Like Tree23Likes
Old 12-13-2011, 06:56 AM   #2326
NiMo's Avatar
Originally Posted by Airflow View Post
Ok thanks. So 13.5 brushless will be more forgiving you think? Ill just gear up higher for speed?
Anyway, what Tamiya shell can I use to achieve 245mm (medium setting) wheelbase?
HPI do a 240mm Wb Peugeot 106 GTI (#7241), not sure if this has enough clearance at front though for motor ?
NiMo is offline   Reply With Quote
Old 12-17-2011, 01:09 PM   #2327
Lightbulb
Hi all,
I have the non-pro ff03. I want softer springs to replace the stock silver ones. Can somebody tell me how hard the stock silver ones are compared to other brands?
BenjaminX2 is offline   Reply With Quote
Old 12-22-2011, 03:37 AM   #2328
Hi All.
I recently installed the solid axle from 3 Racing and it is awesome!! Just one problem, the cups that hold the dog bones are noticibly shorter that the stock diff. Thus the dog bones fall out of the cup, causing damage.
My question, does tamiya make a 52mm (or there abouts) dog bone/drive shaft? I'm looking around, but the longer dog bones have bigger 'balls' on the end compared to the stock items and don't fit.
Cheers guys - I look forward to your help!
Davo.
Dave5290 is offline   Reply With Quote
Old 12-22-2011, 03:40 AM   #2329
Originally Posted by Dave5290 View Post
Hi All.
Davo.
which universal do you have at the moment?
Tammy does 42,44,46 and 48mm bones
The 52 your referring to are xray, and i believe are measured differently.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 12-22-2011, 11:43 AM   #2330
Thanks for your reply Besercoe.
I currently use the 47mm dog bones that came in the kit (FF03 Pro) which are the same as the ones used in the TA05.
I'm not too fussed about which brand I use - I just want this car to go
I've had it since august and have only put half a battery pack through it - had issue after issue - It's a great kit, just having bad luck
Old 12-22-2011, 12:22 PM   #2331
Sorry missed the dog bone part. Just get a set of universals, 44mm will fit well. Best option is 3racing or spec r
Old 12-22-2011, 02:11 PM   #2332
How big is the performance plus when using sway bars (stabilizers)?
/B
Old 12-23-2011, 12:54 PM   #2333
Thanks for the advise man. I'm currently considering these : http://www.ebay.com.au/itm/220882772...84.m1423.l2649
I know they are 2mm longer than the 44mm you suggested, but I'm hoping that will be fine as I currently have about 2mm worth of packing at either end of the dogbone at the moment ... worse case, my TA05 gets a pair of uni's
Old 12-23-2011, 06:37 PM   #2334
Starteur's Avatar
Why in the manual they say to put 3/32 balls in the diff and when you look at the hop-ups they sell you 3mm balls?????
So I know that I will use black gears, ceramic balls, trf201 trust bearings with ceramic balls and alu outdrives.
I just need to know the size of the diff balls, and do 417 diff plates fit the FF03 diff?
Best regards
Ride it like you stole it!!!!!!
Tamiya TRF417V5 SEDAN Racer - Tamiya 416X VTA Racer - Tamiya TRF 416X USGT Racer -Tamiya M05 V2 PRO Racer.
Starteur is offline   Reply With Quote
Old 12-24-2011, 12:29 AM   #2335
Best regards
This car uses 3/32" balls, a tiny bit smaller then 2,4mm. I'm not certain about the diff plates. I use the 3racing diff halves and they use d shaped diff plates. The balls run very close towards the outer edge.
Old 12-26-2011, 05:59 AM   #2336
Starteur's Avatar
Anyone about the diff plates?
Old 12-27-2011, 01:35 AM   #2337
Airflow's Avatar
Hi, what protoform shell can I use with FF03?
Airflow is offline   Reply With Quote
Old 12-27-2011, 06:01 AM   #2338
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
unfortunately, Protoform doesn't make 190mm FWD-specific bodies (yet?). So far your choices would be Tamiya and ABC. Not sure if HPI/HB or Ride makes bodies for FWD as well...
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 12-27-2011, 05:10 PM   #2339
Airflow's Avatar
Ok thanks for the reply. Having problems with Civic shell, I cant lower it as much as I want. I might change to something bigger but FWD models.
Old 12-27-2011, 05:54 PM   #2340
alana07's Avatar
Trader Rating: 52 (100%+)
Send a message via MSN to alana07
Mazda Sp 6 fits nicely, but you do need to trim some bits off the foam bumper though.
没有最好,只有更好!!!
alana07 is offline   Reply With Quote
Tamiya Championship Series Neil Rabara Racing Forum 21026 Yesterday 08:50 AM
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5789 04-27-2017 10:11 PM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 724 04-03-2017 12:43 PM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 11:28 AM
