Old 01-19-2011, 07:05 PM   #1876
mikeygar's Avatar
Trader Rating: 14 (100%+)
Originally Posted by cannon View Post
You realise that by running just one class you will only get to race once every 5 houyrs !!!!!!
hey man, really good point there...
Manila On-Road RC on Facebook
https://www.facebook.com/ManilaRC
mikeygar is offline   Reply With Quote
Old 01-20-2011, 12:04 AM   #1877
Send a message via AIM to Waco
Non timed 17.5 are hard to gear up on the FF03. That is why we picked 13.5 as it is easier to gear and not that slow. Our speed is similar to turbo 21.5
Thanks for the response Cannon... So you're saying that the 21.5 turbo is as quick as a standard 13.5? Ouch! I have run a non-turbo 13.5 in the past as it was originally identified as being about the same performance as a 27x1, so that makes sense, but if I'm going to be racing against 21.5 turbos with a 17.5 that I'd have to gear really high to be competative (& also get hot), I'm going to get my rear end kicked!
I think I need to look for an 'Old Man' can!
Waco is offline   Reply With Quote
Old 01-20-2011, 12:48 AM   #1878
cannon's Avatar
Trader Rating: 35 (100%+)
You have to remember that the system we use has no timing on the ESC and no timing on the motor. Currently we are running at 50mm rollout (60 spur/40 pinion). With a 17.5 you might need to gear even higher which is hard to achieve with the FF03's 2.6 gearbox
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 01-20-2011, 03:51 PM   #1879
It's the second time i have been driven my FF03 PRO with the old B-type in front and the new C-type tires at the rear and the car runs like a dream. (it was on a indoor track)
Not to much grip in front that makes the rear too loose, it's just perfect with the B-type tires.
I could recommend it to you guys
addicted2blue is offline   Reply With Quote
Old 01-20-2011, 05:51 PM   #1880
fordmike65's Avatar
Trader Rating: 28 (97%+)
I've been running a SP Cirtix 21.5 combo for the past few weeks practicing at Cal & the Rose Bowl. It's pretty spot-on with the other silver can FF03's. Seems to be a good,cheap alternative.
fordmike65 is offline   Reply With Quote
Old 01-21-2011, 01:16 AM   #1881
Hi Cannon, I get your point, & I agree that my gearing is going to be off...
hence the comment re me getting my tail kicked!
I have seen that the RC scene is in a state of flux regarding the motor speeds/ sizes & how could the turbo/ non-turbo speedos be effectively policed when its common knowledge that there are pirate programs out there that can subtly enhance a motor whilst it appears to be running stock?
There is a good case for silver cans insofar that if you overgear them, they go off or 'let go', whereas the brushless can tolerate high/ over gearing so much better...
I like your idea with the fixed gearing ratios & the non-turbo 13.5s although I guarantee that we don't have enough support for that sort of class, let alone front wheel drive. But hey! It's worth a dream...
I'll have to find out what class they run in Boksburg South Africa before I go over there in December
Old 01-21-2011, 02:12 AM   #1882
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
any set-up suggestions for low/med grip asphalt? we're running the Tamiya GT tuned for our local TAC series...
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 01-21-2011, 08:07 AM   #1883
Tommi Makkinen's Avatar
Trader Rating: 28 (89%+)
listen to the man, Mikey, try to run a 2nd class in TITC...
i mean, it'll just take you at most an hour/ hour and a half max to fix and recharge your car for the next round. what will you do for the next three and a half hours? check out our teammate Noel, he's planning on doing 3 classes there... and im going to run FWD in addition to my F-1 even though i know i'm gonna get slaughtered in FWD with my FF-02...
Racing is in my blood
Tommi Makkinen is offline   Reply With Quote
Old 01-21-2011, 11:30 AM   #1884
TryHard's Avatar
Thats the whole reason I picked up an FF03 to run as a second class... I'd be pulling my hair out with the amount of time between races.
Not sure if anyone else has noticed, but we've got Jilles, Surikarn, and Meen V joining in the FF class.
Only issue I see, is I probably won't be able to give the car a run until I actually get to Thailand... could be an issue!!
Old 01-21-2011, 12:05 PM   #1885
superspeed's Avatar
any new re-release of older fwd bodies? Mondeo would be cool, and old VW Golf.
superspeed is offline   Reply With Quote
Old 01-21-2011, 08:50 PM   #1886
mikeygar's Avatar
I've decided to run the FF03 as well! Updated entry form sent to Itaru just now... Now to figure out the luggage situation
Old 01-21-2011, 09:06 PM   #1887
cannon's Avatar
Damn,
The more people I encourage to race FWD the further diown the field I finish
Old 01-22-2011, 04:31 AM   #1888
27t old school all the way
Xray X1 "16" driven by an idiot, me
weekendracer_uk is offline   Reply With Quote
Old 01-22-2011, 06:32 AM   #1889
mikeygar's Avatar
Damn,
Hahaha hard to believe! Personally if I can make it to the middle of the pack I'll be very happy already!
Did my maiden run in our local TCS today and was very happy with the FF03! could have used more speed but our locAl spec is for the GT tuned motor I can only imagine how much better it will be with a 13.5!!!
Looking forward to running it again!
Old 01-22-2011, 06:35 AM   #1890
VooDooPH's Avatar
Tamiya Championship Series Neil Rabara Racing Forum 20851 01-17-2017 10:21 PM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 711 01-08-2017 09:27 AM
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5774 09-23-2016 10:49 PM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 12:28 PM
SEO by vBSEO 3.5.0
