Like Tree24Likes
Old 06-03-2010, 07:16 PM   #301
Originally Posted by Hebiki View Post
there "might" be some plastic reinforcements there for the tub (the TB-03 tub had this so you had to run the blocks flipped upside down).... so Tamiya will force you to use the split blocks (unless of course you dremel it off.)
either way the wait is STILL killing me.
A good news is unlike the TB03, there is complete flat between the countersunk screw hole, so we don't have to flipped the block
Franky
einix is offline   Reply With Quote
Old 06-03-2010, 07:59 PM   #302
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Originally Posted by einix View Post
The only location that can use the V2 block are the Front axles rear block. The other 3 must use the old type
The rear axle block are 1XD and 1A, that's killing me, not much hobby store will stock 3 1XD block
But remember it is 2 of the standard XD, and 1 of the Newer 2pc XD
tamiyarcracer is offline   Reply With Quote
Old 06-03-2010, 08:12 PM   #303
old-man's Avatar
So it is;
Front-front - 1XD Old Type
Front-rear - 1XD V2
Rear-front - 1XD Old type
Rear-rear - 1A Old type
no?
old-man is offline   Reply With Quote
Old 06-03-2010, 11:16 PM   #304
Originally Posted by old-man View Post
So it is;
Front-rear - 1XD V2
no?
the front rear can use the old type or the v2.
for me, i prefer the old type but my local hobby store doesn't have 3 old type 1XD in stock, so I have to go with the v2 on the Front-rear
Franky
Old 06-03-2010, 11:21 PM   #305
razzor's Avatar
Dont stress about the track width !! these cars are designed for the narrower bodies and are a lot more fun and challenging to drive fast.
If you traction roll, your setup needs wok.
Wait for them to be released, i am sure you will love them.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 06-04-2010, 01:44 AM   #306
kentech's Avatar
84138 Honda Accord 1996 Racing Body (RC Limited)
Release Date: July 17
84140 Alfa Romeo 156 Racing Body Parts (RC Limited)
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 06-04-2010, 08:46 AM   #307
I hope its the JACCS accord?
where did you find the info at?
tpsolid is offline   Reply With Quote
Old 06-04-2010, 10:43 AM   #308
Einix, since you have the manual and all, can you tell us what the internal drive ratio and the max size pinion it can use? Thanks
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 06-05-2010, 11:27 AM   #309
Internal ratio is 2.60
the pro comes with a 26t pinion, and a 68t spur = 6.80 final drive ratio
with the stock spur and the optional 29t pinion it only gets down to a 6.10 final drive
Old 06-05-2010, 12:30 PM   #310
NiMo's Avatar
can you fit bigger than 29T?
I need to get to something near 3.9
NiMo is offline   Reply With Quote
Old 06-05-2010, 01:07 PM   #311
some very interesting things:
plastic suspension mounts use a plastic ball on the rod like the TB03
kit comes with plastic suspension blocks (3) XD, (1) X, (1) A, & (1) B
the rear block in the front of the car can use the V2 type block
Spur gear is mounted on a plastic mount, so can be immediately replaced with an industry standard 64p or 48p (if desired).
Dog bones are the same as the TA05, so a 46mm swing shaft is needed for the universal, but a TB03 wheel axle is used
Rear axle is the same as the Mini, so 54183 will work
the suspension shaft is a 46mm like the EVO4, 53851 is the Ti coated replacement
Turnbuckles = (5) 3x32mm & (4) 3x23mm, if you want Titanium
Bearings = (11) 10x5mm, (2) 15x10mm, (2) 8x5mm, & (1) 8x4mm also (4) 8x5mm for the steering (these are metal bushings in the kit)
All suspension componants are plastic, so if desired you need the 416 parts for the carbon reinforced plastics (53928 arms, 51332 f upright, 51333 r upright)
Diff plate is from the TRF501x (51287)
Shocks are built with 3 hole pistons, and a have a pair of yellow springs, and a pair of blue springs, the shocks are the TRF version (42101) with the Ti coated shafts
the rear shock tower looks to have the TA05 and TB03 mounting holes, bud needs a 53882 Damper stay spacer to clear the bulkhead.
Something else that is interesting, there is a plate that the Speeder and receiver mount onto, and it is removable with 2 screws.
You don't have to use the tray for the servo, if you don't want.
Old 06-05-2010, 01:48 PM   #312
This is very important if I'm going to run this in 17.5 non-boosted.
TLR 22 3.0
Apex RC Proshop
Old 06-05-2010, 02:17 PM   #313
I don't have the small spur gears like they run in a 12th scale, but I'm sure you can get pretty close
Something like a 72t spur and a 48t pinion gets you a 3.9
Old 06-05-2010, 02:33 PM   #314
NiMo's Avatar
so it can fit a 48t pinion ? 64dp I assume?
Old 06-05-2010, 06:50 PM   #315
I was able to stuff a 56t pinion into the tb03, so I hope that's how tamiya designed this one. Well, at least I can run it w/o the gear cover if I have to.
TLR 22 3.0
Apex RC Proshop
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5806 Yesterday 03:06 PM
Tamiya Championship Series Neil Rabara Racing Forum 21185 09-05-2017 07:20 PM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 730 08-15-2017 08:06 PM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 11:28 AM
