Old 11-24-2010, 09:59 AM   #1426
you can also use the TOP pieces with 3 holes in.
I tryed it because the HB pieces where nowhere in stock.
stofke is offline   Reply With Quote
Old 11-24-2010, 10:20 AM   #1427
san.'s Avatar
Trader Rating: 59 (100%+)
Originally Posted by Apex View Post
Anyone have an extra set of the machined 1.1mm 3 hole pistons they want to part with (part#hpi 73524)? PM me if you do. Thanks!
Or does anyone know if the Tamiya 3 hole pistons will work in the TCX shock?
Tamiya TRF 1.1mm 3 hole piston is a direct fit. It's what I'm currently using.
Awesomatix USA||Roche RC USA||Sanwa
san. is offline   Reply With Quote
Old 11-24-2010, 10:56 AM   #1428
Korey Harbke's Avatar
Tamiya 3 hole pistons are what I have been using. Just put a small shim to take up any slack that is between the e-clips and the piston. You have to do this with the HB pistons as well.
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 11-24-2010, 11:05 AM   #1429
Trader Rating: 45 (100%+)
Originally Posted by Korey Harbke View Post
+1
Thanks for the replies everyone! What size are the small shims to take up the slack?
Apex is offline   Reply With Quote
Old 11-24-2010, 07:25 PM   #1430
EJ20's Avatar
HPI #72111
Shim set M3x5 (M3x5x0.1, 0.2, 0.3mm/10 each)
- HOTBODIES - AHRP -
EJ20 is offline   Reply With Quote
Old 11-25-2010, 03:15 AM   #1431
Originally Posted by EJ20 View Post
HPI #72111
Nice, already have them just in case I needed to shim the suspension rods.
Old 11-25-2010, 10:10 PM   #1432
Robertcooper88's Avatar
Trader Rating: 15 (100%+)
Hello,
Just finished building my TCX. Has anyone had a problem with the shocks being too short? I have the ride height set at 5mm all the way around and the shocks are all the way preloaded. I have tried to unscrew the shock end of the shock to lengthen it but little/no luck. Also, my kit did not come with any longer ends. Does anyone have any ideas to help me out?
Thank you
DischargeRC.com - Race-Opts MTS T2 - TRINITY FOR POWER
Robertcooper88 is offline   Reply With Quote
Old 11-25-2010, 11:18 PM   #1433
Originally Posted by Robertcooper88 View Post
Hello,
Thank you
Mine and a mate's are the same
markrobinson is offline   Reply With Quote
Old 11-26-2010, 02:28 AM   #1434
AGNO's Avatar
Hello,
Thank you
Here I posted a photo
Hot Bodies TCX
The shock towers are hig version for maximum grip, if one so desires can be lowered using the "upper bulk head Moorspeed # 61316.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 11-26-2010, 05:14 AM   #1435
warnos's Avatar
Default for a tcx
Anyone know the cheapest place to get a TCX at the moment?
Everyone seems to be putting the prices up before xmas..
Cheers
TCX Smokem / F104 wgp
Major Sponsor : Visa Card
TEAM SMA - www.smaracing.org
warnos is offline   Reply With Quote
Old 11-26-2010, 07:36 AM   #1436
Stormer - $409.99
Old 11-26-2010, 08:54 AM   #1437
ali_g's Avatar
Hot Bodies TCX
any major difference?
☆ JU.C RACING ☆
https://www.facebook.com/Ju.Cracing
ali_g is offline   Reply With Quote
Old 11-26-2010, 10:36 AM   #1438
AGNO's Avatar
With high towers one has more grip but less stability (more roll), with low towers less grip but more stable, at least this is my impression, I think depends on the position of the piston damper, with high towers one has the piston down then has over a larger amount of oil compared with low towers.
Old 11-26-2010, 12:16 PM   #1439
jag88's Avatar
I thought that the bulkheads were moved in on the TCX so I'm surprised to see the tower from the Andy Moore version fits the TCX, or am I missing something hear ...
jag88 is offline   Reply With Quote
Old 11-26-2010, 01:40 PM   #1440
AGNO's Avatar
The tower is different, the upper bulkheads are compatible, replacing them change the height of the tower
