Like Tree24Likes
Old 03-01-2011, 07:20 PM   #1996
TryHard's Avatar
Originally Posted by mikeygar View Post
I used 100k AE oil
With 100k oil it felt like a really tight ball diff. Advantage for me was that I had a little bit of turn in afforded as compared to a spool. Takeoff from standstill was awesome!
Same problem here. The Spec-R gearcase comes with adapters to fit either the original ball diff or the gear diff. Too many philips screws to undo to make my car TCS legal again so I won't be running in our events for awhile hehehe. Had my fill of rebuilding the diff so many times during TITC I'm pretty much sick of it right now hahahaha
You're lucky that your diff stayed ok. Mine was very notchy after every 2 runs. I even put new diff plates on the 2nd day and still became notchy. I've pretty much given up on the Tamiya diff and will join our TCS events again once Tamiya comes out with a geardiff. All in all, I spent more time fixing my FF than my touring car!!!
Also seeing that my times were a second off the A-main guys was very disappointing, am challenged to run FF again next year since I know I could have done so much better, but it just took away so much time from my main focus
Didn't get to meet you though, what main did you run in? I was in main D
For the FF I was in the D as well... blue Integra. Really didn't have a good run in the main, got up to second on the first lap before losing the rear on the sweeper, on power (), and then collecting a track barrier. Cue removed lower kingpin screw, one popped out driveshaft, and end of the race... hey ho, try again next year!
Old 03-02-2011, 03:47 AM   #1997
Suspended
That's why I use aluminium knuckles if I can. Plastic threads are a bad idea in places like that.
Diffs become notchy because of worn balls as well. Changing plates is only half the equation. Try to have a look under a powerful magnifier at the worn balls and you'll see they're anything but round.
niznai is offline   Reply With Quote
Old 03-02-2011, 05:17 AM   #1998
mikeygar's Avatar
Trader Rating: 14 (100%+)
cool! I uploaded a vid of our main:
+ YouTube Video
sorry to hear about your crash. Was lucky to TQ the run and finish same position as well laptimes were 2 seconds off the A-main though so still a lot of work needed.
I agree, I should throw out my balls and get new ones
Manila On-Road RC on Facebook
https://www.facebook.com/ManilaRC
mikeygar is offline   Reply With Quote
Old 03-02-2011, 08:08 AM   #1999
mikeygar's Avatar
FF A Main Rd 2 Finals
+ YouTube Video
FF A Main Rd 3 Finals
+ YouTube Video
Old 03-02-2011, 12:57 PM   #2000
Send a message via AIM to Waco
WOW! Well done mikeygar! If that was the 'D' Final, it was very competative.
That looks like an incredibly quick & quite a large indoor track (it would be great if we had more of them over here.
What was the surface, as it looks like highly polished concrete, & what tyres did you guys use to get that great handling?
Thanks for the video, it gives us an idea what the FF03 can do in good hands
Waco is offline   Reply With Quote
Old 03-02-2011, 05:52 PM   #2001
cannon's Avatar
Trader Rating: 35 (100%+)
Asphalt track with a lot of goop.
Tyres were a Ride control tyre .... 36 compound all round
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 03-02-2011, 05:58 PM   #2002
mikeygar's Avatar
Thanks Waco! The surface was super smooth asphalt, and yes, the track is HUGE and QUICK but very narrow! Our run in D main was pretty slow compared to the A since in D, I was only able to manage 20 second laptimes whereas in A, they were doing 17's! 3 seconds down per lap plainly means there's still a lot of progress needed.
Tires were Ride handouts, 36 degrees with medium inserts. The FF03 was pretty nimble, luckily in the last few days, traction stabilized and there were less traction rolls all around. It was ridiculous in day 1 and 2 of qualifying. Truth be told, I spent more time setting up my FF than my touring car!
Old 03-03-2011, 03:23 AM   #2003
Thanks for the feedback on the swing shafts on the previous page!
Ok so I have seen people using the integra and Civic VTi bodies thus far.....have also seen the 08 Subaru used as well.
