Like Tree24Likes
Old 09-09-2011, 01:08 PM   #2266
Originally Posted by syrss View Post
Has anyone tried the Hobbywing 13T EZRUN 3650M (380 sized) series motor?
Does it have enough torque and power to pull ff03 versus the true 540 sized motors?
I have run the motor twice already, seems to run a little hot with the stock gearing.
Just want to get some general inputs from the experts.
TIA,
Ron
I run the 9turn together with the 35A ESC. The timing set on 3.75deg, punch 5 from 9. Gearing: 30 pinion and 80 spur dp48.
My indoor and outdoor track is rather tight, so a lot of accelerating. Temps are fine (somewhat warm), but I did cut the "grill"of the car for some airflow.
The stock plastic diff halves WILL melt. Don't even try, you will ruin diff-balls and what not.
B.
BenjaminX2 is offline   Reply With Quote
Old 09-09-2011, 05:13 PM   #2267
clittle's Avatar
B.
May I ask what body you are running? and has the grill affected the downforce or feeling of the car at all?
I have a similar problem with really high temps and with gearing can get it down but I'd like to see how some more airflow would help.
Cheers.
Latest is a Tamiya TB04 Pro..... Love it!!!
Aussie in Japan!
clittle is offline   Reply With Quote
Old 09-11-2011, 08:13 PM   #2268
FFO3EG's Avatar
Hey guys i was wondering what Universal shaft set to purchase for my FF-03, i noticed that my drive shaft was rubbing on the front knuckles of my car.
FFO3EG is offline   Reply With Quote
Old 09-11-2011, 09:23 PM   #2269
clittle's Avatar
I've got the Aluminum 46mm Swing Shaft (53724) and the TB03 Wheel Axle (54076). I think you can also get the 44mm Swing Shaft from what I've read.
Also the TRF417 Wheel Axle set uses a slightly different way of clamping the pin into position which I believe is better.
Basically, I found most of my options parts from here. http://www.petitrc.com/reglages/tami...010/index.html
Cheers
Aussie in Japan!
Old 09-12-2011, 10:18 AM   #2270
FFO3EG's Avatar
Thanks a ton! i've been out of the R/C car scene for a long time, tryin to learn about all the new stuff and upgrades.
Do those swing shafts come with a Pin to place into the wheel hub?
Current: CTR FF-03
Old 09-12-2011, 05:51 PM   #2271
clittle's Avatar
Sorry, no. The shafts are just the shafts. If you got TB03 route, then you'll have to get the pins and "holder" (little black tubes that hold the pin and grub screw" separately (There's a part number for it somewhere but I'm sorry I don't have it, I think it's a common part for most of the tamiya universal swing shafts)
If you go the 417 route, I believe the clip and pin are also a separate buy, but don't quote me on that
Cheers
Aussie in Japan!
Old 09-13-2011, 03:18 AM   #2272
Cheers.
I run the stock civic body (eg or ek ) ) and I didn't notice a difference. I might lack experience to notice, because the last RC I rode 5 years ago was a 1/8 nitro buggy.
I did notice a change in tires/setup .
In general, be certain that your transmission isn't binding. My diff/gear case had rather bad tolerances.
B.
p.s.
That hottest day I drove, was like 30 degree Celsius. 86F.
Old 09-13-2011, 03:47 AM   #2273
kentech's Avatar
58505 VW Scirocco GT24-CNG (FF-03 Chassis) Tamiya Release Date : Nov
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 09-13-2011, 03:50 AM   #2274
cannon's Avatar
Trader Rating: 35 (100%+)
Originally Posted by kentech View Post
58505 VW Sirocco GT24-CNG (FF-03 Chassis) Tamiya Release Date : Nov
Awesome ....
Wish they would release my Renault Megane RS250
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 09-13-2011, 06:39 AM   #2275
clittle's Avatar
B.
p.s.
Thanks for that. I'm currently running the Porsche GT3 body and on a 35 deg day the temps were 90 ish (celcius). A little bit on the high side I think.
Aussie in Japan!
Old 09-13-2011, 05:02 PM   #2276
FFO3EG's Avatar
Thanks for the help, ill try to find the Part# for the grub screws and such.
Also im starting to hear some light grinding when i let off the accelerator, wondering if its the Diff.
Current: CTR FF-03
Old 09-13-2011, 07:39 PM   #2277
clittle's Avatar
Grinding is never good How's the mesh between your pinion and spur gears?
Aussie in Japan!
Old 09-14-2011, 10:46 AM   #2278
FFO3EG's Avatar
It is sitting with enough clearance to grab without danger of slipping, i wanted to take the Diff box off and check it out but one of the screws stripped out from the bottom of the car kissing the ground a bit, so i guess i might just get a spec R gearbox or rebuild the Tamiya one with new parts and upgraded idler,Diff, and spur gear.
Im sure im just being paranoid, i build car engines for my K-series so when i hear a noise i go bat shit crazy.
Current: CTR FF-03
Old 09-15-2011, 05:40 PM   #2279
clittle's Avatar
Default Stipped it down and found a problem
I've just stripped down my FF03 for some maintenance. I've just noticed that I tend to be splitting my tires around the wall. Where the tire is glued to the rim it's ok, but just above there both my front tyres have split. I'm running a 21.5 with Hobbywing 120A Xerun system. I wouldn't have thought I was creating that much drive to split the tyres..... Has anyone else had this trouble and any ideas on how I can not have it happen again?
Aussie in Japan!
Old 09-17-2011, 10:42 AM   #2280
I have the same problem with a set of LRP VTEC 27 (x, or something) wheels. I glue them after every run
With the LRP VTEC CPX (low height type, carpet) I do not have this problem.
Also, I do not encounter the problem with my sweep 32 tires, mounted on hard Robitronic dish wheels and I do have more grip with these!
Seems to me it depends on the tires.
B.
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5805 Today 10:30 PM
Tamiya Championship Series Neil Rabara Racing Forum 21185 09-05-2017 07:20 PM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 730 08-15-2017 08:06 PM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 11:28 AM
