Like Tree24Likes
Old 02-22-2011, 05:47 AM   #1966
rc_square24's Avatar
Originally Posted by VooDooPH View Post
Front:
XD - XD
rear
XD - A (-2.5deg)
going wider might lead to fitting problems with the FF shells available (Accord, Civic EG, etc)
So will this keep the car at stock width?
Just clarifying, do you mean
1XD (415) - 1XD (415) FRONT
1XD (415) - 1A (TB5/416) REAR
Where:
1XD is http://www.rcmart.com/catalog/rc-trf...1-p-26112.html
1A is http://www.rcmart.com/catalog/rc-evo...9-p-27496.html
Thanks!
rc_square24 is offline   Reply With Quote
Old 02-22-2011, 07:05 AM   #1967
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
yup... that's right... although you could also use the split type XD-D (TA05v2) blocks for the FR
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 02-22-2011, 10:05 AM   #1968
TryHard's Avatar
Just to point out, in the mega high traction at the TITC, most of the FWD runners (not just the FF03's) are all running pretty wide cars.
Got my FF03 running pretty well today, setup is a bit crazy (still can't quite understand how it works, but hey, it does!), moving onto controlled practise tomorrow. Was quite fun to see Jilles and Marc out with their FF's as well, should be interesting to see how they fair against the top runners here
I'll note down my setup tomorrow, and hopefully post up later today.
Ed
Old 02-22-2011, 02:44 PM   #1969
Trader Rating: 46 (100%+)
Post some pics if you could please
josh short is offline   Reply With Quote
Old 02-22-2011, 03:17 PM   #1970
if anyone interested racing ff03 once a month see my thread california racing
corally rdx ta01 thru ta05 m03 trf416 cyclone s tc3 yokomo sd
some offroad vehicles
a special thanks to dennis lyman and bitter and also grandpa for all the help
always looking for old tc's like old tc3 and tamiyas etc
service most generator rv and portables kipors briggs & stratton generac etc.
dongenserv is offline   Reply With Quote
Old 02-22-2011, 05:14 PM   #1971
My ff03 with +2 offset wheels are rubbing the exiv body front and back. Are there any options to narrow the chassis down while keeping the wheels? That's my only set of tires for tcs and the raised body doesn't look very good (it needs to be raised a lot). I found the rubbing to be less on 0 offset wheels, are there any hex hubs that are 2mm thinner than stock ones?
I know theres probably not much i can do, just wondering.
Old 02-22-2011, 05:25 PM   #1972
cartix's Avatar
Trader Rating: 33 (100%+)
Ed
Thanks for the updates. Kick ass!
Cars and boats, lots!
cartix is offline   Reply With Quote
Old 02-23-2011, 08:41 AM   #1973
Send a message via AIM to Waco
I would dearly love to! It would be a brilliant break from our lousy weather, but it might be a little too far to travel (& the missus may not justify the cost!)
Waco is offline   Reply With Quote
Old 02-23-2011, 09:28 AM   #1974
MD
MD's Avatar
Trader Rating: 115 (100%+)
I'm sure this has been mentioned in previous posts, but what are the Tamiya part numbers for the universals for the FF03? Thanks.
MD is offline   Reply With Quote
Old 02-23-2011, 11:16 AM   #1975
They haven't released any specific for this car as existing ones fit.
On my car i have the 417 axles and cross joint with 46mm swing shafts.
51445
51444
51092 or equivalent, some use 44mm
Old 02-23-2011, 11:29 AM   #1976
MD
MD's Avatar
Thanks for your help. I went to Tamiya's site and called. There answer was TB03 axles (50476), 46mm swing shafts (51092 standard) (53724 light weight), and the cross joints (53500).
Old 02-23-2011, 12:39 PM   #1977
The 417 axles supposedly spin freer as its a floating design, also no more loose set screws.
Old 02-23-2011, 03:07 PM   #1978
How are you supposed to adjust sway bars?
I have the droop set, but one of the bars came a bit tweaked out of the package and the left is raising (the opposite arm) less than the right as it is suspending the left arm a bit (with shocks off).
The tie rods are set at stock length, so should I just lengthen the left side rod to lower the arm back down? I tried twisting the bar to get it balanced as much as I could but its still a bit off and seems to spring back a bit.
Thanks.
Old 02-24-2011, 09:00 AM   #1979
Barry White's Avatar
Ed
BTW ant the TITC you're not running Civic but an Integra
Barry White is offline   Reply With Quote
Old 02-25-2011, 06:21 AM   #1980
Is there any pics or coverage of TITC???
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5806 09-22-2017 03:06 PM
Tamiya Championship Series Neil Rabara Racing Forum 21185 09-05-2017 07:20 PM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 730 08-15-2017 08:06 PM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 11:28 AM
