Old 01-05-2011, 04:22 PM   #1756
maxepower's Avatar
Originally Posted by F N CUDA View Post
#1 Don't let your diff slip whether you use plastic or aluminum outdrives. Check it often when new and tighten gently, it'll last a long time.
#2 Get the updated or an aftermarket idler gear, the original will last pretty well (if you follow #1) but the new ones are the ticket
Hey Max, will you open up tomorrow or Friday, I promise not to tell anyone else!
I'll close up.
Kevin,mark and Dave are there around three on Friday but you have to help clean up
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EXO-6,TA-07,TRF419,EVO-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 01-06-2011, 01:12 PM   #1757
cementsurfer86's Avatar
Thanks Cuda!
I remember that was the key with all the front drives, that diff has to be butter. Does Tamiya have a hop-up idler? I want to keep it TCS legal. (reason for buying the car in the first place) Thanks!
Jesse Anderson / JROY386 / R_
theRACERunderground - "Budget Champions"
www.theracerunderground.blogspot.com
cementsurfer86 is offline   Reply With Quote
Old 01-06-2011, 03:58 PM   #1758
F N CUDA's Avatar
Trader Rating: 30 (100%+)
Originally Posted by cementsurfer86 View Post
Thanks Cuda!
Yeh, they have a tuffer idler now but I don't have the part number.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 01-06-2011, 04:41 PM   #1759
Cool, I'll look it up, thanks!
Old 01-06-2011, 05:52 PM   #1760
stitchy's Avatar
RW Racing Acetal Idler Gear
Tamiya TRF201/FF-03 Reinforced 52T Ball Differential Gear Set
both in stock
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 01-06-2011, 05:54 PM   #1761
Sweet, thank you!
Old 01-08-2011, 07:22 AM   #1762
tcmodels's Avatar
upgrade your FF03 now
www.tcmodels.net - online hobby shop
tcmodels is offline   Reply With Quote
Old 01-08-2011, 12:45 PM   #1763
Send a message via AIM to Waco
Which in your collective opinion is best for the diff balls? Ceramics or Tungsten Carbide
Waco is offline   Reply With Quote
Old 01-08-2011, 12:52 PM   #1764
Man, I'm so excited to get my FF03!
Tamiya TT-01 drifter, LRP 21T motor
Traxxas Summit VXL
Raguvian is offline   Reply With Quote
Old 01-08-2011, 01:16 PM   #1765
sportpak's Avatar
Trader Rating: 26 (100%+)
Use the steel ones you can get on eBay. I think it was $12 for 100 balls. Build it right and you won't need too many of them. Save your money and buy things that matter more, like tires.
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Old 01-09-2011, 01:22 PM   #1766
Thanks for the quick assistance Sportpak, but I 'shotgunned' & bought both types , so I'm spoilt for choice & I want to know which should go in my 'main' diff (until the R-Spec geared diff comes along )
Thanks again
Old 01-10-2011, 06:41 AM   #1767
TAMAK's Avatar
Trader Rating: 28 (100%+)
I would say Ceramic, lighter weight means less rotational mass. But to tell you the truth I would close my eyes and pick a bag.
TAMAK is offline   Reply With Quote
Old 01-10-2011, 12:54 PM   #1768
Thanks for that, to tell the truth I was leaning towards the ceramics, so decision made!
Old 01-10-2011, 05:41 PM   #1769
I remember for the longest time, Tungstens were the ONLY way to go, but these Ceramics are so light and are just as smooth. I'd say every little bit helps in an already tight class.
Old 01-10-2011, 08:57 PM   #1770
Big Midget's Avatar
Trader Rating: 98 (100%+)
can someone post a link to some FF03 setups....
Dee & Mee Hobbies
Fastlane Raceway-wwwfastlanehobbies.com
Topeka On-Road Racing-Jake's R/C Pro-Am Topeka,Ks
www.ZigPhoto.com,RickyRacer Lidz,Absolute Tattoo,Fuzzy Dice Decals
Big Midget is offline   Reply With Quote
Tamiya Championship Series Neil Rabara Racing Forum 20853 Today 09:35 AM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 711 01-08-2017 09:27 AM
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5774 09-23-2016 10:49 PM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 12:28 PM
SEO by vBSEO 3.5.0
