Like Tree24Likes
Old 03-28-2014, 10:29 AM   #2776
Trader Rating: 4 (83%+)
I started to adjust my car to USGT rule ! I received my spec tire and wheels this morning and I ordered my SMC 4300mah 50C shorty pack yesterday ( 75g less than my 5000mah wolfpack ) and my Tamiya Civic typeR JAS motorsport body ! I will probably run my old LRP X12 21.5 motor or buying another one like orca motor
Xray T4 2017
Yokomo BD7 2015 Spice FWD
Yokomo YR-10F F-1
VBC FF17 FWD
VBC FXM F-1
Quinny45 is offline   Reply With Quote
Old 03-28-2014, 01:24 PM   #2777
Teamhotrods's Avatar
Let me know what your final race setup weight. I'm looking at getting one for Usgt and running the 1200 weight if I can swing it.
Sam
TC4 VTA. RC 10 Gold Pan
2wd SCT. 4wd Rally.
Mugen MBX6 ECO Tekno conversion
Teamhotrods is offline   Reply With Quote
Old 03-28-2014, 01:51 PM   #2778
CraigMBA's Avatar
Trader Rating: 22 (100%+)
Body selection is going to be the biggest factor in your weight goals.
A tamiya LW NSX is 58 grams. A VW Golf is like 140.
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline   Reply With Quote
Old 03-28-2014, 01:53 PM   #2779
for the moment my EVO is at 1375g .
SMC shorty is +- 70g less
I will switched my ESC for a Tekin Gen 2 +- 20g less
I will changed the body for one with less paint ( Honda civic JAS motorsport )
I don't know if the LRP x12 is more heavy than a novak balistic
I hope to go below the 1250g
Xray T4 2017
Yokomo YR-10F F-1
VBC FF17 FWD
VBC FXM F-1
Old 04-01-2014, 02:32 PM   #2780
I need test 2 or 3 other configuration but for the moment this one is the best !
Xray T4 2017
Yokomo YR-10F F-1
VBC FF17 FWD
VBC FXM F-1
Old 04-03-2014, 08:18 AM   #2781
I switch the gear diff with putty for ball diff = -20g
cut extra wire =-5g
with JAS motorsport civic ( no light bucket, no Mirror , no roof trap ) = 1276g reedy race
with civic EG body = 1253g
Xray T4 2017
Yokomo YR-10F F-1
VBC FF17 FWD
VBC FXM F-1
Old 04-03-2014, 10:55 AM   #2782
Nice... now run a nsx body without paint.... is that frowned on...lol!
Sam
2wd SCT. 4wd Rally.
Old 04-07-2014, 12:10 PM   #2783
cartix's Avatar
Trader Rating: 33 (100%+)
Is there anything I can do to try to make the gear diff work reliably?
Cars and boats, lots!
cartix is offline   Reply With Quote
Old 04-07-2014, 09:01 PM   #2784
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
from the top of my head...
1. don't use putty
2. use metal gears
3. use the orange o-rings off the 417v5 (or similar)
4. green slime the o-ring to death
5. shim it properly
the gear diff is reliable but still needs some maintenance... anti wear grease on the outdrives help "delay" the shaft pins from scraping through the metal but would eventually need to be replaced (both the outdrive and the shaft). you can op to use the TA06 option lightweight outdrives which uses a 3.5mm cushion/c-protector. once there's a grove on the outdrive, i noticed the car starts to stutter around corners (high grip carpet).
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 04-08-2014, 08:26 AM   #2785
cartix's Avatar
1. don't use putty
2. use metal gears
5. shim it properly
Thanks for the info.
Old 04-08-2014, 09:09 AM   #2786
tobyzhang's Avatar
It seems very hard to get FF03 right at Tamiya America. I run GTI cup body without aid of any aero and it is very very loose. Full Sauce rear, and no sauce front do not fix it completely. I know the wing on vw scirocco will help but have not tried it yet. harder spring at the rear like blue do help to certain degree but once over board the traction goes away again. Thinking of trying the GTI 35 edition with big wings in the back next time also. Any suggestions on how to gain traction on the rear?
tobyzhang is offline   Reply With Quote
Old 04-08-2014, 09:46 AM   #2787
increase toe-in
softer rear spring
increase up-travel ( droop )
stand up rear shock
what diff are you using ? gear, ball, spool ?
Xray T4 2017
Yokomo YR-10F F-1
VBC FF17 FWD
VBC FXM F-1
Old 04-08-2014, 01:59 PM   #2788
CraigMBA's Avatar
Are the gear diffs unreliable?
Old 04-08-2014, 07:32 PM   #2789
tobyzhang's Avatar
Originally Posted by Quinny45 View Post
increase toe-in
softer rear spring
stand up rear shock
I need to increase toe in for sure
will try red next time and decrease to 27.5 oil
shock is pretty stood up already
I use gear diff with ride 45 diff putty
I honestly think the car is going to be okay once using a body with any wing on it.
Old 04-08-2014, 08:07 PM   #2790
VooDooPH's Avatar
You can also try going down to 500k oil in your diff. It helped calm a buddy's car dow after running 1M oil.
Running the outer camber link (shorter link) in front also helped calm the car down in my experience. I run yellow springs and red swaybar in front and blue spring + blue swaybar in the rear (asphalt track)
Hths.
Tamiya Championship Series Neil Rabara Racing Forum 21092 Today 06:27 PM
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5790 06-17-2017 05:27 PM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 724 04-03-2017 12:43 PM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 11:28 AM
