Like Tree37Likes
Old 01-02-2011, 07:42 PM   #1711
cannon's Avatar
Trader Rating: 35 (100%+)
Originally Posted by Big Midget View Post
Can anyone tell me where I can get white lettered tires like this?
I believe the white lettering on the tire is actually part of the sticker set for the XEiV bodyshell
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 01-02-2011, 07:44 PM   #1712
Big Midget's Avatar
Trader Rating: 99 (100%+)
hmmm I wander if I can order that sheet seperate....
Dee & Mee Hobbies
Fastlane Raceway-wwwfastlanehobbies.com
Topeka On-Road Racing-Jake's R/C Pro-Am Topeka,Ks
www.ZigPhoto.com,RickyRacer Lidz,Absolute Tattoo,Fuzzy Dice Decals
Big Midget is offline   Reply With Quote
Old 01-02-2011, 07:46 PM   #1713
cannon's Avatar
Originally Posted by gashuffer View Post
No I built them to the size in the instructions. Wouldn't lenghthening the push rod make the car taller?.
I think that depends on the amount of preload.
Old 01-03-2011, 12:51 AM   #1714
Send a message via AIM to Waco
Since we brought up bodies I chose the Beams Integra
Me too! That takes the bumper, although I had to shave a little off the sides to let it fit & I hear it's quite a popular shell for its aerodynamics, etc.
My son runs an old (HPI) BTCC Astra which also takes the bumper & that handles brilliantly, but I can't find them anywhere anymore...
Waco is offline   Reply With Quote
Old 01-03-2011, 02:01 AM   #1715
Originally Posted by caltek1 View Post
Out of curiosity has anyone tried flipping the rear arms and placing the rear shocks inboard similar to a MO5L. I see it as a tuning/setup option on page 21 of the instructions. Yes I know your not supposed to read them.
I was just wondering if standing the shocks up similar to the MO5 would change the handling much. I might have to try it out.
I run my FF03 in long configuration with a VW Golf body.
Thanks,
Calvin.
thats my current set up... the weight is more center and the car handles well in corners plus you get to save your TRF shocks from hitting as it is in the inside part of the chassis
jebolution is offline   Reply With Quote
Old 01-03-2011, 02:15 AM   #1716
caltek1's Avatar
Trader Rating: 36 (100%+)
jebolution
I am changing mine over tonight and hopefully if the weather god's are good, will get to test at the track tomorrow.
Thanks for the reply.
Calvin.
caltek1 is offline   Reply With Quote
Old 01-03-2011, 02:26 AM   #1717
im using a beams integra shell and i did not shave any of the bumper foams...
Old 01-03-2011, 06:10 AM   #1718
TAMAK's Avatar
Trader Rating: 28 (100%+)
I am having problems with clearance for my dogbones on a stock FF03. Its almost as if the drive side bone does not have enough room when the wheel is turned. I talked to a local racer and he said I have to build it and install it differently from the instructions.
Any thoughts?
TAMAK is offline   Reply With Quote
Old 01-03-2011, 06:13 AM   #1719
infokiz's Avatar
Any thoughts?
You built the diff wrong. You missed the part where your supposed to flip the diff and then put the screw in. I did the exact same thing.
infokiz is offline   Reply With Quote
Old 01-03-2011, 06:44 AM   #1720
NiMo's Avatar
Another diff build victim ... lol
Hands up who HASN'T built it wrong
NiMo is offline   Reply With Quote
Old 01-03-2011, 06:47 AM   #1721
TAMAK's Avatar
Thanks for the support guys, I feel much better. Time to turn it around. lol..
Old 01-03-2011, 09:17 AM   #1722
Yes, I'm one of those who have done it too, although I didn't spot the mistake until the diff had unscrewed itself & burned the diff balls!
As a result of this little omission, I have bought the 3Racing diff & I have an option of Ceramic or Tungsten Carbide diff balls... I'd like your thoughts as to which is best? I'm also awaiting arrival of the hardened diff (may as well go the whole hog while I'm at it )
Old 01-03-2011, 10:21 AM   #1723
Big Midget's Avatar
I've done it on a TA05
Dee & Mee Hobbies
Old 01-03-2011, 11:22 AM   #1724
speedemall's Avatar
Trader Rating: 58 (100%+)
I put these decals on the tires specifically for bookshelf display. If you plan to run them and keep them intact you have to run a hard insert. If not they will be destroyed the first time you take a turn at speed. Tamiya does not sell them seperate from the body set decal sheets,you have to buy the whole set.
speedemall is offline   Reply With Quote
Old 01-03-2011, 12:44 PM   #1725
F N CUDA's Avatar
Trader Rating: 31 (100%+)
Default tire stickers
Get a hold of Sean at http://tqrcracing.com/ for separate tire logo stickers.
I've seen them in his shop.
Tell him 'cuda sent ya.
Craig Hammon
F N CUDA is offline   Reply With Quote
Tamiya Championship Series Neil Rabara Racing Forum 21198 10-19-2017 06:51 PM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 732 10-12-2017 02:34 PM
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5806 09-22-2017 03:06 PM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 11:28 AM
