Like Tree21Likes
Old 01-03-2011, 04:58 PM   #1726
gashuffer's Avatar
Trader Rating: 48 (100%+)
Originally Posted by cannon View Post
I think that depends on the amount of preload.
Yes I know, but I took all of it out and it still sits to high. I guess i'll have to use limiters and remove the 1mm shims that go under the suspension arm mounts.
T-Sal
gashuffer is offline   Reply With Quote
Old 01-03-2011, 05:28 PM   #1727
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by gashuffer View Post
How are you lowering the ride height in these cars. I am trying to achieve a 5mm ride height both front and rear, but the front is just too high? I set it up as per instructions and I took all of the pre load out of the front shock but it's still high.
The Front susp link rod length according to the directions is 12.5mm gap between the Ball ends.
Mine are 12mm.
You should be able to get your ride height by adjusting those Huff.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 01-03-2011, 05:44 PM   #1728
F N CUDA's Avatar
Trader Rating: 30 (100%+)
Mine is built to spec and with the firm blue springs up front I am almost out of threads for the preload adjustment too.
Others have used the shorter springs from the sets for the mini shocks.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 01-03-2011, 06:20 PM   #1729
gashuffer's Avatar
Where are you sitting at?
T-Sal
Old 01-03-2011, 07:08 PM   #1730
F N CUDA's Avatar
In front of my comp... oh, ride height?
I can go below 5mm no problem, I have the Rodzilla setup from the Tamiya website (I also just ask cuz he's at the same place as me runnin his car ).
If you notice, the arms are flipped (reversible), so shock mounts and even the adjustable links are different so that could be causing some difference in setup also.
Lower link end is in the outer hole on the arm.
Another guy has the 1mm lower spring cups at the base of his springs which also allows it to go lower.
Craig Hammon
Old 01-03-2011, 10:01 PM   #1731
Hi guys, please post your FF03 bodies. Here is my first FF03 body.....
seasons29 is offline   Reply With Quote
Old 01-03-2011, 11:23 PM   #1732
Hey guys I have some quick questions about this car:
Is the battery tray big enough to fit hardcase lipos? My hardcase lipo is the same as a six cell battery in width and height but it is about 9 mm longer. Will this fit? That's a deal breaker for me if it doesn't.
Also, how would the FWD handle a 3800kv Castle brushless?
Thanks!
Raguvian is offline   Reply With Quote
Old 01-04-2011, 01:06 AM   #1733
Send a message via AIM to Waco
Thanks!
I have measured the battery tray with my cheapo very-near (vernier ) & the length is 140mm & the width is 49mm. I have a Trak Power, HPI Plazma & a Core RC hard case LiPos as well as a variety of NiMhs & they fit fine...
The only thing I did was Dremel a hole at the back (although there is a hole at the front for this) to allow more space for the wires to exit without being squeezed (I prefer to wire it that way).
When I run either the LiPos or the NiMhs, I have plenty of space & I should perhaps consider using the foam strips provided to stop the small amount of 'shift' within the battery tray to improve handling.
Regarding the motor, there are plenty of drivers out there that can give you advice, but you have to remember that this is a Front Wheel Drive & any injudicious use of the throttle & the front will 'let go', so smoothness is key, whatever power motor you run.
That's my penny worth, I hope it is of use
Waco is offline   Reply With Quote
Old 01-04-2011, 06:37 AM   #1734
Big Midget's Avatar
Trader Rating: 98 (100%+)
Any chance the Pro kit come's with hex head screws?
Dee & Mee Hobbies
Fastlane Raceway-wwwfastlanehobbies.com
Topeka On-Road Racing-Jake's R/C Pro-Am Topeka,Ks
www.ZigPhoto.com,RickyRacer Lidz,Absolute Tattoo,Fuzzy Dice Decals
Big Midget is offline   Reply With Quote
Old 01-04-2011, 06:47 AM   #1735
SteveM's Avatar
Trader Rating: 128 (100%+)
Nope.
SteveM is offline   Reply With Quote
Old 01-04-2011, 06:53 AM   #1736
Big Midget's Avatar
Dang.....
Dee & Mee Hobbies
Old 01-04-2011, 06:56 AM   #1737
TryHard's Avatar
hence why I ordered mine with the Ti screw kit from RC Mart.... can't stand phillips'. Having said that, probably got enough spare screws in the pit box, so some Ti''s might be transplanted to my 417
TryHard is online now   Reply With Quote
Old 01-04-2011, 07:18 AM   #1738
Big Midget's Avatar
I hear ya! I cant build a car using phillips head screws. I knew I saw a TI kit some where. To bad RcMart was not in the U.S.
ewippler sells a blue anodized aluminum kits made from 7075 aircraft grade aluminum.
He sells them here on Tech and on ebay under the same user name.
I'll probably buy a set just waiting on a PM. He ships fast.
Dee & Mee Hobbies
Old 01-04-2011, 07:48 AM   #1739
NiMo's Avatar
put a small bit of grease over the end of the screw or the hole before you put the screw in for the first time, this makes it easier to make the thread and is less effort on the screw driver, plus you can feel when it is seated easier.
As for ride height, I must have built mine wrong, cos the front (when loaded for race) sat at 3mm, do I had to raise it to stop the front from scraping over the bumps
NiMo is offline   Reply With Quote
Old 01-04-2011, 08:05 AM   #1740
Thanks! I think you just sold me on the car.
By the way, I know this is a random question, but does the Civic VTI body come with headlight decals?
The picture from Tower hobbies shows that the lights are painted black, but I don't want to go for that race scheme (due to my painting inability) and would like the headlight decals instead.
Tamiya Championship Series Neil Rabara Racing Forum 20960 Today 07:10 AM
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5782 03-26-2017 03:14 AM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 723 02-09-2017 08:16 AM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 11:28 AM
