Old 11-22-2010, 01:47 PM   #1411
jackdani's Avatar
Originally Posted by VooDooPH View Post
had a similar problem running on asphalt. when the traction came up i could barely drive the car around a corner. seemed the front was grabbing too hard so the rear would swing around easily. to help, we widened the rear track width (6mm hexes), removed the rear swaybar, removed the shim on the top camber link, and went from pink to gold springs in front (kept the silver springs at the rear). also tried running heavier oil (currently running 65wt in front and 55wt in the rear). easier to drive now but it's still a hand full for me. hths
had a similar problem with my schumacher, going crazy triyng to understand which was the cause...finally i got it..i had too much steering for the truck,
almost every turn my back waa turning around,
it was just one second to reduce streering to 80% and i was fast enought to decrease 3 seconds.
allways try the easiest first!
jackdani is offline   Reply With Quote
Old 11-22-2010, 04:01 PM   #1412
Voodoo, here was my setup. I think we ran on the same track and series.
- 40wt oil with HPI 2 hole pistons
- HPI silver rear, Tamiya blue front springs
- medium roll bars front rear
- 3deg rear toe in
- followed the Hara setup
- negative steering expo and dual rate, depending on the grip
- I do not put tire sauce on the front
I think widening the rear lessens the side bite on that end and might worsen the situation. Try narrower rear or widen the front. See you this weekend, let's try to set it up. Or if you want to buy my car, even better
Good luck in Bangkok!
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 11-22-2010, 08:16 PM   #1413
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
- 3deg rear toe in
think i found my set-up already... worked well last sat during practice. but i'm still thinking if i'll use the TCX or the other kit...
not going to bkk...
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 11-22-2010, 09:59 PM   #1414
mdowney's Avatar
Trader Rating: 21 (100%+)
What do these two things mean?
Mike Downey
I try all of the RC kits and usually race at Tacoma RC Raceway
mdowney is offline   Reply With Quote
Old 11-22-2010, 11:36 PM   #1415
Hi mdowney,
Dual rate - If your steering is set full 100% left / right, dual rate can lessen the travel (e.g. 80%). So less steering angle.
Expo - Not all radios have this feature. You can adjust how fast / slow the steering reacts.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
Old 11-23-2010, 02:30 AM   #1416
VooDooPH's Avatar
agno, what length are your rear universals that you use with the 3racing gear diff? 44 or 46mm?
btw, might want to also try switching back to the ball diff when the traction goes up.
Old 11-23-2010, 05:14 AM   #1417
AGNO's Avatar
With the gear diff.3 Racing you use 44, 46 are too long.
On carpet I used the POM ball diff. with axle shafts 46.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 11-23-2010, 05:35 AM   #1418
AGNO's Avatar
Regarding the gear diff. no one has tested at the front?
I have prepared one with 100,000 cps, but still I have not tried, could work well on carpet?
Old 11-23-2010, 06:34 AM   #1419
mangoman's Avatar
Hi mdowney,
Exponential is relation to the amount which your steering changes relative to how you turn your wheel. Instead of the steering on your radio and servo in your car changing at a linear (same) rate it changes at an exponential rate.
IE. I think negative steering exponential mean initially when you turn the radio wheel the steering moves a small amount servo. The more you turn the steering off center the more and more the servo turns. So around the center of the steering the car is very docile but as you turn the wheel further left and right its gets more sensitive.
Personally i do not like using exponentials as it can get to the point in the mid-upper band where the steering (or acceleration if you set it on your throttle) gets ever more sensitive.
But to each their own.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 11-23-2010, 06:37 AM   #1420
jag88's Avatar
I run a gear diff in the front and a ball diff in the back on carpet (17.5 rubber). 200,000 is the lowest I've gone and have tried up to 500,000 with good results.
jag88 is offline   Reply With Quote
Old 11-23-2010, 06:38 AM   #1421
VooDooPH's Avatar
great! thanks!
Old 11-23-2010, 07:15 AM   #1422
Trader Rating: 77 (100%+)
Default Just sharing in the excitement
So I took my brand new TCX out to the local track this Sunday for the maiden run. Holy cow this car is rediculous. And wouldn't you know just my luck all the HB guys just happened to be there running. Those guys are amazing and so helpful. I am so glad I purchased the TCX just for that reason.
I have owned (still do) HB off road cars and those guys as well have been helpful.
To have the opportunity to have Hiro and Jared from HB give you support right there at the track is invaluable. They were so helpful even to a newb on road guy like myself. After one day I am addicted to on road. The adrenaline rush of even hitting your line on a couple of turns (I said I was a newb) is amazing.
Well just thought I would share. Can't wait for next weekend.
Cheers and everyone should own a TCX
goin2drt is offline   Reply With Quote
Old 11-23-2010, 07:55 AM   #1423
Originally Posted by mr lee View Post
Are there any setups around for foam asphalt?
No one run foams on asphalt?
mr lee is offline   Reply With Quote
Old 11-23-2010, 10:42 AM   #1424
AGNO's Avatar
Ok thanks, I'll get 500.000 ...
Old 11-24-2010, 08:33 AM   #1425
Trader Rating: 45 (100%+)
Anyone have an extra set of the machined 1.1mm 3 hole pistons they want to part with (part#hpi 73524)? PM me if you do. Thanks!
Or does anyone know if the Tamiya 3 hole pistons will work in the TCX shock?
Apex is offline   Reply With Quote
