Like Tree23Likes
Old 01-01-2011, 12:12 AM   #1696
cannon's Avatar
Trader Rating: 35 (100%+)
Originally Posted by foampervert View Post
The brilliant thing about fwd is that, setup right... You'll really save on tires!
You'll find that you need to drive more aggressively with less brakes...
It's so easy to setup and run, people will soon be keen to try fwd too... And a class is born.
I have tried with touring shells, only issue is front motor clearance.
Works really well as long as you use super high front downforce shells like R9r... With a substantially trimmed wing.
Shalom and God bless!
-Alexander
Dont quite understand the high front downforce bit .. theFF03 already has weight concentrated over the front with very little rear downforce. Would have thought a normal wing on the rear would be fine
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 01-01-2011, 01:18 AM   #1697
Send a message via AIM to Waco
And this is where discussions & difference of opinion begins...
I run all my Tamiya FWDs with the same springs front & rear & find that I do well as I am able to do high or low speed corners (& even 'monster' corner dots on the odd occasion) without the rear end getting 'twitchy', although I do find that the front does 'slap' hard if I get too much air Time . I can do the same with or without a body shell & therefore downforce is not an issue for me.
It is a matter of preference, of course, which makes this class so much more involving as opposed to the 'point & squirt' technique that 4 wheel drives seem to offer (again, my humble opinion).
The only problem I'm having (& others from reading some of the other posts too) is trying to get a separate Front Wheel Drive class sanctioned locally as although the FF03 does aquit itself very well, it does lose some 'punch' out of corners & finals grid starts (although that may change with the geared diff! )
Ultimately, the FWD system is great fun & with the differing opinions on how to set it up makes it competative racing
Waco is offline   Reply With Quote
Old 01-01-2011, 07:01 AM   #1698
sportpak's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Big Midget View Post
Thanks for all the info, I still really want one of these cars the only thing that is holding me back is that I'll be the only guy with one at the track and no class to race it in......
So idk, are they so cool to drive that I cant go wrong..... also can I run a normal TC body on the car like speed 6's and such...
I've been considering getting one and trying VTA with it. The slightly lower speed and shallower talent pool (in general) should help even the feild. I myself worry about the front motor and bumper clearing typical VTA bodies.
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Old 01-01-2011, 12:46 PM   #1699
Big Midget's Avatar
Trader Rating: 98 (100%+)
I thought about trying VTA with it as well but a think a 4wd chassis is required for VTA...
I just ordered a FF03 Pro off the ol-ebay.
What are some traditional bodies for this class/car?
Would it be odd to run a traditional TC body?
I want to set the car up as it should be with the proper body.
Dee & Mee Hobbies
Fastlane Raceway-wwwfastlanehobbies.com
Topeka On-Road Racing-Jake's R/C Pro-Am Topeka,Ks
www.ZigPhoto.com,RickyRacer Lidz,Absolute Tattoo,Fuzzy Dice Decals
Big Midget is offline   Reply With Quote
Old 01-02-2011, 05:27 PM   #1700
gashuffer's Avatar
Trader Rating: 48 (100%+)
How are you lowering the ride height in these cars. I am trying to achieve a 5mm ride height both front and rear, but the front is just too high? I set it up as per instructions and I took all of the pre load out of the front shock but it's still high.
T-Sal
gashuffer is offline   Reply With Quote
Old 01-02-2011, 05:50 PM   #1701
cannon's Avatar
I would say that you have built the front arm to shock cam link too short. Lengthen that link
Old 01-02-2011, 05:57 PM   #1702
Big Midget's Avatar
can anyone tell me if the stock pro kit comes with tall body mount post for the rear?
I'm also having trouble deciding on a body, anyone have any suggestions???
I'm thinking about the Civic Vti body.
Dee & Mee Hobbies
Old 01-02-2011, 06:08 PM   #1703
cannon's Avatar
Think before you post. The Pro kit is the same as the standard kit except for some alloy parts. The standard kit comes with the Civic body. So what does that suggest about the length of the body posts?
There are a heap of FWD bodies that suit this car:
Civic
Accord
Pug 406
Alfa 156
VW Golf
etc etc.
Just bear in mind that for the majority of the bodies the front foam bumper must be removed because the motor out front takes up all the space under the body
Old 01-02-2011, 06:17 PM   #1704
Big Midget's Avatar
Thanks for the heads up on the body post. This is my first fwd TC. I'm not famailar with the differences between the two kits other than the hopup's.
Dee & Mee Hobbies
Old 01-02-2011, 06:41 PM   #1705
Big Midget's Avatar
Originally Posted by speedemall View Post
.com
Can anyone tell me where I can get white lettered tires like this?
Dee & Mee Hobbies
Old 01-02-2011, 06:42 PM   #1706
F N CUDA's Avatar
Trader Rating: 30 (100%+)
Wouldn't that apply to everyone?
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 01-02-2011, 06:54 PM   #1707
Trader Rating: 18 (100%+)
Default Suggest a 48 pitch spur and pinion for 13.5
Anyone know a good starting point for 48 pitch spur and pinion for a 13.5 setup, I'm going to use an epic duo2 13.5. What is the fdr for the ff03 anyway.
Thanks for any replies in advance. Or checking other posts should I be using 64 pitch.
lyrragnus is offline   Reply With Quote
Old 01-02-2011, 06:57 PM   #1708
gashuffer's Avatar
No I built them to the size in the instructions. Wouldn't lenghthening the push rod make the car taller?.
T-Sal
Old 01-02-2011, 06:58 PM   #1709
gashuffer's Avatar
Since we brought up bodies I chose the Beams Integra
T-Sal
Old 01-02-2011, 07:36 PM   #1710
Big Midget's Avatar
The internal drive ratio is 2.60
I'd say just start with whatever you have for pinion gears. Then adjust when you get to the track.
Dee & Mee Hobbies
Tamiya Championship Series Neil Rabara Racing Forum 21026 05-25-2017 08:50 AM
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5789 04-27-2017 10:11 PM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 724 04-03-2017 12:43 PM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 11:28 AM
