Like Tree23Likes
Old 01-17-2011, 12:03 PM   #1846
Send a message via AIM to Waco
Originally Posted by jebolution View Post
installed a new robinson 60T 48 pitch spur and 47t 48 pitch pinion which gives me a 3.something FDR. if the motor heats up fast, i might change to slower motor
and 3racing cf chassis conversion.
Hi Jebolution, did the carbon chassis come with a top deck, or did you leave it off to generate mechanical grip with a more flexible chassis without it?
Waco is offline   Reply With Quote
Old 01-17-2011, 12:44 PM   #1847
Hi I have some newbie questions:
1. Is a 5.5t brushless with 2s lipo too much for this chassis to handle?
2. If it's not too much, what size spur/pinion should I use?
3. If it's too much, which motor would be the fastest on this chassis but still controllable?
TIA,
Ron
syrss is offline   Reply With Quote
Old 01-17-2011, 01:42 PM   #1848
NiMo's Avatar
TIA,
Ron
2s 5.5 is too much for most.
FWD is all about traction, so no point is such power if front wheels are never to stop spinning.
2s 13.5 should be plenty if using a timing ESC, 21.5 is more practical.
NiMo is offline   Reply With Quote
Old 01-17-2011, 02:46 PM   #1849
speedemall's Avatar
Trader Rating: 41 (100%+)
If anyone wants a mint condition Tamiya Idemitsu Mugen Civic body for these LMK. I'll be listing it for sale shortly. Will this even fit the FF03??
speedemall is offline   Reply With Quote
Old 01-17-2011, 10:07 PM   #1850
@ wako.. the top deck is included with the chassis but i did not install them as its a pain to change battery unscrewing 4 screws. its so grippy that when cornering and if you clip on the corner, it rolls. hahaha!
im using sorex 36 front and medium-hard inserts and sorex 28 with medium inserts in rear.
no rules here in Dubai except for a 13t motor limit
jebolution is offline   Reply With Quote
Old 01-17-2011, 10:47 PM   #1851
cannon's Avatar
Trader Rating: 35 (100%+)
The battery doesn't come out from the top. You undo the blue nut on the ESC mounting plate and slide the plate out and push the battery in from the side. Same as the 3 racing sakura FF car
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 01-17-2011, 11:25 PM   #1852
made that option first but found it difficult to slide the batts from the ESC side as its hitting the receiver and i dont want to relocate the reciever so i opted for the one on the pix
Old 01-17-2011, 11:27 PM   #1853
cannon's Avatar
The receiver is meant to sit behind the servo. That way you have plenty of room to get the battery in.
Cheers
Old 01-18-2011, 01:49 AM   #1854
mikeygar's Avatar
Trader Rating: 14 (100%+)
Hey guys, what is the internal ratio of the FF03? If I plan to switch between 64 and 48 pitch, the IR should stay the same right?
TIA!
Manila On-Road RC on Facebook
https://www.facebook.com/ManilaRC
mikeygar is offline   Reply With Quote
Old 01-18-2011, 01:59 AM   #1855
rc_square24's Avatar
Search shows its 2.60
No change as its internal and not final drive.
rc_square24 is offline   Reply With Quote
Old 01-18-2011, 08:32 AM   #1856
Ah! I see... I have taken the plunge & bought it but I wondered how the battery was changed (thanks to the subsequent feed back ) We have no rules other than trying to get the Front Wheel Drive Class sanctioned locally! I will be trying the 17.5 class, but I think it may be slow without monster gearing .
Old 01-18-2011, 10:58 AM   #1857
NiMo's Avatar
Waco
Ran mine around Aldershot with a basic HPI Firebolt motor and cheap Ansmann ESC, was good for 18 laps but may have been 19 if I ran a proper shell and better drive out of corners (and a clear run) (17.5 on fast 19 lap pace with timing ESC).
If using a timing ESC then gearing is not a problem, but may be if zero timing is used.
Mine is resting at moment as I have other areas to get sorted within the club
(entry level 21.5 class (TC5)).
Old 01-18-2011, 11:09 AM   #1858
cannon's Avatar
Waco
At the huge TITC event in Thailand (60 entries for FWD) we are using the Hobbywing Justock ESC and 13.5 motor. Both have no timing so equal for all. This combo allows gearing to be achieved relatively easily. We have been running that combo here in Australia and it works great ... good speed without being crazy.
If you need help finding that system let me know
Old 01-18-2011, 11:24 AM   #1859
TAMAK's Avatar
Trader Rating: 28 (100%+)
Waco
I love how TITC is setup this year. Cant wait to see some footage of the FWD race.
TAMAK is offline   Reply With Quote
Old 01-18-2011, 05:50 PM   #1860
cannon's Avatar
Glad you like the rules etc.
It took me a little bit of time to set up the rules and the class and the motor/ESC combo were chosen based on that all brands of FWD car could achieve the gearing.
As for the bodyshell choice of realistic bodies ... it just had to be. We also managed to convince the event organiser to swap to spoked rims for even more realism
Tamiya Championship Series Neil Rabara Racing Forum 21026 05-25-2017 08:50 AM
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5789 04-27-2017 10:11 PM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 724 04-03-2017 12:43 PM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 11:28 AM
