Old 06-02-2014, 08:22 AM   #2806
Chrissy C's Avatar
Hi, does anyone have a copy of the FF03 Evo manual on pdf that they could send me, or direct me to an online one if there is one (although I have looked and can't find it)
Thanks,
Chris
Chrissy C is offline   Reply With Quote
Old 06-02-2014, 08:30 AM   #2807
stormridersp's Avatar
Thanks,
Chris
I was looking for the exact same thing!
stormridersp is offline   Reply With Quote
Old 06-02-2014, 08:48 AM   #2808
Clawhammers's Avatar
You can found it here
Direct link for FF03 Evo
http://www.tamiya.com/japan/download...al/ff03evo.pdf
Clawhammers is offline   Reply With Quote
Old 06-03-2014, 02:39 AM   #2809
Chrissy C's Avatar
Now why couldn't I find that??!! Thanks Clawhammer, massive help
Old 06-04-2014, 01:26 PM   #2810
3rd-dan's Avatar
Hi Guys,
ive a question.
I now own a FF-03 Chassis.
I dont have any experience with FWD Cars.
Now i want to know how i can adjust the ride high?
With the pushrods or the dampers?
Or a combination of both?
Cheers Mike
3rd-dan is offline   Reply With Quote
Old 06-04-2014, 02:27 PM   #2811
I have 1 question for the FF03 community:
Im looking for these aluminum shaft/posts that are used in YeahRacing FF03 Graphite conversion, so I can complete my XV01 Carbon Fiber Chassis project, but I cant find them anywhere.
http://www.rcmart.com/yeah-racing-ff...h=595_744_1471
14mm Side Plate Shaft (8 pcs)
14.5mm Center Support Shaft (2 pcs)
16.5mm Steering Shaft (2 pcs)
18.5mm Front Side Shaft (2 pcs)
Does anyone knows where I can buy those without having to purchase this entire $99 bucks package?
Old 06-04-2014, 06:54 PM   #2812
just buy the 3racing one
http://www.rc-mushroom.com/product_i...r-ff03-p-21689
Xray T4 2017
Awesomatix A700 L2
Yokomo BD7 2015 Spice FWD
12th scale Roche 2016
Quinny45 is offline   Reply With Quote
Old 06-06-2014, 07:46 AM   #2813
3rd-dan's Avatar
Originally Posted by 3rd-dan View Post
Hi Guys,
ive a question.
Has nobody an answer for me?
Searched the forum, but couldn't find anything.
Cheers Mike
Old 08-10-2014, 09:54 AM   #2814
Butler205's Avatar
Combo of both. More spacers in the dampers above the springs will reduce the sag, which can affectively give you more height.
Just bought one myself. Hope to run to race it on Wednesday.
Butler205 is offline   Reply With Quote
Old 08-10-2014, 09:57 AM   #2815
Butler205's Avatar
What's the best solution for gearing. Using a silver can so I think it needs to be taller than stock. Have 2 XV01s in my racing group that will need to do the same. Can you buy a bulk bag of all different spurs and pinions?
Old 08-10-2014, 10:15 AM   #2816
ThePanda's Avatar
Trader Rating: 62 (100%+)
Usually pinions and spurs have to be bought separately.
ThePanda is offline   Reply With Quote
Old 08-14-2014, 01:23 AM   #2817
Butler205's Avatar
Anybody know what the tyres are that are supplied with the Civic JAS kit?
M05 Racer(retired) FF03 Racer - Brushless Hyper 7 Basher
Last edited by Butler205; 08-14-2014 at 08:50 AM. Reason: Found the answer on page 108. Type A
Old 08-15-2014, 07:20 AM   #2818
Tommi Makkinen's Avatar
Trader Rating: 28 (89%+)
Hi guys, I'm a little bit rusty on racing FF's so i just need a bit of info to get up to speed...
-On carpet, what's the best Tamiya FF body to use? I heard somewhere that it was a toss-up between the VW Scirocco, Honda EG6 Civic, and Honda CR-Z with the Tamiya option racing rear wing.
-when running these newer FF-03 cars (i've only driven FF-01 and FF-02's previously but it was a very long time ago...), do they behave like the old FF cars?
Thanks in advance...
Racing is in my blood
Tommi Makkinen is offline   Reply With Quote
Old 08-15-2014, 10:34 AM   #2819
tobyzhang's Avatar
Never had a old FF car so not sure how they compare but FF03 is very tail happy in high speed. The car gains steering as the speed increases. the front diff cannot be set too tight otherwise the car becomes very hard to control in high speed sweepers.
Almost any body will work well on good grip carpet even without a option wing.I run Scirocco with kit wing in TQRC and the result is pretty good.
In Tamiya America, I tend to have over steer and over sensitivity with high speed sweeper at end of straight with Scirocco when the grip is average. On race day when traction is high the issue is not as severe but none the less still persist. Usual practice at Tamiya America for me is to only sauce rear tires. Tom's Exiv seems to be the most popular in medium to low traction. I think in general a sedan shaped body is the way to go when traction is not very high.
If you do not wish to run TCS FF class and uses option wings on your body, then I think any body will make the car handle well. One guy used to race FF03 in GT3 with a CR-Z body and option wing. He can keep up with 4wd cars just fine.
tobyzhang is offline   Reply With Quote
Old 08-15-2014, 10:57 AM   #2820
SteveM's Avatar
Trader Rating: 125 (100%+)
I have run several bodies on my FF-03 Pro and my favourite is the Tom's Exiv. I also run a Peugot Xsara abd a BMW 320si WTCC 2006 body. I have also run in our 17.5 blinky sedan class with a Protoform DNA and R9R
SteveM is online now   Reply With Quote
Tamiya Championship Series Neil Rabara Racing Forum 20851 01-17-2017 10:21 PM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 711 01-08-2017 09:27 AM
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5774 09-23-2016 10:49 PM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 12:28 PM
SEO by vBSEO 3.5.0
