Like Tree24Likes
Old 03-06-2012, 01:28 AM   #2401
Auskenny's Avatar
What cv's work with the spec r oil filled diff ?
Cheers guys
Hot bodies cyclone TCX, Tamiya F104 pro,FF03 pro ,M05 mini ,Futaba 4pks
***PENRITH ELECTRIC MONDAY NIGHT RACING***
Auskenny is offline   Reply With Quote
Old 03-06-2012, 12:07 PM   #2402
Bad-Andy's Avatar
Cheers guys
I'm using 46mm with the 1C suspension mounts and they work fine.
Bad-Andy is offline   Reply With Quote
Old 03-06-2012, 05:45 PM   #2403
Timbulb's Avatar
Originally Posted by Misiek View Post
Is anyone racing FF03 in the USGT class?
I will be attempting it in the next few weeks in our local VTA/GT class. I have a very fast silvercan motor to try in it. I'll let ya know how it goes.
Timbulb is offline   Reply With Quote
Old 03-06-2012, 07:04 PM   #2404
Misiek's Avatar
Sounds good. Thank you in advance.
According to one of the rctech.net members his FF03 was only .4 to .5 second slower than his 4wd...not bad at all for a FWD.
I drove my friend's FF03 last weekend and looks like I'll be getting one soon for TCS and some USGT club racing...
________________________________________________________
On paternity leave...
Misiek is offline   Reply With Quote
Old 03-06-2012, 07:22 PM   #2405
OVA
OVA's Avatar
Trader Rating: 77 (100%+)
if you are .5 slower than the 4wd each lap that's one lap down in the finish races...
I did raced my FF03 againt the 4wd and the FF03 is faster in the back straight but the in the infeild the 4wd is quicker out of the corner
OVA is offline   Reply With Quote
Old 03-06-2012, 08:56 PM   #2406
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
madjack is offline   Reply With Quote
Old 03-07-2012, 08:52 AM   #2407
Luppi Stefano's Avatar
Originally Posted by Luppi Stefano View Post
Hi all!
I read that the ta06 rear gear diff fit on FF03, is true?
no mod required?
thanks
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Old 03-07-2012, 11:57 AM   #2408
Misiek's Avatar
Overall how were your results racing FF03 against 4wd?
Old 03-07-2012, 11:09 PM   #2409
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
Hi all!
no mod required?
thanks
Originally Posted by VooDooPH View Post
Nope.
i think i answered this question in the last page...
anyway, the answer is no... the TA06 gear diff will NOT fit the FF03 without any modifications.
The TA06 gear diff is much wider than what the FF03 will allow to fit even when using the SpecR diff housing.
Pic attached is a comparison between the SpecR FF03 gear diff (white/bronze) and the TA06 gear diff (black).
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 03-08-2012, 09:07 AM   #2410
thank you so much!
Lab F1-01
Old 03-09-2012, 12:35 PM   #2411
Auskenny's Avatar
Can the 3racing Universal Shaft 46mm be used with the spec r oil gear diff?
Old 03-09-2012, 03:14 PM   #2412
caltek1's Avatar
Trader Rating: 36 (100%+)
Shane,
Yes they can. Just check when you put on the blade that there is no binding with the suspension compressed.
I checked my FF03 and with the standard front blocks I am using 44mm universals.
Later,
Calvin.
caltek1 is offline   Reply With Quote
Old 03-09-2012, 03:47 PM   #2413
Auskenny's Avatar
Cheers Cal
Old 03-10-2012, 07:44 AM   #2414
AndyMoore's Avatar
Trader Rating: 53 (100%+)
Send a message via AIM to AndyMoore
Originally Posted by caltek1 View Post
Shane,
Later,
Calvin.
Im using 44mm shafts as well.
|JConcepts|Winning Edge Designs|
AndyMoore is offline   Reply With Quote
Old 03-10-2012, 01:15 PM   #2415
Hi all.
Just picked up a standard ff03. I am looking to do a few cheapish mods to improve it. I was thinking some tuned springs and a full bearing set, what else would you guys recommend? I want it for outdoor and parking lot driving.
Many thanks! JM
Jackiemoon is offline   Reply With Quote
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5806 Yesterday 03:06 PM
Tamiya Championship Series Neil Rabara Racing Forum 21185 09-05-2017 07:20 PM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 730 08-15-2017 08:06 PM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 11:28 AM
