Old 11-13-2010, 07:34 PM   #1321
Trader Rating: 77 (100%+)
Default FDR help
FDR help. Running the following
Tekin RS ESC with the Hara set-up sheet on Tekin website (17.5 IIC) and boost turned down to 10
Tekin 17.5
Tight indoor track, high grip, 50' straight.
His car is at 6.4.
goin2drt is offline   Reply With Quote
Old 11-13-2010, 10:42 PM   #1322
olhipster1's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to olhipster1
Default Hara Vegas Setup
I've looked for Hara's Vegas setup but can't seem to find it.
can someone please give me the link
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 11-13-2010, 11:01 PM   #1323
EJ20's Avatar
Originally Posted by Hi-LowBlow View Post
Hello everybody,
Here are the setup sheets from the IIC 2010!
Page 50 #741
- HOTBODIES - AHRP -
EJ20 is offline   Reply With Quote
Old 11-14-2010, 01:29 AM   #1324
Hello, i need some advice about setup, i have more setups for my old cyclone car for asphalt, but i think the TCX car need some differencess in setup, i think to start with Hara low grip setup, this is for carpet, i run in low grip asphalt, i think it will work.
Any recomendations would be appreciated.
Thanks FranH, for your responses.
Thanks, Luis C.
## NOSRAM ## YOKOMO BD5W ## BMI DB12RR+ ##
luic is offline   Reply With Quote
Old 11-14-2010, 03:25 AM   #1325
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Originally Posted by ark View Post
Hi guys I thought Id share my gear diff conversion with everybody. Its a Spec R Xray 38tooth diff giving a 1.9 final drive and no need to change any belts. The diff needs about 1 mm of shimming. Xray 50mm driveshafts and blades. The driveshafts are a perfect fit into the axles. Front pulley is a xray ball diff pulley which has had the centre hole enlarged a little with a body reamer and elongate two holes for the screws.
Nice work Dman
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 11-14-2010, 04:20 AM   #1326
Barry_Hughes's Avatar
Thanks, Luis C.
I run virtually the same settings as I did for my TC, 30w oil allround and less droop, otherwise it is the same.
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 11-15-2010, 01:04 AM   #1327
mdowney's Avatar
Trader Rating: 21 (100%+)
Hot Bodies TCX
Mike Downey
I try all of the RC kits and usually race at Tacoma RC Raceway
mdowney is offline   Reply With Quote
Old 11-15-2010, 09:32 AM   #1328
olhipster1's Avatar
Default thanks
Thanks for the info everyone much appreciated.
Ran my TCX this past weekend, the car is very good.
very stable throughout the track.
very easy to fix driving errors, cars reacts very quick to steering input.
Build quality is fantastic.
had a little problem with traction rolling so have to work that out but it was only on certain parts of the track.
Not sure if this has been answered but are there any Front Steel dog bones for the front, it's the only thing on the car I find myself checking over and over again.
For anyone running 17.5 Stock Non boosted, I found a gear combo of 100 spur with 52 pinion worked great,
had to take the motor mount brace off to keep the pinion from hitting
using a spur from 100 to 104 is probably the best option.
CAUSE and EFFECT
Old 11-15-2010, 11:34 AM   #1329
Trader Rating: 45 (100%+)
Any build tips for the TCX? Also, is the box stock setup any good for low grip asphalt?
Apex is offline   Reply With Quote
Old 11-15-2010, 01:26 PM   #1330
Trader Rating: 17 (100%+)
Can anyone tell me what servo saver is in this picture?
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 11-15-2010, 02:29 PM   #1331
Suspended
Trader Rating: 86 (100%+)
it looks like an hot bodies servo saver
littlealex is offline   Reply With Quote
Old 11-15-2010, 02:56 PM   #1332
Exclamation
im back
DEIGIMA is offline   Reply With Quote
Old 11-15-2010, 03:05 PM   #1333
Default pinion and spur
i will be buying a lrp eraser 13.5t (brushless) motor soon and has made me realise what a big power difference it will be... im wondering what pinion and spur i should start from as i "gear it up"?
xtra info
the victim is a hpi rs4 rally
i use reedy wolfpacks - 7.2v, nimh, 3600mah.
and i wanna tune for bashing(all round run and relyability)
so could one of u give me a pointer on what pinion/spur gears?
thanks jim
Old 11-15-2010, 03:26 PM   #1334
AGNO's Avatar
Tamiya with 3Racing aluminum parts, I also use.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 11-15-2010, 03:28 PM   #1335
san.'s Avatar
Trader Rating: 59 (100%+)
That's actually the Tamiya High Torque Servo Saver with a purple horn from 3Racing.
I have the same one.
Awesomatix USA||Roche RC USA||Sanwa
san. is offline   Reply With Quote
