Like Tree24Likes
Old 02-22-2014, 09:36 PM   #2746
CraigMBA's Avatar
Trader Rating: 22 (100%+)
My evo came in at 1353, ready to race. Going to gain a few more as I add the wing and the stickers.
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline   Reply With Quote
Old 02-26-2014, 05:18 AM   #2747
C5R01's Avatar
Send a message via Yahoo to C5R01
Need a little help. Need to see how the brushless motors are put onto the FF03. Can someone post pics of how they did it and what you need to do this.
Current Cars:
Tamiya Garage:TB03; TA05V2-IFS; 414X #60;F104 V2;TA03r-s:TA03F:TA03R: FF01: FF03: M01: M03: M06: 1/14 Mercedes Semi truck- w/Reefer trailer ( fully functional): Tamiya Juggernaut 4X4X4, Tamiya RC Freightliner Cascadia Evo.; Honda City Turbo WR-02C; TRF102 F1
OTHERS:Kyosho 1/8th scale nitro Corvette C6R: Yokomo GT4 nitro, Slash 2WD,TA SCm5
C5R01 is offline   Reply With Quote
Old 02-26-2014, 05:54 AM   #2748
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
For standard sensored bl motors you'd need a spacer between the motor and motor plate for the soldertabs to clear the left motor support. Tamiya makes one for the TB03D (pictured)
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 02-26-2014, 05:57 AM   #2749
Trader Rating: 4 (83%+)
LRP X20 17.5
just need a long sensor wire... with the LRP you dont need the spacer between the motor and motor plate because you have enought hole to put the motor at the right place and the soldertabs are perfect fit !!
Xray T4 2017
Yokomo BD7 2015 Spice FWD
Yokomo YR-10F F-1
VBC FF17 FWD
VBC FXM F-1
Quinny45 is offline   Reply With Quote
Old 02-28-2014, 05:09 AM   #2750
C5R01's Avatar
LRP X20 17.5
just need a long sensor wire... with the LRP you dont need the spacer between the motor and motor plate because you have enought hole to put the motor at the right place and the soldertabs are perfect fit !![/QUOTE]
Thanks!
Current Cars:
Old 02-28-2014, 05:35 AM   #2751
SteveM's Avatar
Trader Rating: 139 (100%+)
BL motors with the solder tabs on top may not fit as the motor cannot be inserted deep enough. The cooling plate mentioned already might help in some cases.
I went with a Speed Passion 17.5 motor that uses the bullet connectors on the end bell which eliminated any issues.
SteveM is offline   Reply With Quote
Old 02-28-2014, 11:09 AM   #2752
CraigMBA's Avatar
After having installed the motor in mine, I ordered some 16g wire and plan on pre wiring the motor, installing it, and then soldering the leads straight to the speed control for length.
Old 02-28-2014, 09:44 PM   #2753
vadersing's Avatar
Default FF03 Evo
Hi
Anyone has a FFO3 Evo to sell? Ideally new in box.
Please PM price.
vadersing is offline   Reply With Quote
Old 03-06-2014, 08:39 AM   #2754
What combo spring and oil do you use for the front suspension of your FF03 EVO because in my case in the long fast corner the plastic bumper and the frame rub the carpet alot... my ride height is set to 5.5 mm I use Tamiya blue spring in the front with Associated 45 grade silicone ?
Xray T4 2017
Yokomo YR-10F F-1
VBC FF17 FWD
VBC FXM F-1
Old 03-07-2014, 10:19 AM   #2755
I think it is not easy to find a good set up on the evo front suspension. I have not run it much yet but I have made no progress on the set up so far. See picture for a Evo set up from some driver at TITC Race
BJS414 is offline   Reply With Quote
Old 03-07-2014, 11:18 AM   #2756
Thank you mister ! This setup is similar to mine but I will check this !! I don't understand why he put 100g over the chassi ? anybody try a center battery configuration on a EVO ?
Xray T4 2017
Yokomo YR-10F F-1
VBC FF17 FWD
VBC FXM F-1
Old 03-07-2014, 12:31 PM   #2757
CraigMBA's Avatar
When I ran mine this past weekend, it was unpredictably snap sideways loose. Sometimes early in the turn, sometimes in the middle, sometimes late. Was dependent on how much weight transfer you had in the car, how much wheel, and how hard you were on the gas.
No matter what changes I did to the rear, it didn't help fix it. Car felt different, but center off it wasn't an improvement. Next time I go back to the track, I'm putting the baseline rear back on and try changing only the front.
Old 03-12-2014, 07:43 AM   #2758
Next Saturday I'll try a new configuration for the battery. I will try the same configuration as the Tamiya M05 to see if the car will be more stable and fast cornering than the initial configuration
Xray T4 2017
Yokomo YR-10F F-1
VBC FF17 FWD
VBC FXM F-1
Old 03-12-2014, 09:45 AM   #2759
I dropped the idea of ​​style M05 battery. I reassemble as before and decide to work little harder the balance side... 60g of the opposite side of the battery and that's it !!
Xray T4 2017
Yokomo YR-10F F-1
VBC FF17 FWD
VBC FXM F-1
Old 03-12-2014, 10:10 AM   #2760
nrtv20's Avatar
I love looking at the front wheel drive cars, the EVO is a nice looking kit!
http://www.trautengineering.com/ http://www.toledooneeighthracers.com/
http://www.youtube.com/user/nrtv20
One Eigth Racers of Toledo; Hobby Stop West Track; "The Gate" NORCAR
FUTABA 2.4G FASST, Spec-R S1, Speed Passion SP-1, Sakura D3 FWD, Kyosho Evolva M3, Team Losi XX-4, Caster EX1.5R, HPI Wheelie King Crawler, Quanum Aquaholic, Joysway Wildcat
nrtv20 is offline   Reply With Quote
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5806 09-22-2017 03:06 PM
Tamiya Championship Series Neil Rabara Racing Forum 21185 09-05-2017 07:20 PM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 730 08-15-2017 08:06 PM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 11:28 AM
