Like Tree24Likes
Old 01-14-2011, 10:59 PM   #1831
cannon's Avatar
Trader Rating: 35 (100%+)
Originally Posted by gtfour93 View Post
Guess you're not a rally fan.
The tamiya Renault Clio shell is seriously ugly. It just doesn't look good
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 01-16-2011, 05:39 PM   #1832
Casey's Avatar
what spur and pinion combo are you all using to get max FDR, ( 64 p )
Casey is offline   Reply With Quote
Old 01-16-2011, 06:27 PM   #1833
padailey's Avatar
Originally Posted by MD View Post
Which length of the FF03 is the best handling version.
I think the JAS version may be the short body version. In the TCS rules they just designate FF03 platform and list the bodies. I just wondered if anyone tried running the FF03 in the shortened version.
I've been running the medium wheelbase on carpet and like it. Car doesn't plow in the corners as much for me and I can drive it a little more like a touring car than a mini. Not that a different setup on the long wheel base couldn't produce the same results I just thought I'd try it and see what it did (going shorter).
I'm not up on all the bodies but most I know of (Tom's and Levin Toyotas, 406, 850, Accord, GTI, Civic VTI, JAS Civic, and the Beam's Integra (I think)) are all long. The Clio is medium ... so is that the only shorter body? I really had to hack out the wheel wells on my Accord to get it to work with the medium wheelbase.
www.hobbyplexraceway.com
Tamiya TRF417X (Lion's Automotive GTR)
Tamiya TRF416X
Tamiya F104W MP6/4 converted to F104X1 (Renault R30)
padailey is offline   Reply With Quote
Old 01-16-2011, 06:34 PM   #1834
padailey's Avatar
TCS max is Spur: 80 tooth, Pinion: 54 for a 3.85. You can get to a 3.82 with a 78 spur if you just want to max out the gearing. On carpet when I try and run that I'm frying eggs on my motors. Going to a 4.3 motors are still a little warmish but at least they are under 200 degrees.
Tamiya TRF416X
Old 01-16-2011, 06:38 PM   #1835
padailey's Avatar
Hope some FF03 hotshots come to Omaha for the TCS. I'd really like to see how my car stands up to a good one. I can put mine in the A of our USGT class (21.5 open esc) but can't get anywhere near the front. This is understandable just want to see how I stack up against people running the car/class regularly.
Tamiya TRF416X
Old 01-16-2011, 06:40 PM   #1836
gashuffer's Avatar
Trader Rating: 48 (100%+)
Ran my car for the first time this week and I had a blast with it. 80/51 was the ticket. Now I just need to go to a stiff spring up front and get some sway bars. The car rolls way to much, but is really fun to drive. Love it.
T-Sal
gashuffer is offline   Reply With Quote
Old 01-16-2011, 07:37 PM   #1837
rtypec's Avatar
Default 2011 TCS Regionals FWD A-Main
Hi All,
Here's a video from the FWD A-Main. Camera work is a little shakey due to Rockstar
+ YouTube Video
rtypec is offline   Reply With Quote
Old 01-16-2011, 08:14 PM   #1838
MD
MD's Avatar
Trader Rating: 112 (100%+)
padailey - Thanks.
rtypec - Good video.
MD is offline   Reply With Quote
Old 01-16-2011, 09:08 PM   #1839
Johnn27's Avatar
Trader Rating: 69 (100%+)
What body were most racers running at this weekends TCS on the FF03???
Johnn27 is offline   Reply With Quote
Old 01-16-2011, 09:13 PM   #1840
Guddam's Avatar
Hi,
I just received my FF-03Pro kit and couldn't resist the temptation of building it straight away. Still waiting for the option parts... plan to built it with all the bells and whistles from Tamiya inventories....
Guddam is offline   Reply With Quote
Old 01-17-2011, 01:13 AM   #1841
rc_square24's Avatar
Would a Kimbrough 80t 64p spur fit this car?
Anyone tried Type C tires on carpet?
Thanks!
rc_square24 is offline   Reply With Quote
Old 01-17-2011, 07:08 AM   #1842
TAMAK's Avatar
Trader Rating: 28 (100%+)
My thrust bearing failed on me, there was not enough clearance for the bearing to move freely and it was actually pressed into the diff half. Has anyone had this problem? And has anyone used a another manufactures thrust bearing?
TAMAK is offline   Reply With Quote
Old 01-17-2011, 08:28 AM   #1843
Thanks!
I've tried the new C-type tires (with my FF03 PRO) on carpet, and they provide a lot of traction.
I don't think they are the best choice for the FF03 chassis, cause it gives the car too much traction in the front.
But that's my opinion
addicted2blue is offline   Reply With Quote
Old 01-17-2011, 09:18 AM   #1844
F N CUDA's Avatar
Trader Rating: 30 (100%+)
Thanks!
Kimbrough spurs work great.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 01-17-2011, 09:27 AM   #1845
installed a new robinson 60T 48 pitch spur and 47t 48 pitch pinion which gives me a 3.something FDR. if the motor heats up fast, i might change to slower motor
and 3racing cf chassis conversion.
jebolution is offline   Reply With Quote
Tamiya Championship Series Neil Rabara Racing Forum 21088 Yesterday 09:48 PM
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5790 06-17-2017 05:27 PM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 724 04-03-2017 12:43 PM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 11:28 AM
