Like Tree23Likes
Old 06-17-2013, 08:16 AM   #2671
SteveM's Avatar
Trader Rating: 133 (100%+)
Originally Posted by Rich Valente View Post
Hi all,
Sorry if it's been covered before, searched but could not find much.
I bought a used FF03 Pro with 3Racing chassis and raced it for the first time yesterday in USGT (21.5t brushless) and it ran great the first 2 heats. My youngest son ran it in the main and he had a few hard hits and it quit moving (or moving very slowly when on the ground) tires seems to spin fine when it's on the pit stand, but just slipping on the ground.
I know it sound like something with the diff/tranny and I did see some oil stain/leak on the front tranny case.
My question is, what's the most worry-free diff/tranny setup for the FF03? I see ball diff options from 3Racing and gear diff options from SpecR (SPR028-GBDFF), as well as Tamiya (54471)?
Thanks,
-Rich
Based on my experience racing the FF-03 in my club's 17.5 blinky class, the best solution for me was the Spec-R gear diff running fairly thick diff fluid. The Tamiya ball diff slips even when new and just doesn't work.
SteveM is offline   Reply With Quote
Old 06-17-2013, 08:24 AM   #2672
Rich Valente's Avatar
Trader Rating: 21 (100%+)
Default which one?
Thanks Steven,
TQ Racing has this - SPR028-GBDFF - http://www.tqrcracing.com/shop/produ....asp?p_id=2283 - $31
RC Mart has this - http://www.rcmart.com/spec-spr009ff-...h=595_744_1471 - $26.50
Looks like the TQ Racing is a complete pre-built diff with the tranny cases? Seems like a no-brainer to get the one from TQ Racing, is that the one you are running or what's the difference between the two?
Thanks,
-Rich
Rich Valente is offline   Reply With Quote
Old 06-18-2013, 01:07 AM   #2673
Your best option currently is the Tamiya gear differential, 54471. This includes the steel gears as well as the steel cross-joint. You will need 54398 (FF03 gear case) as well.
HannK is online now   Reply With Quote
Old 06-18-2013, 01:55 AM   #2674
Best combination for 17.5t blinky is (IMO):
TA-06 Diff with Roche - Heavy Duty Diff Cup Joint for TA05/TA06
To get TA06 diff to fit you need new transmission case:
9008152 FF-03R A Parts
In finland all huge FF11 drivers and mostly all FF03 drivers use TA-06 diff's.
Spec-R diff's were used before but they wouldn't last.
TeemuS is offline   Reply With Quote
Old 06-21-2013, 06:39 AM   #2675
bizkit1's Avatar
Trader Rating: 27 (100%+)
Would this car be good to run at the TCS National in GT3 class or should I go with a TA06? As I will be flying out there, I don't want to take more than I need and would like some input from any past winners and maybe some set-ups using a 21.5 motor, as that is the legal motor in the GT3 class. Thank you for any help.
George
bizkit1 is offline   Reply With Quote
Old 06-25-2013, 02:48 AM   #2676
Have anyone seen this new kit from Tamiya... Any news or pics of it yet?
http://www.tamiyausa.com/items/radio...ssis-kit-84354
<Awesomatix A700 EvoII><Highest><Sanwa><Muchmore><Fantom>
<Awesomatix A800a><Hitec><Sanwa><Muchmore><Fantom>
<VBC LightningF><Hitec><Sanwa><Muchmore><Skyrc>
<=Team Autopartner=>
Gillblade is offline   Reply With Quote
Old 06-30-2013, 12:01 AM   #2677
Good but it's worrying that they still seem to have laydown front dampers. They need to put a normal damper mount on their FF03 soon... It's nice looking but I think it is more difficult to set up and more balljoints means more play in the suspension.
BJS414 is offline   Reply With Quote
Old 06-30-2013, 01:32 AM   #2678
zephuros's Avatar
Worrying indeed. Haha. But I think I'll stay away from another limited edition tamiya item. My lower deck for the carbon conversion is dead and I can't seem to get a new one. I'm not a happy puppy
awww bollox....
zephuros is offline   Reply With Quote
Old 07-01-2013, 01:00 PM   #2679
bizkit1's Avatar
Got a question for anybody that has run out at the Tamiya track in Cali. How or what kind of setup did you use and what kind of gearing was used? It seems the lower you go on your gear ratio, the more the car takes to build up speed. Am I correct in this? I'm wanting to run this in GT3 this year, as this is my first time going to Cali, much less a plane, and I need all the help I can get. Thanks,
George "Fuzzy" Sharp
Old 07-03-2013, 09:40 AM   #2680
kentech's Avatar
Translated info
84354 FF-03 EVO Chassis Kit
- 2.5mm thickness, new design carbon chassis. New style from 84314 upper vertical frame of the upgrade set was changed to (2.0mm) deck type.
- L size only, wheelbase front of the battery. Center of gravity of the balance depending on the situation enables after move It can be changed.
- The standard double cardan drive shaft and Giyadefu
- The model is best suited to the race that is equipped.
New design parts
- carbon main chassis (2.5mm thickness)
- carbon upper deck (2.0mm thickness)
- Carbon Rear Shock Stay (3.0mm thick)
- bulk aluminum rear aluminum
- aluminum rear upper arm mount
- aluminum front damper mount
- aluminum steering mount
Main equipment
- TRF damper
- aluminum turn buckle
- bearing
- TRF hex screw
- Gear diff
- Souble joint Cardan drive shaft
August 21st release.
http://kentech.blogs.se/
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 07-18-2013, 07:12 AM   #2681
bizkit1's Avatar
Just wondering if anybody had any "binding issues" when using the gear diff and the 417 outdrives? It seems really tight when I turn the wheels, kinda like lobeing. Any thoughts would be appreciated.
George
Old 07-22-2013, 10:54 PM   #2682
hanzo3's Avatar
Trader Rating: 55 (100%+)
I am having trouble using a bl motor on the ff03. I can only mount one motor screw. Is there a way or do I need to grind? I am using a Novak 21.5
Chris TRF419 TA05V2
TQ RC Racing Powered by teeth
hanzo3 is offline   Reply With Quote
Old 07-22-2013, 11:41 PM   #2683
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
Originally Posted by kentech View Post
Translated info
New design parts
Main equipment
- TRF damper
- bearing
- TRF hex screw
- Gear diff
hehehe... looks like a giant xevo conversion for the mini...
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 07-23-2013, 11:55 AM   #2684
Novak motor tabs are much further in than other BL motors. I.e. Tekin or LRP
I sanded both motor tabs and carbon mount on mine.
http://tamiyatorg.blogspot.com/2012/...raded.html?m=1
torg is offline   Reply With Quote
Old 08-01-2013, 11:44 PM   #2685
Hi Guys,
Need some advice !
Had been a fan of front wheel drive machines since i started this hobby.
Was away for quite awhile and was looking online for FF03..
Came across this combo:
http://www.max-hobbies.com/ff03-spec...etCurrencyId=2
Is this combo worth to get ??
Thank you !
august1989 is offline   Reply With Quote
Tamiya Championship Series Neil Rabara Racing Forum 21024 Yesterday 10:48 PM
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5789 04-27-2017 10:11 PM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 724 04-03-2017 12:43 PM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 11:28 AM
