Like Tree22Likes
Old 09-17-2011, 10:45 AM   #2281
Giorgio's Avatar
The front CVD that goes on the 415-416 will fit on the FF03?
https://www.facebook.com/FenixRacing.it/
www.fenixracingshop.com
Giorgio is offline   Reply With Quote
Old 09-17-2011, 12:59 PM   #2282
FFO3EG's Avatar
Hey guys im trying to set up my FF-03 for a race tomorrow and it seems under a somewhat hard turn after cutting off the accelerator the back end wants to swing around and i basically loose my control of the car for a sec. Is it possible to fix this with a stiffer sway bar? (using blue atm) or compressing my shocks? or go the other way with it?
Current: CTR FF-03
FFO3EG is offline   Reply With Quote
Old 09-17-2011, 02:12 PM   #2283
C5R01's Avatar
Send a message via Yahoo to C5R01
Straighten the rear shocks up 1st. That should help.
Current Cars:
Tamiya Garage:TB03; TA05V2-IFS; 414X #60;F104 V2;TA03r-s:TA03F:TA03R: FF01: FF03: M01: M03: M06: 1/14 Mercedes Semi truck- w/Reefer trailer ( fully functional): Tamiya Juggernaut 4X4X4, Tamiya RC Freightliner Cascadia Evo.; Honda City Turbo WR-02C; TRF102 F1
OTHERS:Kyosho 1/8th scale nitro Corvette C6R: Yokomo GT4 nitro, Slash 2WD,TA SCm5
C5R01 is offline   Reply With Quote
Old 09-17-2011, 03:35 PM   #2284
clittle's Avatar
Initially I found running a softer tyre on the rear seemed to calm it down some, and then (contrary to the advice above I know) I layed down the shocks when going back to running the same tyres as up front and now it's pretty planted.
I guess you could also limit the amount of rear droop, that would limit the amount of weight going forward and keep some of the weight on the rear and save some of that precious grip.
Someone also told me that when turning like that, always try to keep some throttle on (half or part throttle) rather than neutral. I guess it's up to personal preference with that one.
Good Luck with your race.
Latest is a Tamiya TB04 Pro..... Love it!!!
Aussie in Japan!
clittle is offline   Reply With Quote
Old 09-25-2011, 07:01 PM   #2285
alana07's Avatar
Trader Rating: 52 (100%+)
Send a message via MSN to alana07
is there a day and night's difference in handling between the carbon composite tub vs the kit's plastic tub chassis? is the carbon tub chassis a must-have or nice-to-have part, running on a asphalt track surface...
没有最好,只有更好!!!
alana07 is offline   Reply With Quote
Old 09-25-2011, 07:41 PM   #2286
FFO3EG's Avatar
I'm kinda wondering the same, just got done ordering my knuckles, and new front drive shafts and crap. I want to lighten the car up a bit and make it more stiff.
Current: CTR FF-03
Old 09-26-2011, 08:48 AM   #2287
Core Creations's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to Core Creations
If anyone is looking... Tamiya FF03 Pro Hopped up TCS ready! TRF
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 09-29-2011, 05:41 AM   #2288
I asked this before and no one responded so I assume no one has tried it!
One of our fellow drivers here tried it and reported an improvement in traction.
I also noticed that the shops are not moving stock on this part so can't be a concern for most drivers.
Anyone tried using the carbon steering link upgrade from Tamiya?
Is it worth it?
mr lee is offline   Reply With Quote
Old 09-29-2011, 05:59 AM   #2289
SteveM's Avatar
Trader Rating: 128 (100%+)
Is it worth it?
I'm using the Tamiya carbon steering link kit and found that it greatly reduced the slop that the stock components have. It's nice and light and works great.
SteveM is online now   Reply With Quote
Old 09-29-2011, 08:49 AM   #2290
rtypec's Avatar
It's a not day and night difference and to be quite honest, I did not notice anything when I installed all of the carbon reinforced parts on my car. Maybe it felt a little more precise???
rtypec is offline   Reply With Quote
Old 09-29-2011, 08:58 AM   #2291
NiMo's Avatar
Someones coming out to play again.
(sorry about blurry pic)
Fully waterproofed ready for outdoor winter series.
HPI Firebolt - Cheap Ansmann waterproof ESC - Stumpy 3800 LiPo - Unbelted Tyres.
NiMo is offline   Reply With Quote
Old 09-29-2011, 06:54 PM   #2292
alana07's Avatar
I asked this before and no one responded so I assume no one has tried it!?
its my 2nd time asking that question....
没有最好,只有更好!!!
Old 09-29-2011, 06:56 PM   #2293
alana07's Avatar
thanks, your answer just helped me save $40,,,,
没有最好,只有更好!!!
Old 09-29-2011, 07:52 PM   #2294
FFO3EG's Avatar
I just installed the lightweight dog bones and axles, spur gear, totally noticed better turning response and power output, next is carbon tray. Oh I have the Lightweight aluminum steering link kit, it has some slop and it's annoying.
If anyone wants part numbers that work with the stock diff I can msg them.
Current: CTR FF-03
Old 10-05-2011, 11:02 AM   #2295
Trader Rating: 33 (100%+)
Hello all. Has anyone run their FF03 Pro with a boosted 17.5 on asphalt with decent results? If so can you shoot me a PM with the setup you used I am trying to find a starting point to work off of. Thanks in advance for any assistance you guys can offer.
Blue Diamond Park
Align 500 electric heli, Blade 300X and 130X
Pete720 is offline   Reply With Quote
Tamiya Championship Series Neil Rabara Racing Forum 20961 03-28-2017 11:31 PM
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5782 03-26-2017 03:14 AM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 723 02-09-2017 08:16 AM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 11:28 AM