Now is one of the above better in more ways than the other? What is the best all rounder or does it not really matter and all comes down to your setup and driving style?
Does anyone run one of the Tamiya racing wings on the Integra or is the standard one used?
I am currently using an EVO X (came with the PRO I bought) and have the Tamiya racing wing on it (least downforce of the two wings) which I ran a couple of weeks ago and it seemed to handle well. You can argue that it is not an FWD car but the 2.0L Lancer is FWD as far as I know......
It's not on the list of bodies that do not fit this chassis so I see no reason why it cannot be used, but if the others are better I may consider a new body. Also don't like the colour scheme of this EVO X anyway!
mr lee is offline   Reply With Quote
Old 03-03-2011, 06:57 AM   #2004
NiMo's Avatar
Standard Lancer/Charisma is Front Wheel Drive, and some do put the Evo body kits on standard models, with the Evo IV very common and easy to obtain (pattern parts I think).
NiMo is offline   Reply With Quote
Old 03-03-2011, 08:57 AM   #2005
Cannon & Mikeygar: Thanks for the response, I envy you being able to race at such a venue...
The cars looked 'planted' & composed & I suspected that you had foams as they picked up speed quickly & gripped so well although I did notice that any 'clipping' of the apex dots was punished with too much air time or rolling over, but all the same it looks like a great venue. The Ride handouts were up to the task by the looks of it despite the high temperature rating (I've NEVER used such a high rating even in mid summer! -maybe one day I may stop whingeing about our lousy weather! )
Great racing!
Old 03-03-2011, 09:20 AM   #2006
NiMo's Avatar
Great racing!
Having raced at a Worlds finals in Honolulu (1999) I have kept my views about tyres different to which part of the world they race.
At that time 25 or 30 was the compound to have in the UK and Europe, but they felt like jelly after only 2 minutes in Hawaii, and 40 compound was the minimun you could get away with, 50's were used by the A B & C finalists.
Basically our ground temperature is like ICE compared to those the other side of the Atlantic, so 36's there is like us running 24's
Old 03-04-2011, 07:52 AM   #2007
Point taken, I suppose I'm a little envious of the weather that these guys are having to 'endure' I think the highest rating I've ever owned was a 35 which I took to by brothers in South Africa (& left there)
I didn't know that you raced in Honolulu... pretty good going
I just have to settle for racing in South Africa (K90 in Boksburg) as & when I visit the family & yes, even in the middle of their winter, I have to use harder compounds even though they tend to use foams (& Coke on the surface )
I do find that I'm asked all sorts of questions regarding my batteries as I take them on hand luggage (as well as the chassis, of course!)
Old 03-04-2011, 10:56 AM   #2008
NiMo's Avatar
Was in the Kyosho Cup days
Qualified for 4 European finals (Portugal, Italy, Switzerland, Greece) and 2 World finals (Honolulu, Beijing).
Don't think anything will ever beat the trophy from Italy - 1ST PLACE - thanks to some helpful wet weather
Old 03-06-2011, 08:10 AM   #2009
C5R01's Avatar
Send a message via Yahoo to C5R01
Just finished my FF03
Current Cars:
Tamiya Garage:TB03; TA05V2-IFS; 414X #60;F104 V2;TA03r-s:TA03F:TA03R: FF01: FF03: M01: M03: M06: 1/14 Mercedes Semi truck- w/Reefer trailer ( fully functional): Tamiya Juggernaut 4X4X4, Tamiya RC Freightliner Cascadia Evo.; Honda City Turbo WR-02C; TRF102 F1
OTHERS:Kyosho 1/8th scale nitro Corvette C6R: Yokomo GT4 nitro, Slash 2WD,TA SCm5
C5R01 is offline   Reply With Quote
Old 03-06-2011, 09:26 AM   #2010
rtypec's Avatar
Nice! Calsonic livery is good for 0.3 seconds per lap
rtypec is offline   Reply With Quote
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5804 Today 01:44 AM
Tamiya Championship Series Neil Rabara Racing Forum 21185 09-05-2017 07:20 PM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 730 08-15-2017 08:06 PM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 11:28 AM
