Like Tree21Likes
Old 03-28-2011, 03:40 AM   #2056
SteveM's Avatar
Trader Rating: 128 (100%+)
Originally Posted by cartix View Post
Nice job Steve.
Body was painted by my friend Dave at Bodywerx. He actually did two identical bodies like this for me.
http://www.bodywerx.net/
SteveM is offline   Reply With Quote
Old 03-30-2011, 01:15 PM   #2057
rc_square24's Avatar
How does the ff03 fair againt 4wd tcs in the 17.5 class?
rc_square24 is offline   Reply With Quote
Old 03-31-2011, 12:13 AM   #2058
Send a message via AIM to Waco
IMHO I have just completed the Winter Series at Bedworth in the Stock 27T brushed & 17.5 brushless (with Turbo option) & without a doubt the 17.5 is quicker on the straight (I was using 27T brushed)
Since I have stood the shocks upright, there is no more mid corner twitching which I hated & now that I can commit to the corners with little fear of flicking out. On the infield where speed is not quite so important, I actually gained ground as I was able to take the inside lines of some of the corners where the 4 wheel drives were 'pushing'.
The summer series is due to start in 2 weeks & the 17.5 will now be non-turbo & the 21.5 will be turbos/ advanced timing or both (I'll be trying the 21.5), so I'll keep you posted.
Waco is offline   Reply With Quote
Old 03-31-2011, 06:16 AM   #2059
NiMo's Avatar
Haven't run mine for a while, but I have an X12 21.5 and a Tekin RS (not pro), so I may look at getting that put together (as GT is no more at my track).
Will just have to work out which dates dont clash with my club, and when the other half hasn't arranged anything.
NiMo is offline   Reply With Quote
Old 03-31-2011, 07:46 AM   #2060
I finally got to dirve one of these and I am hooked!! anybody have a used one they would part with? Also, is there any real difference between the pro kit and the standard kit in terms of performance?
4x4moneypit is offline   Reply With Quote
Old 03-31-2011, 10:03 AM   #2061
I am selling my 100% upgraded ff03 pro. 100% TCS legal.
Sent you a PM.
http://www.rctech.net/forum/r-c-item...o-vfs-1-a.html
I have a few 'low ball' offers so not sold yet.
Michael Zufelt
It's not how you stand next to your car, it's how you race your car.
http://www.dynamichobbies.com
TheZoof is offline   Reply With Quote
Old 03-31-2011, 12:51 PM   #2062
Sounds great! Hope you (& anyone else out there) can make it...
Old 04-01-2011, 02:31 PM   #2063
Whats a recommended fdr for start with a 380 size 3000kv/13.5T motor on the hobbywing no timing profile?
Old 04-02-2011, 03:03 AM   #2064
Showbiz's Avatar
It have also use 3000kv sp, my FDR is around 5.9, which it could enough for my local track, where the straight is no so important. Howevr I think that it could be better if I push my FDR down to be 5.3 - 5.4. (or might be 5)
Showbiz is offline   Reply With Quote
Old 04-02-2011, 03:31 AM   #2065
Just came back from the track, it's an indoor carpet track med-large size I'd say about 90'.
I started with 5.3 (96/47) and got pretty good speed all around. The car was pushing (under) a lot on infield and my diff rings came loose by the 2nd run.
I use the plastic outdrives, shoo-goo doesn't seem to stick very well on the drives. Any tips?
Thanks.
Old 04-13-2011, 01:34 AM   #2066
kentech's Avatar
To be announced at Shizuoka:
Tungsten Balls for Thrust Bearing (8 pcs)
3/32 inch Ceramic Diff Ball (12 pcs)
FF-03 Carbon Toughened Lower Deck
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 04-13-2011, 01:47 AM   #2067
PizzaDude's Avatar
No geardiff??!!
PizzaDude is offline   Reply With Quote
Old 04-13-2011, 05:27 AM   #2068
Skitee's Avatar
No they can't just re label the Spec-R gear diff this time because you need the Spec-R gear case too.
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 04-13-2011, 06:01 AM   #2069
PizzaDude's Avatar
So they'll offer that as well as a package or a separate option...
Old 04-13-2011, 06:41 AM   #2070
kentech's Avatar
Originally Posted by PizzaDude View Post
No geardiff??!!
TA06 (with same gearbox) to come standard with newly designed gear diffs...
sccchhhh...
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5782 Today 03:14 AM
Tamiya Championship Series Neil Rabara Racing Forum 20952 Yesterday 10:43 AM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 723 02-09-2017 08:16 AM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 11:28 AM
