Old 01-26-2011, 03:47 PM   #1906
rtypec's Avatar
Originally Posted by maxepower View Post
...a lot of us running the FF03 used weight as a tuning feature to get the cars to stay planted ... Weight varied from 7 grams to 28 grams.
Just my 2$
Doh! News to me!
I spent all that money on Ti and Alu parts only to add $0.05 worth of lead weight?!? haha I know it's not how much weight, but where you add weight.
rtypec is offline   Reply With Quote
Old 01-26-2011, 04:41 PM   #1907
OSherman's Avatar
my car was actually on a strict diet.. finally got it working good by the mains..
weight watchers.
OSherman is offline   Reply With Quote
Old 01-26-2011, 06:59 PM   #1908
TryHard's Avatar
Originally Posted by superspeed View Post
just want to confirm that universals of ta04/tt01 fits in ff03 or is it partial of trf201 universals...
I'd go with the following from the 417 personally...
TAM51445 - TRF417 wheel axle
TAM51444 - TRF417 cross joint
and either
TAM54077 - 44mm Aluminium swing shaft
or
TAM53724 - 46mm Aluminium swing shaft
depending on your preference.
The 417 uses clips rather than grub screws to hold the cross joint in, frees up the cvd a little.
HiH
Ed
Old 01-26-2011, 07:14 PM   #1909
maxepower's Avatar
Cool RE: Weight Watchers Program!
Originally Posted by rtypec View Post
Doh! News to me!
Yes, I didn't say "all" of us. But, like I said I only started playing with weight when it was cold and rear grip was an issue.
Once it warmed up the weight came off!
Just my 2$
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EXO-6,TA-07,TRF419,EVO-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 01-27-2011, 09:46 PM   #1910
J-VET's Avatar
Default Which body?
So I've been running a FXX body while waiting to have some options before picking out a fwd. Now that theres a few choices, does one have a performance advantage another? The Integra still looks to have more of a race car shape then some, but I only saw one at TCS. Also, are they all made for the long wheel base? Is this a better choice then the short or med? Or are they all the same and just a matter of looks?
Thanks in advance
Jeff
J-VET is offline   Reply With Quote
Old 01-28-2011, 03:26 PM   #1911
caltek1's Avatar
Trader Rating: 33 (100%+)
I have been running my FF03 with a few of the Tamiya hop-ups and using the TITC tyres on all four corners and have the car handling reasonably well. I really like how when it is pushed it lifts the inside rear wheel. I am also using the Just stock speed controller and 13.5 BL motor, which is the system used at TITC. A 48 pitch 45 tooth pinion with a 65 tooth spur will get you in the ball park, however a smaller spur and larger pinion would be better. The gear cover is not used.
I have found on the tracks I have run, that by standing up the rear shocks and using a stiff swaybar to assist with handling. I have also added the carbon fibre rear stiffeners. The 3Racing ball diff works a treat and I think is better than the Tamiya diff, however I know some are restricted to running Tamiya gear due to TCS.
I don't think the car would be ultra good on a high traction circuit, because of the flex in the plastic chassis. But it works well on lower traction circuits.
I have also been using the Tom's EXIV body, which I think is better than the VW Golf that I was using. I will test a Beams Integra when it is painted. They seem to be very popular in TCS races.
Good luck to those running TITC next month. I had entered but will be unable to attend due to work commitments. It would have been a great opportunity to have met some new faces with similar interests.
If I get time I will take some pictures and post.
Later,
Calvin.
caltek1 is offline   Reply With Quote
Old 01-30-2011, 12:02 PM   #1912
Did a quick test run today after adding anti-roll bars all round and adding more rear toe-in, track was only 3c but dry. Found the car to be far better than it was last week on a cold damp track. Still used the pit inters as it was to cold for my new slicks to grip as i left tyre warmers at home. The car was far more positive turning into the corners letting me carry more speed.
Going to be good fun running this car once the warmer weather hits the UK.
Xray X1 "16" driven by an idiot, me
weekendracer_uk is offline   Reply With Quote
Old 01-30-2011, 11:56 PM   #1913
Send a message via AIM to Waco
"Going to be good fun running this car once the warmer weather hits the UK."
What day will that be then John? Ha Ha!
I agree that your car is absolutely on the money... It's responsive & accurate, but felt 'safe' at the same time... no wonder you were giving all but one 4 wheel drive a caning last winter series!
Waco is offline   Reply With Quote
Old 01-31-2011, 08:17 AM   #1914
4WD = beginners cars
Old 02-03-2011, 05:29 PM   #1915
thudtheace's Avatar
Send a message via MSN to thudtheace
I just picked up the FF-03 with the civic type-R body. Didn't go for the pro because I have so many of the hops up lying around here as spare parts for my evoV,evoIV, and trf-415(universals, shocks, springs, and lots of Ti screws). I did however get the upgraded steering parts, tb-03 axles(to complete my universals), and aluminium diffs. So is there anything to watch out for while building? (besides the flip the diff over before putting the diff screw in). This car looks like so much fun to drive! Thanks!
Cheers!
Currently Building - Tamiya FF03
thudtheace is offline   Reply With Quote
Old 02-04-2011, 10:01 PM   #1916
Default esc for brush on ffo3
Hi guys..
I decide to buy fo3 pro for running on tcs, but i have know idea which esc will be good to use for brush motor...
Since you guys know better, please let me know which is the best esc...
thanks
k4mp4q is offline   Reply With Quote
Old 02-04-2011, 10:53 PM   #1917
No idea what you can and carn't run in the TCS as we dont have that in the UK but im using a LRP Quantom 2 speedo i brought 2nd hand of ebay for next to nothing.
Old 02-05-2011, 01:47 AM   #1918
NiMo's Avatar
I'm using a redundant Nosram Stock Spec brushless esc wired to an HPI Firebolt sealed can motor.
Orange to live, yellow and blue to earth.
NiMo is offline   Reply With Quote
Old 02-05-2011, 04:13 AM   #1919
rc_square24's Avatar
Original LRP QC in mine for a silvercan. This car is so nice to drive out of the box.
rc_square24 is offline   Reply With Quote
Old 02-05-2011, 08:17 AM   #1920
Guddam's Avatar
Default The shape of thing to come...
Guddam is offline   Reply With Quote
Tamiya Championship Series Neil Rabara Racing Forum 20850 Today 01:06 PM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 711 01-08-2017 09:27 AM
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5774 09-23-2016 10:49 PM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 12:28 PM
SEO by vBSEO 3.5.0
