Like Tree39Likes
Old 11-08-2011, 08:34 PM   #2311
Alfonso_R's Avatar
Send a message via Yahoo to Alfonso_R
I have a question for the FF guys.
I am planning to run FF next year for the TAC, will it be cheaper to get the pro kit or just the regular kit? and what would be the most important parts for the car? Thanks !
Alfonso_R is offline   Reply With Quote
Old 11-08-2011, 08:52 PM   #2312
clittle's Avatar
The dampers/suspension alone make the Pro kit worth it I feel.
Latest is a Tamiya TB04 Pro..... Love it!!!
Aussie in Japan!
clittle is offline   Reply With Quote
Old 11-08-2011, 08:54 PM   #2313
Airflow's Avatar
What I meant was if the Ballistic's solder tabs would hit the motor stay (stock plastic or carbon motor stay).
Airflow is offline   Reply With Quote
Old 11-08-2011, 10:39 PM   #2314
maxepower's Avatar
Talking Ballistic motor in FF03!
The carbon motor stay will give you more room but the stock plastic ones will work also, the motor will be mounted so the tabs are at an angle and you'll solder the wires facing the inward rather than the normally facing outward from the motor.You will have to use almost all the wire provided and a long sensor wire to reach. Other than that everything will mount nice!
Just my 2$
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 11-09-2011, 09:06 PM   #2315
Airflow's Avatar
Got it. Thanks bro!
Old 11-16-2011, 08:11 PM   #2316
Airflow's Avatar
Hi, how much wheel offset do I need on the FF03 Pro if Im going to use Tamiya CR-Z, Civic or Integra shells?
Will zero offset be enough?
Old 11-16-2011, 09:22 PM   #2317
clittle's Avatar
I use zero offset. Seems to work ok for me.
Aussie in Japan!
Old 11-18-2011, 11:20 AM   #2318
The suspension arms are the same ones as in the standard kit, they are not the reinforced hard ones as on a 417.
addicted2blue is offline   Reply With Quote
Old 11-18-2011, 11:50 AM   #2319
SteveM's Avatar
Trader Rating: 140 (100%+)
I think the Pro version is the better value. Upgrades that I recommend are;
- sway bars #54230
- alloy servo mounts (TB03 items)
- Carbon steering link #54261
- Alum spur gear adapter #54234
- Carbon rear damper stay #54258
- Carbon rear stiffener #54264
- Set of CVD (need several parts)
SteveM is offline   Reply With Quote
Old 11-23-2011, 12:14 PM   #2320
For conversion to rally, what's the maximum ride height for the FF03 before binding or driveshafts falling out? Can this be extended by adjusting the shock length, or some other part of the suspension?
Would the 201X slipper clutch fit, perhaps with a 201X layshaft?
colmo is offline   Reply With Quote
Old 12-11-2011, 01:23 PM   #2321
Trader Rating: 15 (100%+)
anyone use a spec-r gear diff? what weight oil? need suggestions for 21.5 or 17.5
swarb is offline   Reply With Quote
Old 12-11-2011, 04:36 PM   #2322
Airflow's Avatar
Questions:
1. Whats the safest (but fast) brushless system I can use on the ff03 pro?
Ill be using this for bashing / drag racing. Im targeting 10.5T. Is it overkill for the gearbox? Ill be upgrading to a reinforced gearbox and TRF201 gears and
probably aluminum diff joints.
2. Im after 5.5:1 or below gear ratio. Does Tamiya make spurs and pinions for this ratio? The largest Tamiya pinion Ive seen is 29T, I think Ill be needing 33T.
3. Can I use TA06 gear diff? I dont have access to Spec R stuffs.
Old 12-12-2011, 06:30 PM   #2323
Railroader's Avatar
Selling my FF03 Pro with a lot of upgrades. I just don't have a class to run it in where I live and I don't have the room for another shelf queen.
There's a few more days left in the auction.
I hate to see it go, but it will help fund the purchase of a 417 for USGT racing.
http://www.ebay.com/itm/180772714201...#ht_550wt_1413
Railroader is offline   Reply With Quote
Old 12-12-2011, 07:59 PM   #2324
most of the height of "rally" cars is from the tires. Get longer drive shafts. If you want off road car, buy a off road car. Don't expect much clearance without extended shock shafts or hitting the droop limit.
need suggestions.
Questions:
1.10.5 is fine, some people have run it. Don't expect gears, or diff to last long. And don't expect any traction from a launch.
2. buy aftermarket gears.
3. no, not without major modification, go back 5-10pages and read up.
Old 12-12-2011, 09:17 PM   #2325
Airflow's Avatar
Ok thanks. So 13.5 brushless will be more forgiving you think? Ill just gear up higher for speed?
Anyway, what Tamiya shell can I use to achieve 245mm (medium setting) wheelbase?
Tamiya Championship Series Neil Rabara Racing Forum 21198 10-19-2017 06:51 PM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 732 10-12-2017 02:34 PM
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5806 09-22-2017 03:06 PM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 11:28 AM
