Like Tree24Likes
Old 06-17-2010, 11:29 AM   #391
Trader Rating: 70 (100%+)
hope mind is in the mail from the speedtechrc preorder!!!!!!
Markus is offline   Reply With Quote
Old 06-17-2010, 11:42 AM   #392
OSherman's Avatar
Thumbs up
Jef and his crew are really good at the pre-order thing.. if you pre-ordered, i think its safe to say its on its way to you as we speak..
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 06-17-2010, 12:18 PM   #393
RossoTorro's Avatar
Originally Posted by Fabiz View Post
Ordered one from SpeedTech as well. Always a pleasure to do business with them, and will keep on doing that in the future.
Fabiz
Are you from Norway? There are a guy on a norwegian rc forum with the same name....
RossoTorro is offline   Reply With Quote
Old 06-17-2010, 12:24 PM   #394
Phat-Boy's Avatar
Trader Rating: 25 (96%+)
Default Turnbuckle Shafts
What size are Turnbuckle Shafts in front of FF-03? I want to replace aluminum ones.
Thanks.
Phat-Boy is offline   Reply With Quote
Old 06-17-2010, 12:57 PM   #395
Samme Fabiz
MatsNorway is offline   Reply With Quote
Old 06-17-2010, 01:52 PM   #396
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Thanks.
Lots of info in post # 311 if you look
Turnbuckles = (5) 3x32mm & (4) 3x23mm, if you want Titanium
tamiyarcracer is offline   Reply With Quote
Old 06-17-2010, 02:12 PM   #397
kentech's Avatar
Have run the FF-03 a little the last three days now and I'm absolutely in love with this car!
The setup as built per instructions is already very good. Just make sure you check the droop is equal and that the rear dampers are not limiting rear droop. Needed to unscrew the ends a bit.
Í made a front roll-bar out of parts I had, using the H (hard) front bar made for the 416 together with some 32mm turnbuckles and the neccesary cups, balls and other hardware. This allows you to be a lot more aggressive going into the turns and makes the car really fun to drive.
The FF-03 has a lot of steering and carries amazing corner speed. It's fairly quiet and is really good over kerbs, and the realism is just great!
+ YouTube Video
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 06-17-2010, 02:32 PM   #398
What tires are you running? Are they the same front and rear?
Old 06-17-2010, 02:35 PM   #399
OSherman's Avatar
Thumbs up
looks good for the first runs.. will only get better..
•KO Propo America
•EXOTEK
Old 06-17-2010, 02:37 PM   #400
Orlando,
Are you going to run the FF03 as a 2nd TCS class now?
Old 06-17-2010, 02:40 PM   #401
kentech's Avatar
Sorex 28's with Hara Black inserts F & R.
Old 06-17-2010, 02:44 PM   #402
thanks for the vid! Seems like it turns really good without the rear stepping out. Can't wait to run it against the 4wd in the stock spec class. Wonder how it will do with the super stock? Weight will the biggest advantage.
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 06-17-2010, 02:47 PM   #403
I'm not familiar with the hara inserts, are they a hard, medium or a soft?
Anyway it is great to hear that the tires are the same front and rear, and it looks that good.
Old 06-17-2010, 02:47 PM   #404
OSherman's Avatar
Orlando,
lol.. might be my ONLY class... but uhmmm, yeah... thats the plan..
•KO Propo America
•EXOTEK
Old 06-17-2010, 02:48 PM   #405
OSherman's Avatar
Hara Black are Medium..
Hara has two versions also.. v.2 are the latest.. more airgap than v.1
•KO Propo America
•EXOTEK
Tamiya Championship Series Neil Rabara Racing Forum 21085 Yesterday 05:34 PM
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5790 06-17-2017 05:27 PM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 724 04-03-2017 12:43 PM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 11:28 AM
