Like Tree23Likes
Old 01-12-2011, 09:27 AM   #1801
F N CUDA's Avatar
Trader Rating: 30 (100%+)
My email said fastest single qualifier not lap.
Fastest lap is our F1 crowd though and is a really cool way to qualify.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 01-12-2011, 09:42 AM   #1802
stitchy's Avatar
Originally Posted by Dave K View Post
Well i should did this a couple weeks ago when i ordered the ff03 pro but what up grades should i get for it before i get all together .We run silver can where i race with med/high traction . Im getting it ready for the TCS race we are having at my local track so any input would be helpful thanks .
I definitely recommend the aluminum outdrives. CVDs if possible as well.
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 01-12-2011, 11:16 AM   #1803
cannon's Avatar
Trader Rating: 35 (100%+)
And get the alloy spur gear mount
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 01-12-2011, 06:14 PM   #1804
TryHard's Avatar
Well, my FF03 is built
Have to say, actually enjoyed building a non-TRF tamiya kit for once, although not so keen on screwing into plastic
I have built an IFS suspension on a TB03 before, but I'd forgotten how cool it was to see all the links working. And it's the first brand new gearbox'd car I've built since a TA03FS some 12years ago! Something about cutting fresh screw threads that's satisfying
Put a few options on the car, alloy diff halves, alloy driveshafts, ti screws, spur holder etc, only thing I realise I forgot was the sway bars, but I can pick those up later.
On the driveshaft front though, I cheated and went for the TRF417 axles, which use a spring clip rather than grub screw to hold the cross pin, to try and free up the shafts as much as possible. I did contemplate for a few seconds the VCS driveshafts from Litemodz, but having seen all the not so good reviews decided against that option!
Now just need to spray up the Integra shell (white or blue, hmm), and then mount up some electrics, and good to go.
Only issue I've run into is that the only 13.5t motor I have (going for 13.5t blinky to test for TITC), is an X12, which is a few mm shorter than other motors, so the solder tabs touch the plastic motor brace, unless I rotate the motor almost 180 and have the tabs pointing down and back to the arm. No biggie (and shouldn't have that prob with the handout hobbywing setup), but it's gonna make my install look ugly...
Will post some pics later, took a load of pics during the build.
Ed
Old 01-12-2011, 07:29 PM   #1805
cannon's Avatar
Ed
Ed, you will need to place the wire tabs back near the arm.
There is a simple reason for this . With the Hobbywiing motor the sensor lead comes out of the side of the endbell of the motor and is at 90 degrees to the wire tabs. If you try to stand the tabs at 12 oclock the sensor lead will be at 9 oclock facing out the front of the car ... not a good idea
With the wire tabs back at around 4 oclock the sensor lead is up high and thus easier to deal with.
As for motors rubbing against the plastic brace .. get the graphite one which is thinner and works better. Also Yeah racing do a motor spacer which screws to the motor which also helps.
As for an ugly installation , it actually looks super neat with the tabs down and all the wires close together
Old 01-12-2011, 11:01 PM   #1806
Have no experience with Hobbywing motor either, many thanks for tip . How about "sensor cable" proper length for ESC (install per Tamiya's manual)..120, 180 mm or longer ?
kammako is offline   Reply With Quote
Old 01-13-2011, 12:38 AM   #1807
cannon's Avatar
The Hobbywing ESC and motor for TITC has a sensor lead long enough to suit the car. As well I have been told that Hobbywing has slightly lengthened the motor wire so that the wires can reach the motor in the FF03. Hopefully we have thought of everything for the event
Old 01-13-2011, 12:42 AM   #1808
Kail's Avatar
Ed
I tried with the Litemodz CVS and my car felt amazing!
Kail is offline   Reply With Quote
Old 01-13-2011, 07:24 AM   #1809
TAMAK's Avatar
Trader Rating: 28 (100%+)
Hey Guys,
Still having rear droop problems. Can someone measure the maximum up travel with the shocks on? And also the Shock length. Mine is set at 5mm ride height and 3mm additional up travel in the rear and 5mm ride height and no additional droop up front, yet still have some on brake spin out.
TAMAK is offline   Reply With Quote
Old 01-13-2011, 07:44 AM   #1810
SteveM's Avatar
Trader Rating: 133 (100%+)
Default Spec-R Gear Diff?
Has anyone heard when the Spec-R gear diff might be available?
SteveM is online now   Reply With Quote
Old 01-13-2011, 11:09 AM   #1811
cannon's Avatar
Originally Posted by TAMAK View Post
Hey Guys,
They handle far different. You have to drive differently
Old 01-13-2011, 11:25 AM   #1812
kentech's Avatar
First limited batch should be ready in about 1 week I think.
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 01-13-2011, 11:41 AM   #1813
TAMAK's Avatar
Yes they do, just picking some brains. I also found that I can drive it harder in the first half of the race, but after that it seems to have slowed down and get loose.
Old 01-13-2011, 01:07 PM   #1814
F N CUDA's Avatar
Aint that the truth. Backend likes to step out, when it does, punch the throttle.
It's like pulling a trailer that's waggin around back there, hit the gas and it gets back in line. (more or less)
Legal bodies for this class have crap for wings, no help in the aero dept but when a real wing is on these cars they get locked in.
So like every type of racing, it's 99.9% tires.
.1% is getting the setup to support the frontend weight so it won't roll over and unload the rearend yet still allow it to turn.
Good luck with that.
Craig Hammon
Old 01-13-2011, 03:12 PM   #1815
gashuffer's Avatar
Trader Rating: 48 (100%+)
Hey Guys,
Take away some brake you might have it set to high. Also try adding more toe in in the rear that will make the a$$ hook more.
T-Sal
gashuffer is offline   Reply With Quote
Tamiya Championship Series Neil Rabara Racing Forum 21026 05-25-2017 08:50 AM
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5789 04-27-2017 10:11 PM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 724 04-03-2017 12:43 PM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 11:28 AM
