Old 12-22-2010, 04:13 AM   #1636
gdiddy's Avatar
Default any suggestions?
what would be a good baseline setup for indoor carpet. running 17.5 with tekin rs timing profile set to 1.
The desired effect is what you get when you improve your interplanetary funksmanship.
gdiddy is offline   Reply With Quote
Old 12-22-2010, 04:40 AM   #1637
Bad-Andy's Avatar
This is my carpet setup.
http://www.rctech.net/forum/8270708-post1545.html
The only changes I've made since were to go to 600 oil in the front, removed the rear sway bar, and added the red sway bar to the front.
Bad-Andy is offline   Reply With Quote
Old 12-22-2010, 07:38 PM   #1638
gdiddy's Avatar
thanks Bad Andy
Old 12-23-2010, 07:23 AM   #1639
Hi guys,
Would like to check if 13.5 brushless motor will be too much for FF03?? I will be running asphalt outdoor...
Currently looking for new set of motor for this chassis..
thanks
hansenhon is offline   Reply With Quote
Old 12-23-2010, 10:34 AM   #1640
infokiz's Avatar
Originally Posted by hansenhon View Post
Hi guys,
thanks
That would depend on the size of the track and the type of layout it is. If it's large, fast and flowing lay out I would say your ok. If it's small and technical then I think it would be to much motor.
The beauty of the FWD chassis is that it can only handle so much power, to much and any benefit is lost in wheel spin.
infokiz is offline   Reply With Quote
Old 12-23-2010, 12:15 PM   #1641
cannon's Avatar
Trader Rating: 35 (100%+)
Hi guys,
thanks
Here in Australia we are using the Hobbywing Justock ESC with a 13.5 motor (non timed ESC and motor). It has the right amount of speed.
This ESC system is also being used in the FWD class at the TITC event in Thailand (already has 40 entries for the class)
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 12-23-2010, 03:16 PM   #1642
RossoTorro's Avatar
I'm using Xerun 60A with 13.5T Team Powers. Low boost and low gearing, just enough to reach top speed on straight. 20T pinion with stock spur in fact.
Very happy with this setup. Cheap and reliable, cost me less than 120 USD incl. shipping.
RossoTorro is offline   Reply With Quote
Old 12-23-2010, 10:34 PM   #1643
thanks to all the reply...
Think I will go ahead and source for a 13.5T brushless motor then..
Thanks a lot
Old 12-25-2010, 10:53 AM   #1644
gashuffer's Avatar
Trader Rating: 48 (100%+)
Redundant question. Besides the TRF shocks what is the difference other than the blue bits between both the pro and non pro version? Does the non pro come with bearings?
Merry Christmas.
T-Sal
gashuffer is offline   Reply With Quote
Old 12-25-2010, 01:08 PM   #1645
infokiz's Avatar
Merry Christmas.
The pro includes the 5mm low friction ball links and includes bearings for everything but the rockers and the steering. There is no body, motor or tires and inserts with the pro.
Old 12-25-2010, 01:27 PM   #1646
SteveM's Avatar
Trader Rating: 125 (100%+)
The Pro doesn't include bearings for the suspension rockers either.
SteveM is offline   Reply With Quote
Old 12-25-2010, 02:32 PM   #1647
gashuffer's Avatar
So it's safe to say the non pro is the better value. I have a set of TRF shocks that I can just throw on. Most if not all shops online are out of stock on FWD bodies
T-Sal
Old 12-25-2010, 02:58 PM   #1648
If weight&TRF dampers isn't an issue then the non pro is the better version.
This cause of the motor, body and perhaps the ESC (this isn't bad at all).
Not sure if those tires are the standard medium narrow ones or the A-type tires.
addicted2blue is offline   Reply With Quote
Old 12-25-2010, 10:30 PM   #1649
F N CUDA's Avatar
Trader Rating: 30 (100%+)
No esc included in the non pro and the body really isn't the trickest thing on the planet, no wing and can't add a wing under TCS rules.
These things like wings.
So you get to buy shocks, better body and tires (good ones) anyway.
Best deal?
Your choice.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 12-25-2010, 10:51 PM   #1650
stitchy's Avatar
Default on top of the TRF shocks...
If you don't care about the blue ball studs and wheel nuts (), consider the upgraded servo saver, motor plate and nice turnbuckle parts
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Tamiya Championship Series Neil Rabara Racing Forum 20852 Yesterday 08:29 PM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 711 01-08-2017 09:27 AM
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5774 09-23-2016 10:49 PM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 12:28 PM
SEO by vBSEO 3.5.0
