Like Tree24Likes
Old 03-06-2011, 09:28 AM   #2011
rtypec's Avatar
Default Esso Beams Integra
Here's my recently finished Integra
rtypec is offline   Reply With Quote
Old 03-06-2011, 09:48 AM   #2012
C5R01's Avatar
Send a message via Yahoo to C5R01
nice
Current Cars:
Tamiya Garage:TB03; TA05V2-IFS; 414X #60;F104 V2;TA03r-s:TA03F:TA03R: FF01: FF03: M01: M03: M06: 1/14 Mercedes Semi truck- w/Reefer trailer ( fully functional): Tamiya Juggernaut 4X4X4, Tamiya RC Freightliner Cascadia Evo.; Honda City Turbo WR-02C; TRF102 F1
OTHERS:Kyosho 1/8th scale nitro Corvette C6R: Yokomo GT4 nitro, Slash 2WD,TA SCm5
C5R01 is offline   Reply With Quote
Old 03-06-2011, 10:17 AM   #2013
rtypec's Avatar
Default 1:1
Slightly off topic...nice Vette in your avatar C5R01. Ironically enough, I was out on a Sunday drive this morning and snapped off a pic of my 1:1 scale C6. I know this is a FWD thread so please make an exception
Old 03-06-2011, 11:40 AM   #2014
C5R01's Avatar
This is one of my real racecar paintjobs (designed by me for the dealer I work for). I also own a 94 Z51 6speed coupe.
Current Cars:
Old 03-06-2011, 05:26 PM   #2015
cartix's Avatar
Trader Rating: 33 (100%+)
Nice simple, effective paint jobs on the Integras guys!
Cars and boats, lots!
cartix is offline   Reply With Quote
Old 03-06-2011, 05:47 PM   #2016
C5R01's Avatar
Thanks. A simple paint and decals can make a ordinary carlook like great car.
Current Cars:
Old 03-06-2011, 07:46 PM   #2017
I read in the earlier pages of this thread that due to gear case constraint, there is a limit for how tall a gear you can use i.e. pinion rubbing gear case. So for those of you with the spec-r gear diff. + matching case. Does spec-r address this problem by having a different internal ratio rather than just transferring the originals over?
one-nil is offline   Reply With Quote
Old 03-06-2011, 07:57 PM   #2018
rc_square24's Avatar
They only released the diff itself and no counter gears so the internal ratio will be the same as stock. I think by case you mean the gear cover?
rc_square24 is offline   Reply With Quote
Old 03-07-2011, 02:12 AM   #2019
oldnwise's Avatar
Just leave the pinion/spur cover off and you will have no issue with fitting large pinions. Most high end on-road cars do not have covers over pinions/spurs and if you need to achieve a large rollout then you will need to leave the cover off.
oldnwise is offline   Reply With Quote
Old 03-07-2011, 06:09 AM   #2020
TryHard's Avatar
as we're posting piccies... my Integra as (not) raced at the TITC
Tamiya FF03-titc-2011-part2-005.jpg   Tamiya FF03-titc-2011-part2-009.jpg   Tamiya FF03-titc-2011-part2-010.jpg
Old 03-07-2011, 06:19 AM   #2021
Originally Posted by mr lee View Post
Ok so I have seen people using the integra and Civic VTi bodies thus far.....have also seen the 08 Subaru used as well.
Now is one of the above better in more ways than the other? What is the best all rounder or does it not really matter and all comes down to your setup and driving style?
Does anyone run one of the Tamiya racing wings on the Integra or is the standard one used?
Anyone?
mr lee is offline   Reply With Quote
Old 03-07-2011, 08:16 AM   #2022
mikeygar's Avatar
Trader Rating: 14 (100%+)
if your pinion is really big its a bit difficult to get the meshing correct. can be done but pinion will be slightly offset to spur gear
Manila On-Road RC on Facebook
https://www.facebook.com/ManilaRC
mikeygar is offline   Reply With Quote
Old 03-07-2011, 08:32 AM   #2023
Originally Posted by mikeygar View Post
I used 100k AE oil
With 100k oil it felt like a really tight ball diff. Advantage for me was that I had a little bit of turn in afforded as compared to a spool. Takeoff from standstill was awesome!
Same problem here. The Spec-R gearcase comes with adapters to fit either the original ball diff or the gear diff. Too many philips screws to undo to make my car TCS legal again so I won't be running in our events for awhile hehehe. Had my fill of rebuilding the diff so many times during TITC I'm pretty much sick of it right now hahahaha
You're lucky that your diff stayed ok. Mine was very notchy after every 2 runs. I even put new diff plates on the 2nd day and still became notchy. I've pretty much given up on the Tamiya diff and will join our TCS events again once Tamiya comes out with a geardiff. All in all, I spent more time fixing my FF than my touring car!!!
Also seeing that my times were a second off the A-main guys was very disappointing, am challenged to run FF again next year since I know I could have done so much better, but it just took away so much time from my main focus
Didn't get to meet you though, what main did you run in? I was in main D
Hai Guys...
With the spec-r gear diff... are you using a different oil thickness for 27t motor to 13t motor? or you just using the same oil thickness....
@mikeygray... is 100k mean 100,000 cts or wt? sorry to ask you this question seen i'm new to this diff oil...
thanks guys
k4mp4q is offline   Reply With Quote
Old 03-07-2011, 09:25 AM   #2024
padailey's Avatar
Thanks for the feedback on the swing shafts on the previous page!
I am currently using an EVO X (came with the PRO I bought) and have the Tamiya racing wing on it (least downforce of the two wings) which I ran a couple of weeks ago and it seemed to handle well. You can argue that it is not an FWD car but the 2.0L Lancer is FWD as far as I know......
It's not on the list of bodies that do not fit this chassis so I see no reason why it cannot be used, but if the others are better I may consider a new body. Also don't like the colour scheme of this EVO X anyway!
At TCS speeds I don't think it makes any difference. TCS in Omaha I'm not sure if any racing wings were used at all. Here's the order of finish if I remember correctly...
1. Celica - no wing
2. Accord - stock wing
3. Integra - can't remember what wing he ran
4. Civic VTI
5. Civic VTI
Not sure the order of the rest but no other cars really challenged the top 5.
I've seen others locally try the Golf and 406. The guy running the 406 has tried the racing wing and liked it but setup is most important. Getting the car not to roll over the front tire in the corners and getting it to pull off the corners have been the biggest challenge for me. That's on carpet.
www.hobbyplexraceway.com
Tamiya TRF417X (Lion's Automotive GTR)
Tamiya TRF416X
Tamiya F104W MP6/4 converted to F104X1 (Renault R30)
padailey is offline   Reply With Quote
Old 03-07-2011, 11:46 AM   #2025
superspeed's Avatar
Is the Integra from Tamiya or HPI?
superspeed is offline   Reply With Quote
Tamiya Championship Series Neil Rabara Racing Forum 21085 07-20-2017 05:34 PM
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5790 06-17-2017 05:27 PM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 724 04-03-2017 12:43 PM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 11:28 AM
