Old 01-05-2012, 06:26 AM   #2356
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
Originally Posted by Airflow View Post
Stock rear spring rate is ok.
Have you run your kit already? Last year during the TAC qualifiers everybody was running different spring rates front and rear. I was running blue at the rear and yellow in front. Others had it the other way around with blues in front and yellow at the back.
Anyway to answer your question you can either adjust ride height via the pushrods instead of the turning the collar as mentioned above. And you can play around with adding or removing shims at the rocker arm (same effect as moving the shocks at tue shock tower).
For the rocker arms i think the plastic ones work just fine. Just install bearings instead of using the brass bushings for smoother operation.
Hths
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 01-05-2012, 05:52 PM   #2357
Airflow's Avatar
Hths
I have run my kit over 10 times I think. Yellow at the front? Can you show me a pic so I can see how compressed are your yellow springs at the front, I think it's too soft even if you lengthen the pushrods. Are the bearings for the rocker arms available at Lil's?
Thanks for your help bro. I had lots of 4WD kits before and this kit is almost as good as them with the benefit of a sealed drivetrain.
Airflow is offline   Reply With Quote
Old 01-05-2012, 06:14 PM   #2358
VooDooPH's Avatar
old set-up here: http://www.rctech.net/forum/8691073-post1965.html
bearings are available at lils... they're the same size of bearings that go inside the aluminum tamiya ball diffs.
(my kit has alum rocker arms... reused the ones that came with my TA05v2. but i ran my previous TB03 with the plastic rocker arms with bearings)
Old 01-05-2012, 06:37 PM   #2359
Airflow's Avatar
Ok, thanks bro.
Old 01-07-2012, 11:09 PM   #2360
VooDooPH's Avatar
Originally Posted by Starteur View Post
Does anybody know the answer???????
Do 417 diff plates fit the FF03 alu outdrives?
no they don't. 417 diff plates are too big.
Old 01-07-2012, 11:54 PM   #2361
guys question...
does the old corolla wrc shell fit FF03 medium or small?
jebolution is offline   Reply With Quote
Old 01-08-2012, 12:04 PM   #2362
cementsurfer86's Avatar
I would think probably on the short setting.
Jesse Anderson / JROY386 / R_
theRACERunderground - "Budget Champions"
www.theracerunderground.blogspot.com
cementsurfer86 is offline   Reply With Quote
Old 01-11-2012, 02:41 PM   #2363
Ok thanks for the reply. Having problems with Civic shell, I cant lower it as much as I want. I might change to something bigger but FWD models.
Which Civic shell are you running. I want to get one but don't want to run into the same problem I did with the HPI Integra, hood too low for the motor mount. Does anyone know if the HPI Honda Prelude or Mitsubishi Eclipse will fit?
glinx111 is offline   Reply With Quote
Old 01-11-2012, 05:57 PM   #2364
Airflow's Avatar
It's the Civic Castrol. I ended up making a rectangular hole just the motor mount to clear the hood. But then again, I ended up with the Integra shell. It has more room at the front and more menacing.
Tamiya FF03-390130_10150429226972828_711727827_8559038_1500274582_n.jpg   Tamiya FF03-395615_10150429226892828_711727827_8559037_86827223_n.jpg   Tamiya FF03-377556_10150454663352828_711727827_8674671_179323604_n.jpg   Tamiya FF03-378133_10150454663812828_711727827_8674675_349417715_n.jpg
Old 01-12-2012, 10:25 AM   #2365
Most of my rc'ing has been with drifitng so I'm pretty much a noob to onroad racing. I was working on my FF03 last night setting it up for a race this weekend when I ran into a problem. I noticed that when I press down on the bumper at the left front corner, the rear right tire raises up enough to come off the groound. Tried pressing at the right front and the left rear lifted a little but stays in contact with the ground. I adjusted my front shock collars which helped a little but not enough. Though in doing this my chassis is real close to touching the ground and there's almost no suspension travel. I made adjustments on the rear right droop screw and that didn't seem to help either. I then adjusted the front droop screws which caused both tires on the rear to come off the ground when compressing the front suspension. What am I doing wrong?
Old 01-12-2012, 06:12 PM   #2366
VooDooPH's Avatar
had no issues intalling the honda civic shell on my ff03 (didn't have to cut holes on the hood to clear anything)...
Old 01-12-2012, 10:05 PM   #2367
Airflow's Avatar
I lowered my civic shell more (tires are inside the wheel wells) thats why I have to cut it. In your case it's just fine. Im just trying to achieve the stance that I want.
To glinx: Before you adjust anything on the suspension, make your car race ready first like putting the batt. Adjust desired ride height, then adjust droop.
Mine doesnt lift the rear wheels if you press the front bumper and has identical left and right front spring rates. BTW I didnt use the stock TRF springs.
Just my suggestion. Let the experts here help you.
Old 01-15-2012, 02:21 PM   #2368
AndyMoore's Avatar
Trader Rating: 53 (100%+)
Send a message via AIM to AndyMoore
What diameter fan fits on the Spec R gearbox?
Thanks in advance.
|Kyosho America|Team Orion|JConcepts|Airtronics|Winning Edge Designs|
AndyMoore is offline   Reply With Quote
Old 01-16-2012, 05:06 AM   #2369
VooDooPH's Avatar
Thanks in advance.
30mm i believe...
Old 01-18-2012, 01:36 PM   #2370
Default Diff Oil Choice
Thanks in advance.
Hey gents, what viscosity oil are you using (successfully) in your SPEC-R gear diff. My son's car gets too squirrelly in the hairpins, and I think the oil is too thick. A lighter oil will allow more diff action, but I don't know what the original oil was (I didn't install it).
Thanks,
Bill
EB Racer is offline   Reply With Quote
Tamiya Championship Series Neil Rabara Racing Forum 20851 01-17-2017 10:21 PM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 711 01-08-2017 09:27 AM
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5774 09-23-2016 10:49 PM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 12:28 PM
SEO by vBSEO 3.5.0
