Like Tree23Likes
Old 12-27-2011, 06:24 PM   #2341
Airflow's Avatar
Originally Posted by alana07 View Post
Mazda Sp 6 fits nicely, but you do need to trim some bits off the foam bumper though.
Thanks but wont the low slung hood of the Mazda Speed 6 hit the motor mount/gear cover?
Airflow is offline   Reply With Quote
Old 12-27-2011, 09:52 PM   #2342
Nope, it fits quite well - besides having to trim the bumper a little and looks the business too!
Dave5290 is offline   Reply With Quote
Old 12-27-2011, 10:09 PM   #2343
Airflow's Avatar
Thanks but can you post pics?
Old 12-28-2011, 03:23 AM   #2344
SteveM's Avatar
Trader Rating: 133 (100%+)
I have used the Protoform DNA 1 body on my FF-03 without any issues as well as the Parma RTB GBS body. Both were excellent.
SteveM is offline   Reply With Quote
Old 12-28-2011, 04:49 PM   #2345
Airflow's Avatar
Wow thanks. I noticed that you used two different mounting holes at the front. If it's the same ff03, it should've had the same mounting holes at the front. Can you show it again but this time with the shell removed so I can see how much urethane bumper material I have to shave off. Thanks.
Old 12-28-2011, 05:19 PM   #2346
SteveM's Avatar
I removed the stock foam bumper and bought peel and stick 1/2 inch foam sealing tape from the local auto shop. I was running the Speed Passion Citrix Club Spec speed control and a 17.5 BL motor. I have since reverted back to the silver can motor for TCS events.
Old 12-28-2011, 05:29 PM   #2347
cementsurfer86's Avatar
This may have already been covered, but do they make a fluid-filled gear diff for the FF? Seems like it would be a good idea.
Jesse Anderson / JROY386 / R_
ThreeEightSix / Sticky Kicks RC
theRACERunderground - "Budget Champions"
www.theracerunderground.blogspot.com
cementsurfer86 is offline   Reply With Quote
Old 12-28-2011, 05:48 PM   #2348
Airflow's Avatar
Ok, got it. Thanks again. Ill try a Mazda Speed 6 shell to night.
Old 12-28-2011, 05:49 PM   #2349
SteveM's Avatar
Yes, by Spec-R and you also need there gear case halves.
http://www.spec-r.com/default/index....roducts_id=138
Old 01-04-2012, 09:43 AM   #2350
Starteur's Avatar
Originally Posted by Starteur View Post
Anyone about the diff plates?
Does anybody know the answer???????
Do 417 diff plates fit the FF03 alu outdrives?
Ride it like you stole it!!!!!!
Tamiya TRF417V5 SEDAN Racer - Tamiya 416X VTA Racer - Tamiya TRF 416X USGT Racer -Tamiya M05 V2 PRO Racer.
Starteur is offline   Reply With Quote
Old 01-04-2012, 08:08 PM   #2351
Airflow's Avatar
Hi, I have the Pro version and just want to know how can you equalize the
spring rates of the front and rear? Seems that the front's spring rate is harder
than the rear, too hard for my liking. If I use a softer springs on the front, it'll
sit lower which forces me to adjust the shock collars to regain my desired ride
height which then leads to a harder spring rate again. I wanted it to be a
"little" hard not so hard like the stock that there's very little suspension
travel. On side note, if I use the aluminum IFS rocker arm, will it yield better
or smoother suspension? Im starting to hate the IFS specially on this kit.
Old 01-04-2012, 09:07 PM   #2352
If you adjust the pushrods, won't that raise/lower ride height? That way you won't be messing with shock collar preload. That's how I adjust on the TA06. Just make sure you keep the pushrods the same length.
Old 01-04-2012, 09:12 PM   #2353
superspeed's Avatar
They're running silver can at TCS instead of BL? Wow.
superspeed is offline   Reply With Quote
Old 01-04-2012, 09:14 PM   #2354
superspeed's Avatar
stiffer spring on the back
Old 01-04-2012, 11:45 PM   #2355
Airflow's Avatar
Stock rear spring rate is ok.
Tamiya Championship Series Neil Rabara Racing Forum 21025 Yesterday 02:38 PM
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5789 04-27-2017 10:11 PM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 724 04-03-2017 12:43 PM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 11:28 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
