Like Tree23Likes
Old 08-01-2011, 02:59 AM   #2236
No one ever tried the carbon reinforced deck
mr lee is offline   Reply With Quote
Old 08-04-2011, 09:26 AM   #2237
Default spec R diff oil question
Is everyone putting in 100K or putty in their SpecR gear diff? Does that give you enough turn in?
TIA,
Ron
syrss is offline   Reply With Quote
Old 08-08-2011, 03:03 PM   #2238
TIA,
Ron
Me... but before I need to restore the rear suspensions
Tamiya: Mad Cap, 1&1/2 Ta02, Manta Ray, Grasshopper re-re, Subaru Brat re-re, Mitsubishi Pajero, Stadium Blitzer 2010, FF03 (Full ballraced, TRF Fluorine Coated Damper, Universals, Alum Spur Gear Mount, Carbon Motor Stay, Alum Wheel Hub Clamp, Hi-Torque Servo Saver, Hi-Torque Servo Saver Horn Alum Black, RcScrewz Stainless Steel Screws Kit, Spec-R Gear Box, Spec-R Gear Diff)
jeekelemental is offline   Reply With Quote
Old 08-08-2011, 04:38 PM   #2239
tried 300k, got little understeering into the corner, but the car was very easy to drive.
havent tried 100k but i think it will work just fine, but it will make the wheels spin faster so you will probably not be as fast out of the corners as with 300k
Xray T4`16 - Hobbywing - Highest - Sanwa - Gens Ace
Xray XB2 - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 08-08-2011, 06:20 PM   #2240
TryHard's Avatar
TIA,
Ron
I've used putty and 500K. Not as much steering into the turn, but a lot better drive out than the ball diff... and having said that, i found it a lot easier to play the throttle on the way into the turn to get it to steer with the gear diff.
Try it and see... and check the laptimes
Old 08-10-2011, 01:01 AM   #2241
Trader Rating: 44 (100%+)
thinking of getting an FF03 pro more so for playing than racing but I am sure I will race it from time to time..what do you guys suggest for hop-ups one thing I know for sure I will be getting is the SpecR diff
T5M 7.5
22 3.0 7.5
SickWitiTRacing(Jayson)
NitroLuver is offline   Reply With Quote
Old 08-10-2011, 02:21 AM   #2242
rollbar set is the #1 option and caster bock in graphite plastic #2
thats the most important upgrades if you ask me. then you might want to change the plastic suspension blocks to aluminium when the plastic gets worn out
Old 08-10-2011, 02:46 AM   #2243
peter p's Avatar
Hi does anyone know if the diff in a ff03 will fit in a TA03 ? would be a good change from the lead weight diffs in the TA03
peter p is offline   Reply With Quote
Old 08-10-2011, 08:03 AM   #2244
TAMAK's Avatar
Trader Rating: 28 (100%+)
Selling my FFO3: Tamiya FF03 Pro / Extras!!!
TAMAK is offline   Reply With Quote
Old 08-10-2011, 01:26 PM   #2245
Ok I put 60K Associated diff oil in my SpecR gear diff and it's almost a spool (when I turn one wheel, the other wheel spins the same direction).
My newbie question of the day is how can I create more turn in without changing the gear diff oil to a lower weight?
TIA,
Ron
Old 08-10-2011, 01:34 PM   #2246
Second newbie question of the day, I am using the following parts to build universals:
Tamiya Cross Joints For Universal Shaft Set 4pcs. 53500
Tamiya 46mm Swing Shaft 53724
Tamiya TB-03 Wheel Axles 54076
Will the 46mm swing shaft fit the SpecR gear diff? Does anyone know?
TIA,
Ron
Old 08-10-2011, 08:26 PM   #2247
TryHard's Avatar
TIA,
Ron
Yes, fits' fine (although I do use a slightly wider frond end than kit)
Old 08-14-2011, 07:19 AM   #2248
Do any diff rings other than the FF03 ,TRF201 fit the plastic or aluminum outdrives?
Rd/Rz is offline   Reply With Quote
Old 08-14-2011, 07:26 AM   #2249
t4m1y4niac's Avatar
TIA,
Ron
46mm swing shaft will fit nicely with the specr gear diff.
Also you can use trf417 wheel axle and trf417 cross joint
SABRE S4 by TOP RACING....
t4m1y4niac is offline   Reply With Quote
Old 08-14-2011, 10:22 PM   #2250
dawin2122's Avatar
Hi guys please recomended me a brushless combo for a ff03 thanks
dawin2122 is offline   Reply With Quote
Tamiya Championship Series Neil Rabara Racing Forum 21025 Yesterday 02:38 PM
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5789 04-27-2017 10:11 PM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 724 04-03-2017 12:43 PM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 11:28 AM
