Old 11-21-2010, 05:17 PM   #1396
Bubblehead's Avatar
AGNO,
After looking at Hara's set-up I would also change sway-bars front 1.6mm rear 1.2mm, front pivot blocks spacer to 1.5mm, front stock tower hole #5.
Bubblehead is offline   Reply With Quote
Old 11-22-2010, 12:08 AM   #1397
AGNO's Avatar
Originally Posted by Bubblehead View Post
I would try more droop in the rear (lower arms) and less droop in the front (higher arms).
Smaller spacer under the rear ball studs (more grip).
Make one change at a time 1st rear droop 2nd front droop 3rd ball stud.
AGNO,
I had a lot of droop front and rear, the next time I'll try to decrease the front.
I tried front sway-bar 1.4 mm and 1.2 mm rear (1.6 mm is not available for TCX).
However, the IIC Hara setup during practice was pretty good, things became much worse with the increasing grip.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 11-22-2010, 12:59 AM   #1398
Are there any setups around for foam asphalt?
mr lee is offline   Reply With Quote
Old 11-22-2010, 05:23 AM   #1399
Bubblehead's Avatar
You'll right 1.6mm is not available I was thinking (black TC 1.6mm). But your problem is as track grip increased your cars grip decreased? You described your car as too nervous and little rear grip.
Old 11-22-2010, 06:00 AM   #1400
AGNO's Avatar
Yes, this is the problem, when it increased the grip is greatly increased steering and increased front grip was too lighten the rear, creating loss of adhesion.
Perhaps with a less aggressive guide and with a greater ability to control the car can esssere very fast, but I'm not able ...
Old 11-22-2010, 06:06 AM   #1401
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
had a similar problem running on asphalt. when the traction came up i could barely drive the car around a corner. seemed the front was grabbing too hard so the rear would swing around easily. to help, we widened the rear track width (6mm hexes), removed the rear swaybar, removed the shim on the top camber link, and went from pink to gold springs in front (kept the silver springs at the rear). also tried running heavier oil (currently running 65wt in front and 55wt in the rear). easier to drive now but it's still a hand full for me. hths
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 11-22-2010, 06:13 AM   #1402
san.'s Avatar
Trader Rating: 59 (100%+)
AGNO,
TCX sway bars are rated differently. There's no 1.6mm.
Gold = 1.2mm
Silver = 1.3mm
Black = 1.4mm
Awesomatix USA||Roche RC USA||Sanwa
san. is offline   Reply With Quote
Old 11-22-2010, 07:11 AM   #1403
mangoman's Avatar
BTW Big congratulations to Ryan Maker who dominated the field at the Australian Titles over the weekend
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 11-22-2010, 08:51 AM   #1404
sosidge's Avatar
Sorry to butt in on the TCX thread, but...
This is more or less the exact same problem I've seen myself with a few years of running the TOP Scythe (which uses the HB suspension) under my belt, and what I've seen trackside from a lot of people driving Cyclones and Pro4's over the years.
The suspension geometry on these cars generates a LOT of steering. Fast when it's under control, but when you are pushing the limit, the back end becomes very loose.
A couple of things that helped (a little) for me on the Scythe was a higher front roll centre (0.5-1mm extra under the blocks), heavier front damping, and less arm sweep. But the tendency to oversteer was always there. A long rear upper link has always been on my "to do" list as well (although I suspect the outer hole on the rear hub is a bit too long...).
Old 11-22-2010, 09:27 AM   #1405
Trader Rating: 17 (100%+)
help!
I need a setup for carpet and Sorex 36 tires, I tried the setup Hara IIC but with poor results, is too nervous with oversteer and little rear grip, is not suited to my driving.
I state that I attend a few races on carpet and my guide is not the best on this surface, so I need a setup that makes the model easy enough to drive.
Anyone have experience with these tires on carpet?
Any suggestion is appreciated.
Thanks.
Have you tried lower the rear inner link by 1mm, use 1.2 rear sway bar, and take two screws out of top deck at rear of chassis. This helped my car out quite a bit last weekend.
Art
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 11-22-2010, 09:29 AM   #1406
Trader Rating: 45 (100%+)
What about trying some ant-dive up front to keep the front end from grabbing too much? I know the Tamiya guys do this to smooth the car out. Also, maybe try applying traction compound to rear tires longer than the front.
Apex is offline   Reply With Quote
Old 11-22-2010, 09:48 AM   #1407
Bubblehead's Avatar
You can also put a Diff in the front, I find that a spool pulls hard.
Old 11-22-2010, 11:03 AM   #1408
Or simply, wide the front pivot blocks, you can use 1 or 2 in F/R.
Greetings, Luis C.
## NOSRAM ## YOKOMO BD5W ## BMI DB12RR+ ##
luic is offline   Reply With Quote
Old 11-22-2010, 11:36 AM   #1409
I would move the front suspension arms forward by 1mm. So there should be 1.0mm shim in front of a-arms and 1.75mm in back. You can also rise up the suspension block to 1.25mm/1.5mm from the AH setup (1.0mm).
Hope it helps.
Thanks,
Hi-LowBlow is offline   Reply With Quote
Old 11-22-2010, 01:18 PM   #1410
AGNO's Avatar
Wow! Thanks, many tips and all valid, in December will attend the next race on carpet, I will keep you informed.
