Like Tree21Likes
Old 08-15-2014, 10:06 AM   #2821
3rd-dan's Avatar
@Butler205
Thanks.
@tobyzhang
Which Option Wing do you use?
There are several wings available.
I use a JAS Honda Body.
Cheers Mike
3rd-dan is offline   Reply With Quote
Old 08-15-2014, 01:24 PM   #2822
Originally Posted by tobyzhang View Post
Never had a old FF car so not sure how they compare but FF03 is very tail happy in high speed. The car gains steering as the speed increases. the front diff cannot be set too tight otherwise the car becomes very hard to control in high speed sweepers.
Almost any body will work well on good grip carpet even without a option wing.I run Scirocco with kit wing in TQRC and the result is pretty good.
In Tamiya America, I tend to have over steer and over sensitivity with high speed sweeper at end of straight with Scirocco when the grip is average. On race day when traction is high the issue is not as severe but none the less still persist. Usual practice at Tamiya America for me is to only sauce rear tires. Tom's Exiv seems to be the most popular in medium to low traction. I think in general a sedan shaped body is the way to go when traction is not very high.
If you do not wish to run TCS FF class and uses option wings on your body, then I think any body will make the car handle well. One guy used to race FF03 in GT3 with a CR-Z body and option wing. He can keep up with 4wd cars just fine.
I have owned and raced all Tamiya Front wheel drive touring cars. In general, the FF01 is the most planted, but has the most understeer if you overcook corners a lot, the FF02 handles like a bigger front wheel drive M-chassis car (which it is). In the end, the corner speed of the FF03 is head and shoulders above both previous models because of the lower center of gravity.
Now for the FF03. Early on, I would agree with the quoted text above. In fact, I had loaned out my FF01 to someone else for our FWD race series, and he smoked my FF03 because I thought that it was too tail happy.
But, the key is understanding the chassis. The chassis is very sensitive to diff adjustments AND weight placement. Let me explain further.
The Scirocco body with the FF03 has been much maligned as not a good body to have on a medium to loose track, but why?
People say it's "aero," and I called b.s. Take that HEAVY plastic wing and hardware off and, instantly, the car is more planted. I further tested by leaving the wing on, and adding twice what the wing and hardware weighs directly below where the wing would be on the chassis, and the car again is instantly planted.
In my own testing, I would disagree with the post above regarding diff setting. I have found that no matter the diff you choose, ball or gear, you just have to run it *tight* as in very little diff action and again, that car is no longer "tail happy" in any situation. How tight? I can almost turn the motor by spinning just one front wheel. If you want more steering, just go looser on the diff. I found that this has a greater effect on the car's general attitude more than anything else
Many have been running the hardest Tamiya front springs on their FF03 to try and tame it down, but buy first running a fairly tight diff and adding some weight above the rear axle, I've found that I can run the front a bit softer and it ends up being more forgiving to drive overall.
You can find me at the folllowing sites:
twowheel at rcracing.com
FuriousFlip at ultimaterc.com
K.O.M. at rccrawler.com
TW@ at vwvortex.com
TwoWheel is offline   Reply With Quote
Old 08-15-2014, 01:45 PM   #2823
tobyzhang's Avatar
That is very interesting, I'll have to do more testing as I did not run that car too much. I used to run front gear diff with ride 45wt putty and in low speed the car handles well but very twitchy in high speed on throttle. I then went to 30k diff fluid and that calmed the car down a bit. I think in terms of how tight the diff is, I could always turn the motor with spinning one wheel, including very high torque rotor motors in a 4.1 fdr. There might be a point of no return on diff tightness where too much locking will make the car unstable on throttle because the front outside tire is pulling on the front end too hard. however, if off throttle, the car is pretty stable although not always.
tobyzhang is offline   Reply With Quote
Old 08-15-2014, 04:06 PM   #2824
tobyzhang's Avatar
Originally Posted by 3rd-dan View Post
@Butler205
Thanks.
@tobyzhang
Tamiya 53604 Racing Wing Set is very good for most conditions for Tamiya Scale bodies. I use the smaller one of the set for asphalt and the scooped one for carpet or lose conditions. All the wings Tamiya offer are good for certain conditions. They all feel slightly different. For FF, I only suggest to use the relatively lower down force wings. Bigger wing tends to make the car too stuck and increases drag. But if Two Wheel is right, I might have to change my perspectives.
Old 08-16-2014, 04:12 AM   #2825
Tommi Makkinen's Avatar
Trader Rating: 28 (89%+)
Thanks bro. I'm going to run in our local races that uses the Tamiya Asia Cup rules which actually specify only the use of FF specific bodyshells... and since our next run will be on carpet, the CR-Z might be a good choice but i just need to know if the body alone will work on carpet and not have to use the Tamiya option racing rear wing or do i have to put on the wing for it to work.
