox assembly last night. My Tekin brushless motors won't fit without modification either. The part of the solder tabs that bends forward will have to be ground off so you solder to the remaining vertical part. Not a huge deal, but I'm kind of baffled that Tamiya could create a clean-slate chassis design in 2010 and not accommodate brushless motors.
Pete Waydo
Old 06-23-2010, 02:32 PM   #464
OSherman's Avatar
it accomodates TAMIYAs brushless motor..
•KO Propo America
•EXOTEK
Old 06-23-2010, 02:34 PM   #465
Hebiki's Avatar
tamiya still accomodates nimhs too.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Tamiya Championship Series Neil Rabara Racing Forum 20858 Today 09:40 AM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 711 01-08-2017 09:27 AM
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5774 09-23-2016 10:49 PM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 12:28 PM
SEO by vBSEO 3.5.0
