Old 05-15-2011, 03:52 PM   #2131
ready for the track!
Tamiya FF03 Pro
Xray XII Link
3 Racing F1-09
Hatebreed is offline   Reply With Quote
Old 05-15-2011, 04:18 PM   #2132
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by The Big Wig View Post
What Ed said.
The pushrod is turned to adjust ride hight and NOT the spring collar. If you adjust the ride hight with the collar. The rocker will move thus changing the progressivenes and springrate also.
So you're saying that as the the suspension cycles, the progressiveness and spring rate change? The rocker moves through the travel of the shock, and you're saying changing the rocker position changes these values, so the suspension has to be either progressive or digressive...
I'm only asking since most of the advice I have heard about IFS is to find a pushrod length that works and stick with it. I'm interested to hear your thoughts.
Old 05-15-2011, 04:29 PM   #2133
F N CUDA's Avatar
Trader Rating: 30 (100%+)
I'm curious too.
Rodzilla's setup sheets show the link to be set at 12.5mm and ride height at 5mm.
Doesn't look like the link is being changed to change ride height after spring rate changes.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 05-21-2011, 06:56 AM   #2134
car tested, cant stop smiling! easily the funniest and best car i have driven in my 20years in rc!
amazing handling and soo easy to drive!!!
only downside was the slipping balldiff, have ordered a geardiff
what oil should i use in the gear diff?
Tamiya FF03 Pro
Xray XII Link
3 Racing F1-09
Old 05-24-2011, 01:46 AM   #2135
Hi all,
I'm new to this forum and Tamiya. I ordered the car (civic) and plan to color the rims.
Can I dye these with clothing dye? I read years ago that some Tamiya rims warp in the boiling water.
Benjamin
BenjaminX2 is offline   Reply With Quote
Old 05-30-2011, 03:03 AM   #2136
kentech's Avatar
TA06 gear diffs. Rear diff should fit the FF-03.
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 05-30-2011, 07:59 AM   #2137
Hope Tamiya recognize this as a hop up part for the FF so it can be used in TC events!
mr lee is offline   Reply With Quote
Old 05-30-2011, 08:38 AM   #2138
maxepower's Avatar
Exclamation FF03 GEAR DIFF
I mentioned this to Fred Medal about using the TA06 gear diff as a legal hopup for TCS on the FF03 and he had no problem with it. He also said there will be a gear diff for the FF03 coming out at some point, just not sure when. But, when it does I'm sure it will be identical to the TA06 rear gear diff~
Just my2$
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EXO-6,TA-07,TRF419,EVO-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 05-30-2011, 09:25 AM   #2139
May ok where you race but ours are sticky! It basically has to be on the FF03 parts list of the local supplier before it is allowed.
....but I am sure it is only a matter of time
Old 05-30-2011, 11:58 AM   #2140
Anyone know the size of the blades to use with Spec-R geardiff. is it 3mm blades or 3.5mm blades
<Awesomatix A700 EvoII><Highest><Sanwa><Muchmore><Fantom>
<Awesomatix A800a><Hitec><Sanwa><Muchmore><Fantom>
<VBC LightningF><Hitec><Sanwa><Muchmore><Skyrc>
<=Team Autopartner=>
Gillblade is offline   Reply With Quote
Old 06-02-2011, 03:17 AM   #2141
PizzaDude's Avatar
I really hope it will.
However it also looks like the gearcase used on the ta06 is a bit different as opposed to the ff03's.
It seems to lean a bit to the spec-r gearcase (for ff03).
If anyone tries this please post here your outcome.
PizzaDude is offline   Reply With Quote
Old 06-03-2011, 01:22 AM   #2142
PizzaDude's Avatar
Are the internal gears in the Spec-R metall and are they interchangable with Tamiya's plastic ones?
Old 06-03-2011, 01:31 AM   #2143
rc_square24's Avatar
The SpecR is not metal, and don't think anyone has a Tamiya one yet.
rc_square24 is offline   Reply With Quote
Old 06-03-2011, 01:42 AM   #2144
PizzaDude's Avatar
Thanks.
Well the ta06s are being built right now (ta06 thread).
So maybe some FF-fan also bought the ta06, hence my Q.
Hope to get the fitting (stock ff03 case) answered as well.
Old 06-03-2011, 02:19 PM   #2145
Does anyone know if the 417 diff rings will fit on the tamiya aluminum diff joints for the ff03?
The 417 has 2 flat spots on the rings, but I cant tell if the ff03 alum diff has 2 notches or not (from pics) and if the diameter fits.
Tamiya Championship Series Neil Rabara Racing Forum 20851 Yesterday 10:21 PM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 711 01-08-2017 09:27 AM
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5774 09-23-2016 10:49 PM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 12:28 PM
SEO by vBSEO 3.5.0
