Like Tree24Likes
Old 03-25-2015, 12:12 PM   #2866
Tamiya re-released a bunch of the touring car bodies when the FF-03 came out. The Volvo 850, Alfa 156, Opel Vectra were offered, possibly more.
I ran a 156 when I had my FF-03.
:: Tamiya TA05 MS :: Tamiya TB04 Pro II/Exotek EXO6 :: Tamiya M05V2 :: Losi XX :: Tamiya TB01 :: Tamiya XV-01 Rally ::
ErikO is offline   Reply With Quote
Old 03-25-2015, 01:53 PM   #2867
ziggy1013's Avatar
Tq Rc sells a few ff bodies
ziggy1013 is offline   Reply With Quote
Old 03-25-2015, 02:47 PM   #2868
Microtome's Avatar
Default Thanks
Thanks I didn't think to look there and Google was letting me down. I need a set of F1 tires and rims so I may as well get it all together.
Microtome is offline   Reply With Quote
Old 03-25-2015, 05:46 PM   #2869
ziggy1013's Avatar
Ur welcome
Old 05-04-2015, 06:24 PM   #2870
Was wondering if anybody has a nib FF03 Evo they'd be willing to part with?
leadfootedfool is offline   Reply With Quote
Old 05-05-2015, 07:40 AM   #2871
gijoe64's Avatar
Trader Rating: 30 (100%+)
im selling a FFO3R with hop ups never ran, I am at work riht now i can send you pictures this afternoon
Raymon Robinson
ARC, LRP Go Blue!!
gijoe64 is offline   Reply With Quote
Old 09-19-2015, 09:39 PM   #2872
Trader Rating: 20 (100%+)
Default Messing around with shorty packs and low profile servos
Had this idea for awhile. Finally put it together just to mess around with alternate servo mounting. I never liked the servo hanging way off the side. Took it for a quick run today steering seemed good.
76jimmy is offline   Reply With Quote
Old 09-22-2015, 07:30 AM   #2873
Butler205's Avatar
Good work. How is the servo mounted? Does it change the balance in terms of oversteer/understeer?
M05 Racer(retired) FF03 Racer - Brushless Hyper 7 Basher
Butler205 is offline   Reply With Quote
Old 09-22-2015, 03:27 PM   #2874
Thanks! I removed the servo mounting tabs from the case and removed the grommet from the servo wire for clearance. It's installed with two small dabs of shoe-goo. It feels mere responsive when I turn in. I've only used it on an unimproved asphalt track so conditions weren't ideal. I have a ff03-pro I'll run it against when I get more time. Had a blast with a friend of mine trading laps with the two cars on Friday. We both felt like the center mounted servo turned in better but the tires weren't the same on the two cars so I'll have to play with it some more.
Old 09-29-2015, 06:00 AM   #2875
bmxcrx's Avatar
Disregard.
Current cars: TA07 / FF04 |
For Sale (thread coming soon):
M05v2 / FF03R / Exotek TB04 / F104v2 / F1R3 / RC10R5
RC Car World - Willingboro, NJ.
bmxcrx is offline   Reply With Quote
Old 01-17-2017, 12:26 PM   #2876
Default FF03 Spec R diff help
I've done a search on the forum but can't find an answer and hope someone out there can help me. I've resurrected an early FF03 that has the Spec R gear diff but the car came with no driveshafts. The outdrives are way too wide to fit the stock shafts so I guess some sort of blade/cushion/protector (call it what you want) is necessary. But which sort? I've tried the white Tamiya ones from the TRF417v5/TA06 but they're too thick. 3Racing TA05 ones don't work either and Spec-R don't supply any in the diff kit at all which just confuses me even more.
Mini35 is offline   Reply With Quote
Old 02-17-2017, 05:34 AM   #2877
Hello everyone, i want to ask about my ff03r, what tires did you guys use? Bcause mine when using 13.5t with 4.7 final ratio and spool diff the front tire not survive just 6 pack of full batt the tire torn apart outside
Then i tried using sport tuned + 5.7 ratio + 1million cst diff oil still the glue off the tires
Im using volante tires btw
And i want the car competitive, now i can't push all out of the car bcause the tire can't survive
kytr8matic is offline   Reply With Quote
Old 02-17-2017, 05:54 AM   #2878
Peter $'s Avatar
Hi guys
Kan you get this geardiff to fit in a FF03? Gear Differential Set 37T (For Tamiya TRF 416/417) [SPR009-TMY] - $34.50 : Spec-R, The Professional Accessories for R/C
Or which geardiff does fit?
Cheers,
Peter
Peter $ is offline   Reply With Quote
Old 02-17-2017, 12:57 PM   #2879
Trader Rating: 4 (83%+)
Tamiya 54471 TA06 Steel Gear Diff Unit - Rear TA06 / FF03
Tamiya 54398 FF03 Gear Case - For Gear Differential
Xray T4 2017
Yokomo BD7 2015 Spice FWD
Yokomo YR-10F F-1
VBC FF17 FWD
VBC FXM F-1
Quinny45 is offline   Reply With Quote
Old 02-20-2017, 12:13 AM   #2880
Peter $'s Avatar
Thank you (I guess thats a "no" to the question whether the Spec-R diff wil fit or not).
Cheers,
Peter
Tamiya Championship Series Neil Rabara Racing Forum 21150 08-18-2017 08:58 PM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 730 08-15-2017 08:06 PM
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5791 08-04-2017 09:31 PM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 11:28 AM
