Like Tree21Likes
Old 02-02-2012, 11:33 PM   #2386
Originally Posted by Airflow View Post
Hi, can I use my stock FF03 gears and diffs on a Spec R gear case? Has anyone tried this? Any difference in feel like more precise meshing of gears?
Im running brushless 13.5 system.
Also, I can here a humming/whirling sound while running low speed (walking speed), Im not sure if it's the internal gears (all-stock) or spur and pinion (Tamiya .4 module). I havent rebuilt the gearbox since December.
The spec-r case comes with adapters to accept the normal (or aftermarket) ball diff. The stock gears also fit.
Humming sound is typical for tight mesh or worn gears.
Benjamin
BenjaminX2 is offline   Reply With Quote
Old 02-06-2012, 10:34 PM   #2387
maxepower's Avatar
Talking SHORT ARMS?
Originally Posted by AndyMoore View Post
Fantastic news! I assume all of the suspension blocks share mounting points and only differ in hinge pin placement?
What about wider arms, I believe the kit comes with "short" arms, correct?
The short arm suspension is kind of misleading. It's the pivot point from hinge pin to hinge pin that's is actually longer or shorter that's the difference in length when they call "short or long arms".
The length of the wheel axle and swing shaft is what varies in length to compensate distance from hinge pin to hinge pin and actually ends up determining overall length of the wheel base. This overall length is still the same. Besides adding shims behind the wheel itself is the only way to widen the lengthen from wheel to wheel. I hope this makes sense!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EXO-6,TA-07,TRF419,EVO-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 02-06-2012, 11:33 PM   #2388
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
Originally Posted by maxepower View Post
The kit comes with "A" blocks you can widen all the way to "F" blocks if yo want. Each letter is a half mm, if I'm correct!
Im looking to widen the rear track of my FF03, does Tamiya offer wider rear suspension mounts?
i believe the kit comes with 1XD-1A rear blocks as stock...
but maxpower is right... you can widen the track width by using wider blocks (F is the widest). along with this you can also try using the 6mm alum wheel hexes (silver in color).
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 02-07-2012, 08:25 AM   #2389
AndyMoore's Avatar
Trader Rating: 53 (100%+)
Send a message via AIM to AndyMoore
Great information guys, this is EXACTLY what I was looking for. I picked up wider blocks (retaining stock toe/sweep) and the wider hexes already.
Massive thanks!
|JConcepts|Winning Edge Designs|
AndyMoore is offline   Reply With Quote
Old 02-19-2012, 05:44 AM   #2390
smith9turbo's Avatar
My Huge FF11 (FF03 Convertion) installed with 9TURBO RC Sound & Light.
+ YouTube Video
smith9turbo is offline   Reply With Quote
Old 02-20-2012, 11:12 PM   #2391
Airflow's Avatar
Cool
Airflow is offline   Reply With Quote
Old 02-20-2012, 11:40 PM   #2392
VooDooPH's Avatar
cool! Bit of a purist though... maybe a civic or a levin shell?
+ YouTube Video
Old 03-01-2012, 04:58 AM   #2393
Timbulb's Avatar
Hey folks, I just got an FF03 today for my birthday. Without going through the hundred and something pages, what are the main replacement parts I'm gonna need for this thing? WHat other models have interchangeable parts? Is it true I can't run a normal 64 pitch spur gear on this vehicle?
Thanks in advance. I look forward to spanking some VTA butt in our local VTA/GT class.
Timbulb is offline   Reply With Quote
Old 03-01-2012, 05:00 AM   #2394
!!! My Hufe FF11 (FF03 convertion) got TITC2012 trophy !!!
This clip is my victory. TITC2012 FWD Main C Final
FWD (Front Wheel Drive) is very new & fun for me.
my car body is white/orange color, start at grid position 2.
i so proud with my 1st Main C FWD TITC2012 Trophy.
i use Huge FF11 (FF03 convertion), servo savox sc-1251mg, Hobbywing Justock + xerun BL 13.5T
+ YouTube Video
Old 03-01-2012, 05:04 AM   #2395
Happy Birth Day to you...
huge ff11 (ff03 convertion kit) is nice for me.
gear 48 pitch is better for FWD class... it nice for racing.
Old 03-01-2012, 05:07 AM   #2396
Tamiya have many look good shell for FF03.
you just select one that you like.
Old 03-01-2012, 11:18 AM   #2397
Luppi Stefano's Avatar
Hi all!
I read that the ta06 rear gear diff fit on FF03, is true?
no mod required?
thanks
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Old 03-04-2012, 12:11 PM   #2398
Originally Posted by Luppi Stefano View Post
Hi all!
no mod required?
thanks
Might be worth looking in too
Rd/Rz is offline   Reply With Quote
Old 03-04-2012, 03:53 PM   #2399
VooDooPH's Avatar
Hi all!
no mod required?
thanks
Nope.
Old 03-04-2012, 06:52 PM   #2400
Misiek's Avatar
Is anyone racing FF03 in the USGT class?
________________________________________________________
On paternity leave...
Misiek is offline   Reply With Quote
Tamiya Championship Series Neil Rabara Racing Forum 20960 Today 07:10 AM
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5782 03-26-2017 03:14 AM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 723 02-09-2017 08:16 AM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 11:28 AM
