Like Tree24Likes
Old 01-04-2011, 08:12 AM   #1741
SteveM's Avatar
Trader Rating: 134 (100%+)
Originally Posted by Big Midget View Post
Dang.....
In reality, the kit is a simple build and all of the plastic parts are of a softer plastic so the Philips screws aren't that much of an issue. There are a few though that I did replace with stainless ones I had in my pit box. The rest were fine.
SteveM is offline   Reply With Quote
Old 01-04-2011, 08:20 AM   #1742
Big Midget's Avatar
Trader Rating: 98 (100%+)
Thanks for heads up Steve
I just ordered a screw kit from ewippler. It a blue anodized 7075 aluminum kit
Dee & Mee Hobbies
Fastlane Raceway-wwwfastlanehobbies.com
Topeka On-Road Racing-Jake's R/C Pro-Am Topeka,Ks
www.ZigPhoto.com,RickyRacer Lidz,Absolute Tattoo,Fuzzy Dice Decals
Big Midget is offline   Reply With Quote
Old 01-04-2011, 08:33 AM   #1743
SteveM's Avatar
I fear that the aluminum is even softer than the kit stock Philips screws which is why I went to stainless. I've used aluminum screws in some TC3 sedans in the past and they were too easy to strip.
Being a FWD car the maintenance is greatly reduced compared to a 4wd sedan. The key maintenance area for me has been the transmission and diff. The good news is that the entire tranny can be removed intact from the chassis by removing only 6 screws. I'd recommend you consider stainless for these screws at the very least.
Old 01-04-2011, 08:51 AM   #1744
Big Midget's Avatar
you think they'd be easy to strip being there 7075 aluminum......
I think that the same material they make cooling heads from.
Dee & Mee Hobbies
Old 01-04-2011, 09:01 AM   #1745
Johnn27's Avatar
Trader Rating: 69 (100%+)
Default universals
what swing shaft/universals fit the ff03???
Johnn27 is online now   Reply With Quote
Old 01-04-2011, 09:27 AM   #1746
SteveM's Avatar
With the stock plastic outdrives I've been told that 46mm work, but with the aluminum outdrives you need 44mm
Old 01-04-2011, 09:29 AM   #1747
I have alu diff outdrives and i do run with the 46mm swing shafts
addicted2blue is offline   Reply With Quote
Old 01-04-2011, 09:29 AM   #1748
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
Just make sure you pre-thread all the screws with a steel screw first. Ive always used aluminum/titanium screws for my Tamiyas...just pre-thread and be careful. I believe Eric gets his screws from www.Fastener-Express.com and they are decent screws...just take your time and it should be fine.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 01-04-2011, 09:58 AM   #1749
Big Midget's Avatar
Thanks Core
Dee & Mee Hobbies
Old 01-04-2011, 09:59 AM   #1750
infokiz's Avatar
I'm running 46mm shafts too and no problems
infokiz is offline   Reply With Quote
Old 01-04-2011, 08:10 PM   #1751
dag32's Avatar
Trader Rating: 100 (100%+)
Pardon the interruption but I have an awsome FF03 Pro for sale here
★ David Garcia ★
dag32 is offline   Reply With Quote
Old 01-05-2011, 12:22 PM   #1752
cementsurfer86's Avatar
Preparing to pick up a new FF03 in the coming weeks, any weak spots that you guys have found so far? It looks like a stout ride and I'm excited to get back into FWD racing, but I figured I'd check.
Jesse Anderson / JROY386 / R_
ThreeEightSix / Sticky Kicks RC / Schumacher
theRACERunderground - "Budget Champions"
www.theracerunderground.blogspot.com
cementsurfer86 is offline   Reply With Quote
Old 01-05-2011, 12:42 PM   #1753
maxepower's Avatar
Cool
The length of the universals is also dependent on the width of your suspension blocks. The "A" blocks are narrower than the" D" blocks so the wider your stance the longer The shafts you use.
Just my 2$
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 01-05-2011, 12:55 PM   #1754
F N CUDA's Avatar
Trader Rating: 30 (100%+)
#1 Don't let your diff slip whether you use plastic or aluminum outdrives. Check it often when new and tighten gently, it'll last a long time.
#2 Get the updated or an aftermarket idler gear, the original will last pretty well (if you follow #1) but the new ones are the ticket
Hey Max, will you open up tomorrow or Friday, I promise not to tell anyone else!
I'll close up.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 01-05-2011, 01:54 PM   #1755
infokiz's Avatar
Just my 2$
Yes that would make a diffrence. I should have stated that I'm using the kit ones.
Tamiya Championship Series Neil Rabara Racing Forum 21158 Today 01:41 PM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 730 08-15-2017 08:06 PM
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5791 08-04-2017 09:31 PM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 11:28 AM
