Like Tree34Likes
Old 03-22-2012, 05:45 PM   #2431
Airflow's Avatar
Hi, possible to install 40T 48P pinion and still use the gear cover?
Airflow is offline   Reply With Quote
Old 03-24-2012, 04:17 AM   #2432
Lethal Enforcer's Avatar
Trader Rating: 97 (100%+)
So if I understand it right Tamiya does not make a gear diff.
Axial Scorpion ,Team Associated TC5R , Tamiya M03R, Tamiya RC Onroad.com
2012 TCS Best of show Mini
2012 TCS Best of show TT01
Lethal Enforcer is offline   Reply With Quote
Old 03-24-2012, 08:40 AM   #2433
Very soon Tamiya must be presenting a FWD up to TRF spec. Carbon chassie Aluminium bulkheads etc. If not I have to go elsewhere for a FWD. But I think they will have some good news in May.
BJS414 is offline   Reply With Quote
Old 03-27-2012, 09:00 PM   #2434
For the Spec R gear diff, what was the consensus for the best diff oil for a tight carpet track?
I'm trying to decide between 100k and 300k.
Machine1 is offline   Reply With Quote
Old 03-27-2012, 09:16 PM   #2435
cannon's Avatar
Trader Rating: 35 (100%+)
Dont bother.
The Spec R diffs are absolute rubbish ... very unreliable
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 03-27-2012, 09:34 PM   #2436
I already have the diff. The factory diff is destroyed (broken outdrives, etc.)
What makes the Spec R diff rubbish?
Old 03-27-2012, 09:39 PM   #2437
cannon's Avatar
The internal gears are too fragile (even their better version)
We were racing at TIITC in Thailand last month and the Tamiya guys were destroying diffs very easily.
There is a solution. There is a Kyosho diff that will fit in the FF03 but I do not have its details. (it comes from a Short Course truck I believe) It has metal gears and is far stronger
Old 03-28-2012, 07:10 AM   #2438
Very interesting I will have to look into that
Old 03-28-2012, 05:01 PM   #2439
Anyone try the 3racing aluminum ball diff
Old 03-28-2012, 05:06 PM   #2440
SteveM's Avatar
Trader Rating: 140 (100%+)
Dont bother.
I run a Spec-R gear diff in my FF-03 Pro and it's been brilliant. I used a Speed Passion Cirtix 17.5 BL motor and Stock Spec ESC.
SteveM is offline   Reply With Quote
Old 03-29-2012, 02:07 AM   #2441
yes...we used it...nice performance... already 3 races done and still good, btw Mr. Lau gave a thumbs up for winning picture ...
bijono is offline   Reply With Quote
Old 03-29-2012, 02:13 AM   #2442
it's because you run 17.5BL motor and non timing speedo ...
give a try with 10.5T BL and open esc/timming esc, i don't what it called " a superstock touring class".... give your spec-R gear diff a chance... and share wit us what happened ..
Old 03-29-2012, 03:23 AM   #2443
SteveM's Avatar
We don't run a class with those specs. Our top class is 4wd sedan with 17.5 BL and boosted ESC.
Old 03-29-2012, 03:51 AM   #2444
is it a direct fit into a stock ff03
Old 03-29-2012, 06:10 AM   #2445
yes... 3 racing balldiff could be fit in a standard gearbox case of FF03..and i just use 52T original plastic gear diff from tamiya...and I like the Balldiff screw+nut...it's bigger and look like TRF model..
Tamiya Championship Series Neil Rabara Racing Forum 21196 Today 11:56 AM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 732 10-12-2017 02:34 PM
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5806 09-22-2017 03:06 PM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 11:28 AM
