Tamiya FF03
#2296
i have run with 13.5t boosted.
start with the box setup, + med sway bars in the front and soft in the rear
only thing i changed from there on mine is 600oil in the front shocks
#2297
October 12th release
#2299
#2300
#2302
New body!
Someone who works at Tamiya corporate had one at the track Saturday and put a Red Bull theme paints scheme. it looked and appeared to handle very well. So, this may be the new body of choice. The majority of the FF03's are running the Integra body, so that getting old, oh yeah I'm running one also. I just might have to get one also!
#2305
does any body know the wheelbase on the new scirocco body, is it the regular 257mm or is it shorter, thanks for the info
#2306
Hey justed wanted to thank everyone on this thread that chimed in with information. I just ran my ff-03 at tq rc on saturday for the first time. I was all over the place I have a lot of tuning and practice ahead of me.
#2307
#2308
Taken from Tamiya's own site:
In 2011, 24-hour race held at the Nurburgring circuit in Germany known as the toughest course in the world - shake things up - the body of the coupe is FF Rorufu, CNG alternative fuel classes using natural gas as fuel Volkswagen Scirocco GT24-played victories electric radio control car assembly kit of CNG. While keeping the image of the car market is characterized by low silhouette to a crawl the earth, the air outlet is provided in the hood, the figure reproduces the rich feel of polycarbonate finish, such as with the more militant lip spoiler. Door mirrors and rear wing increases the sense of scale available in separate parts. 。 The body sides and car number "R" logo, sticker provided by the sponsor mark. High-performance front-wheel drive chassis is the same vehicle FF-03 was adopted.
Good chassis balance - battery upright, FF-FF adopted the lower deck of the bathtub and upright slim battery for running the largest feature - 03-03 adopted. Servo to the right side of the battery, ESC and receiver placed on the left side, left to optimize the weight balance. Such an arrangement of the traction motor and drive wheels at the front wheel well mounted on the chassis front. 。 In a compact gearbox was also equipped with ball differentials. 4-wheel double wishbone suspension features CVA oil dampers mounted. 。 Using the short reversible suspension arms, front inboard type damper is operated by a push rod and rocker arm. In addition, the bridge connecting parts are also equipped with stabilizer rocker arm rotating shaft holder. 10-spoke wheels of the gun metal color, a combination of wide racing slick tires 24mm, enjoy a unique ride Rashii FF.
Height: 134mm ● Wheelbase: 257mm Width: 443mm, 188mm, Specifications】 ● Length (Select three types of 257,245,233 mm) ● Motor Drive system = Front Wheel Drive = 157mm ● Frame: Bathtub type ● ● Tread front and rear = 6.80:1 ● 540 Type 24mm/64mm ● Gear Ratio width / diameter both front and rear double wishbone Damper = CVA Oil Damper Super Mini ● ● ● Suspension: 4-wheel tire = Diff = ball differential equation ● Steering tie rod = 3 division ● With the motor speed controller = ESC specification (optional)
#2310
540 can size fits
