Like Tree24Likes
Old 05-03-2011, 12:30 PM   #2116
skadoosh's Avatar
Can you use this car for drifting or do you really need a 4wd like the TA05 or TB03D?
yesterday is history, tomorrow is a mystery, but today is a gift. That is why it is called the "present."
skadoosh is offline   Reply With Quote
Old 05-03-2011, 02:50 PM   #2117
academygaz's Avatar
Nope, you need 4wd to push the back out as the front pulls.
Quote, Leodis, 2007: ''I've been shopping online for 9 years and the only charge I've ever had to dispute with my credit card company was from TiR. Congratulations TiR. Even porn sites are more ethical than your company!''
RC cars - I haz sum.
academygaz is offline   Reply With Quote
Old 05-03-2011, 04:22 PM   #2118
The Big Wig's Avatar
If you'd have a handbrake you could do this but no. No drifting.
The Big Wig is offline   Reply With Quote
Old 05-03-2011, 05:51 PM   #2119
clittle's Avatar
Default Inboard Suspension
The FF03 is my first in-board suspension car. I've been looking at the front suspension for tuning opportunities/possibilities.
Calling all IFS experts!!!
On "normal" suspension cars, I can lay down or stand up the shocks depending on the feeling I require. I can't see this kind of option with the in-board shocks.
Changing the lower position of the shock seems possible.
Does changing the length of the link between the lower suspension arm and rocker make a difference? If so, what kind of difference?
I'll test this the next time on at the track, but I'm just trying to do a little arm-chair engineering.
Latest is a Tamiya TB04 Pro..... Love it!!!
Aussie in Japan!
clittle is offline   Reply With Quote
Old 05-03-2011, 06:00 PM   #2120
TryHard's Avatar
Changing the bottom position has a similar effect (may need to re-adjust the link), whilst adding shims to the rocker is similar to moving the top positon. At least, that's how I understand it!
HiH
Ed
Old 05-03-2011, 06:11 PM   #2121
What Ed said.
The pushrod is turned to adjust ride hight and NOT the spring collar. If you adjust the ride hight with the collar. The rocker will move thus changing the progressivenes and springrate also.
Old 05-04-2011, 08:59 AM   #2122
....the manual also shows the effect of the spacers on the rocker arms....
page 14 in both the pro and standard FF03 manuals
mr lee is offline   Reply With Quote
Old 05-04-2011, 03:55 PM   #2123
clittle's Avatar
hahahaha cheers.
I guess I should read the manual with more detail. That's got the question answered.
Aussie in Japan!
Old 05-06-2011, 02:51 AM   #2124
kentech's Avatar
Still love the TOMS EXIV body
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 05-06-2011, 07:39 AM   #2125
superspeed's Avatar
I had this Tom's Exiv on FF01.
superspeed is offline   Reply With Quote
Old 05-06-2011, 07:41 AM   #2126
superspeed's Avatar
@kentech
I think Tamiya re-release the Tom's Exiv body but I don't remember if there was a decal set with the body.
Old 05-07-2011, 11:37 PM   #2127
clittle's Avatar
Had some more track time with my FF03. Since running it the last time I've added sway-bars and the carbon rear shock towers. I've also put in a 21.5 turn with boost and turbo ESC. The car has become, for want of a better work, AMAZING. Just need to perhaps change the FDR as the motor was a tad hot.
Aussie in Japan!
Old 05-09-2011, 10:18 PM   #2128
my ff03 pro, only changes i have made is alu spurgear mount, alu outdrives, reinforced gears in the transmission and cvd`s
just need to mount the esc and do the wiring and its ready to go!
Tamiya FF03 Pro
Xray XII Link
3 Racing F1-09
Hatebreed is offline   Reply With Quote
Old 05-14-2011, 05:07 PM   #2129
Misiek's Avatar
I just wanted to find out whats the value of a used FF03 roller (not a pro version!) with a good Honda Civic body
________________________________________________________
On paternity leave...
Misiek is offline   Reply With Quote
Old 05-15-2011, 01:51 AM   #2130
alana07's Avatar
Trader Rating: 52 (100%+)
Send a message via MSN to alana07
has anyone encountered any handling irregularities using the stock plastic tub chassis from the FF03 pro kit? is the carbon tub chassis and/or 3racing carbon chassis conv kit nice to haves or must have items? thanks....
没有最好,只有更好!!!
alana07 is offline   Reply With Quote
Tamiya Championship Series Neil Rabara Racing Forum 21085 07-20-2017 05:34 PM
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5790 06-17-2017 05:27 PM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 724 04-03-2017 12:43 PM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 11:28 AM
