Old 11-28-2010, 12:53 PM   #1456
Jerry P's Avatar
Trader Rating: 44 (100%+)
Congrats to Mike Haynes for the Win in TC Mod at the US Indoor Champs in clevenland. Huge win for the TCX and a second place finish in Superstock.
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 11-28-2010, 08:12 PM   #1457
I've only had the car for 2 weeks and i will say this, the box stock set up was not bad. The car is very fast through the corners. My local track is carpet, and Gen-3 ozite at that. Our tire of choice is the Salaris medium with medium insert. Traction is very high and I believe that to be a lot of the reason for the aggressive nature of the car's steering.
I'm running the kit 2 hole shock pistons. What would happen if I switched to the 3 hole shock pistons. Would that help settle the car down or make matters worse?
silky is offline   Reply With Quote
Old 11-28-2010, 09:44 PM   #1458
STLNLST's Avatar
Trader Rating: 19 (100%+)
3 hole is like night and day IMO. Get your hands on some and you'll feel the difference. Don't know if it will solve your problem but it won't hurt the performance.
STLNLST is offline   Reply With Quote
Old 11-29-2010, 12:50 AM   #1459
Originally Posted by EJ20 View Post
HPI #72111
Shim set M3x5 (M3x5x0.1, 0.2, 0.3mm/10 each)
Is this not too big for the shock shaft? From what I can remember the shaft is 2mm ID! Don't you need 2mm shims?
mr lee is offline   Reply With Quote
Old 11-29-2010, 01:01 AM   #1460
Originally Posted by jag88 View Post
Hiro, will this chassis be an option ??
Thats the Chassis sometimes referred to as "ACE" or as "G-Tech". I am running it as well. It is designed and manufactured in Germany and most of the Top Runners here use it.
Who knows, maybe HB Europe will take it over and officially produce it in the near future
FrankH is offline   Reply With Quote
Old 11-29-2010, 01:26 AM   #1461
ali_g's Avatar
Where can we order it?
☆ JU.C RACING ☆
https://www.facebook.com/Ju.Cracing
ali_g is offline   Reply With Quote
Old 11-29-2010, 06:15 AM   #1462
Ok so I received my TCX and started building it over this past weekend. Is it ok to have so much left/right play in the diffs and layshaft?
I have purchased some Tamiya 4mm shims for the layshaft (as the kit was missing a couple of copper shims ) and will get rid of most of the play, will leave a slight amount!
What about the diff's? Is it ok to have so much play? Is it designed to have this much play or is it HB's way of saying it will work but we left out the shims to cut costs and if you want to be competitive then you need to spend some more money making it better? Why did they just not machine the bulkheads so there is less play and minimal, if any shimming would be required???....or was this done, especially the rear, to catter for a gear diff?
Last HPI/HB product I owned was 2 x Pro 4 Hara's and these kits had all you needed, including spare shims and lots of little bits and pieces to use for spares....plus a set of tools
What does everyone else do? leave the play? If so how does this effect wear on the belts and pulleys?
Old 11-29-2010, 09:10 AM   #1463
Trader Rating: 45 (100%+)
Shim away!! Good you bought the 4mm shims cause you'll need it for the steering rack. I'd recommend buying the 10mm and 3mm shim packs as well. I'd rather have the tolerances allowing for shimming than having the spacing too tight causing binding. And as for the play, of course you don't want too much too keep wear down and make the energy go where it needs too.
Apex is offline   Reply With Quote
Old 11-29-2010, 09:26 AM   #1464
Hi jag88,
I don't think the chassis is made by us like others mentioned. As research and development, we have been testing several different chassis for option parts but we still haven't finalized them yet. I will let you know once we are ready to produce something very good.
Thanks,
Hi-LowBlow is offline   Reply With Quote
Old 11-30-2010, 04:08 AM   #1465
Cool thanks! I thought I would need to shim the steering a little as well.........
Old 11-30-2010, 06:02 PM   #1466
LOSI123's Avatar
Trader Rating: 63 (100%+)
Have HB Fixed the weird rear toe issues that they had with the last three cyclones (and please dont some one come on here and act like it never happened)?
also is there steel front drive shafts available for this car.
LOSI123 is offline   Reply With Quote
Old 11-30-2010, 06:12 PM   #1467
Dog Bone's Avatar
?? Sorry, I really don't know what you mean. I have two TC's, and a TCX, and I don't know what you mean by 'rear toe issue'. Can you explain?
Not yet.
Ken Miller
T4 2015
CRC Xti WC/GenX-10
Dog Bone is offline   Reply With Quote
Old 11-30-2010, 06:31 PM   #1468
Not yet.
I also have a TC-S, TC and TCX and am not sure what he's refering to either. I do know that the toe blocks don't seem to have the correct ratings on them. My 2.0 is really 2.5 and 2.5 is a 3.0 on the guages, other than that all is fine. Please explain......
Cyclone Bender is offline   Reply With Quote
Old 11-30-2010, 08:42 PM   #1469
STLNLST's Avatar
Toe blocks are fine. The issue is in the plastic hubs. Run the alum one's or Tamiya hubs and the toe will be spot on.
Old 12-01-2010, 10:03 AM   #1470
Potoczak's Avatar
Trader Rating: 109 (100%+)
If anyone is looking to buy a tcx kit I have a brand new in box kit. PM me for details if interested. Thanks
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
