Like Tree21Likes
Old 02-28-2011, 09:39 PM   #1981
TryHard's Avatar
Originally Posted by Barry White View Post
BTW ant the TITC you're not running Civic but an Integra
Yeah.. opps! Body of choice was between those two... most seemed to go integra, but the civic was a little better in the chicanes.
I never got the FF handling well once the bite came down, always ended up too tail happy, and with only FWD, didn't have the traction to make up for any little slide.
Really should have tried running the gear diff sooner, but as it was, only put it in for the final (and it did feel better). Couldn't make it count as I crashed and broke in the first lap... kinda summed up my whole event!
Have to say Jilles and Marc both got their FF's going well. Marc's was quite close to box stock, a little wider on the suspension blocks. Surikarn's car did look very good though..
Ed
Old 03-01-2011, 12:30 AM   #1982
Hey Ed,
do you have any pics of the Tamiya Factory Drivers´ FF´s ??
I´m very interessted in how they built and setup their chassis.
Thx in advance.
evotrf is offline   Reply With Quote
Old 03-01-2011, 04:57 AM   #1983
Ok so I purchased an FF03 Pro second hand and ran it as it was at the first TC event. Got serious binding on the right dogbone/axle/suspension arm on first run. Decided to swap diff nut around which helped free up some space for the right dogbone to move a little more freely.
Anyway I will be purchasing the universals and ali diff outdrives for it soon.
I have heard that the diff has to built a particular way and not as per the instructions as it will loosen itself up....how true is this and exactly what must be done? Have been a couple of pages back but didn't find anything!
mr lee is offline   Reply With Quote
Old 03-01-2011, 05:19 AM   #1984
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
after you build the diff, make sure the head of the screw is on the right side of the car, the nut will then be on the left side. suggest you go straight to getting the alum diff halves and the hop-up gears from the TRF201 (black idler and diff gear). everyone back here melted their stock diffs after just 1 pack even though the diff was built and mounted correctly.
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 03-01-2011, 05:36 AM   #1985
Thanks VooDooPH!
Will be getting the gears too
Have been told to get 44mm swing shafts but people here seem to favour the 46mm! Will either be fine with the ali outdrives?
Old 03-01-2011, 06:04 AM   #1986
VooDooPH's Avatar
Thanks VooDooPH!
I'm running 44mm in mine... they fit fine. maybe the others are running 46mm because they're running wider suspension pin mounts?
Old 03-01-2011, 06:35 AM   #1987
SteveM's Avatar
Trader Rating: 127 (100%+)
I'm also running the 44mm CVD's with the aluminum diff outdrives.
SteveM is offline   Reply With Quote
Old 03-01-2011, 06:42 AM   #1988
TryHard's Avatar
personally, I would get the Spec-R gear diff, stuff it with a load of cleaning putty or blue tack, and be done with it.... best solution for a diff imo, and no need to rebuild!
Ed
Old 03-01-2011, 08:12 AM   #1989
mikeygar's Avatar
Trader Rating: 14 (100%+)
Ed
Ed,
That's what I did, after giving up on the Tamiya aluminum diff outdrives. I was running ceramic balls, and after every run, I had to rebuild my diff! After 2 rebuilds in 2 days, I said screw it and got a gear diff. Should have done it sooner - my runs were more consistent and trouble free. If I had the gear diff early on, probably would have qualified better
Manila On-Road RC on Facebook
https://www.facebook.com/ManilaRC
mikeygar is offline   Reply With Quote
Old 03-01-2011, 09:44 AM   #1990
Default diff oil
Originally Posted by mikeygar View Post
Ed,
Which diff oil did you use on your gear diff?
thanks
k4mp4q is offline   Reply With Quote
Old 03-01-2011, 10:06 AM   #1991
F N CUDA's Avatar
Trader Rating: 30 (100%+)
Ed
Does it still "diff" or is it now a spool?
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 03-01-2011, 10:45 AM   #1992
SteveM's Avatar
I've read that in order to use the Spec-R gear diff in your FF-03 that you also needed to use the Spec-R gear case. Is that correct? I run my FF-03 in TCS events and cannot run the Spec-R diff.
Old 03-01-2011, 04:20 PM   #1993
Tommi Makkinen's Avatar
Trader Rating: 28 (89%+)
correct. my teammates who opted for the SpecR gear diff had to use the matching gearcase... some kind of compatibility thing...
Racing is in my blood
Tommi Makkinen is offline   Reply With Quote
Old 03-01-2011, 06:01 PM   #1994
TryHard's Avatar
Still diff's.. but is very tight, some way above 500k I think. One advantage of it is you don't need to worry about oil leaking out with the putty
And yes, you do need to use the Spec-R gear case, as the Gear diff is wider than the ball diff. The casing does come with inserts to mount up the standard ball diff mind, so once it's in, thats it
My ball diff actually ran really well, didn't need to rebuild it at all aduring the week... it just wasn't providing enough drive out the corner, looking forward to giving it another run at some point when it warms up here in Shaghai.
Ed
Old 03-01-2011, 07:03 PM   #1995
mikeygar's Avatar
thanks
I used 100k AE oil
With 100k oil it felt like a really tight ball diff. Advantage for me was that I had a little bit of turn in afforded as compared to a spool. Takeoff from standstill was awesome!
Same problem here. The Spec-R gearcase comes with adapters to fit either the original ball diff or the gear diff. Too many philips screws to undo to make my car TCS legal again so I won't be running in our events for awhile hehehe. Had my fill of rebuilding the diff so many times during TITC I'm pretty much sick of it right now hahahaha
Ed
You're lucky that your diff stayed ok. Mine was very notchy after every 2 runs. I even put new diff plates on the 2nd day and still became notchy. I've pretty much given up on the Tamiya diff and will join our TCS events again once Tamiya comes out with a geardiff. All in all, I spent more time fixing my FF than my touring car!!!
Also seeing that my times were a second off the A-main guys was very disappointing, am challenged to run FF again next year since I know I could have done so much better, but it just took away so much time from my main focus
Didn't get to meet you though, what main did you run in? I was in main D
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5780 Yesterday 07:38 PM
Tamiya Championship Series Neil Rabara Racing Forum 20951 03-18-2017 03:26 PM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 723 02-09-2017 08:16 AM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 11:28 AM
Currently Active Users Viewing This Thread: 5 (3 members and 2 guests)
bemmis, IAmGreatDane, wtcc