Originally Posted by SteveM View Post
I have run several bodies on my FF-03 Pro and my favourite is the Tom's Exiv. I also run a Peugot Xsara abd a BMW 320si WTCC 2006 body. I have also run in our 17.5 blinky sedan class with a Protoform R9R
Thanks also bro. The Exiv might be also OK for tarmac surfaces but its kinda tough to find one here where i live. and as for the Xsara and BMW, its not allowed in our rules since theyre not FF based... but in case of an "open" class race, i mmight have that R9R body in mind... hehehehehe
Racing is in my blood
Tommi Makkinen is offline   Reply With Quote
Old 08-16-2014, 04:25 AM   #2826
3rd-dan's Avatar
Thumbs up
Thanks alot @tobyzhang.
Will try it out.
Cheers Mike
Old 08-16-2014, 01:47 PM   #2827
Clawhammers's Avatar
Too bad, seems the rules has not been amended.
The box of FF-03 EVO states that FF-03 and XV-01 Bodies are recommended by Tamiya Japan (officially)
I wish Tamiya'd release FF-03 EVO MS ....
Clawhammers is offline   Reply With Quote
Old 08-16-2014, 10:58 PM   #2828
OSherman's Avatar
Heard there is/was an FF03 based off of the 417 chassis that the TRF team is/was driving across the pond not long ago. Im guessing similar to what Kentech custom built.
Anyone have anymore info?
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 08-17-2014, 01:09 AM   #2829
That one is a homemade chassie based on the 417... It´s made by kentech from Finland i think.. Here´s the adress to his blog: kentech.blogs.se/
<Awesomatix A700 EvoII><Highest><Sanwa><Muchmore><Fantom>
<Awesomatix A800a><Hitec><Sanwa><Muchmore><Fantom>
<VBC LightningF><Hitec><Sanwa><Muchmore><Skyrc>
<=Team Autopartner=>
Gillblade is offline   Reply With Quote
Old 08-17-2014, 01:15 AM   #2830
Forgot to Thank you for this info TwoWheel... my bad. But i appreciate the additional info. I have right now a few used shells to use as test mules and to see which bodyshell will be suited for the track with my driving... one's a honda EG Civic (the old one), A VW Scirocco (no wing but i'll test it anyway) and a Honda Accord (just to see how it handles)
Old 08-17-2014, 04:28 AM   #2831
tobyzhang's Avatar
two wheel is spot on regarding the body and chassis tuning. Today I added 21g near the rear axle and it instantly tamed down the car with scirocco body on stock wing. By using shorty and moving the battery rear ward also helps a little bit. I was able to go yellow yellow on spring and sauce the front way more than in the past. front still needs heavy damping due to the weight of the motor in front. I'm currently using AE 60 wt front and 27.5 rear on a 86F day. I think FF03 can maybe run without aero now on most surface without issues. Will play with diff again in further testing.
Old 08-17-2014, 10:29 AM   #2832
OSherman's Avatar
Yes, I know of Kentechs ride already. My post was in reference to his actually. Supposedly there were MANY (more than one) of them used by the TRF. Looking to fmget fact about that if there is any. And if so was it a prototype run for production anticipation?....
Thanks.
•KO Propo America
•EXOTEK
Old 08-17-2014, 10:36 AM   #2833
CraigMBA's Avatar
Trader Rating: 22 (100%+)
Thanks.
Was it the Ff03 EVO? I have one. Its three seconds slower than yours....
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline   Reply With Quote
Old 08-17-2014, 05:50 PM   #2834
tom_chang79's Avatar
Hi all,
I'm a bit new to this FWD type of vehicles and I recently started to become interested in these FF03 chassis.
I owned a FF01 chassis (the PIAA Accord), but I paid way too much for it NIB, and I turned it around and sold it back out NIB so I never had a chance to build it and run with it.
I have several questions regarding the FF03:
1) Knowing the history of Tamiya, is the FF04 in the works (is the FF03 an endangered species?)
2) FF03-pro vs. FF03-evo: which one is the latest one? I see that the EVO has the front shocks in different position as the Pro, and it also seems like it's double-deck (for rigidity?)...
3) Is it quite expensive to convert a regular FF03 into a Pro/Evo?
4) Would anyone want a regular FF03? I'm trying to figure out if I should buy the FF03 kit (because I'm really after the body), and just part with the rest of the car... I have WAAAAAAY too many chassis I'm upkeeping at the moment...
Any help would be appreciated, thanks!
RIP TAP RC
tom_chang79 is offline   Reply With Quote
Old 08-17-2014, 06:24 PM   #2835
OSherman's Avatar
It's not the Evo.. I have one too, and yes it's fun.
The way this person was talking is that it is/was based off of a sedan (417/418) similar to Kentechs custom project.
•KO Propo America
•EXOTEK
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5782 Today 03:14 AM
Tamiya Championship Series Neil Rabara Racing Forum 20952 Yesterday 10:43 AM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 723 02-09-2017 08:16 AM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 11:28 AM
