Old 11-10-2010, 02:15 PM   #1306
Korey Harbke's Avatar
Yes!
Pro Spec America/Apex RC - Team ORCA - Awesomatix USA - Roche RC USA - AVID - Sweep - Protoform - Pro-One RC - Slapmaster Tools - Hebiki Design Works - Turtlemaster Racing - Seattle RC Racers - Timezone Hobbies
Korey Harbke is online now   Reply With Quote
Old 11-10-2010, 02:17 PM   #1307
Trader Rating: 45 (100%+)
Originally Posted by Korey Harbke View Post
Yes!
Yes to my question or gwhiz's question?
Apex is offline   Reply With Quote
Old 11-10-2010, 02:18 PM   #1308
By yes I meant the black suspension blocks fit. The heavy duty motor mount is just made out of a better aluminum. It's not needed, but if you somehow bend a motor mount, you might as well replace it with the stronger one!
-Korey
Old 11-10-2010, 02:33 PM   #1309
What are people generally running then FDR wise for 10.5T. I have bought a SP V3 10.5T and an Xtreme Hobbywing ESC. Was told to start around 8.5FDR. I know it makes a huge difference if your are running different settings on the speedo, but was just looking a steer.
Cheers
Stephen_102 is offline   Reply With Quote
Old 11-10-2010, 02:41 PM   #1310
Yea... I need to know the settings in the ESC before I can even begin to tell you where to start. I've seen anywhere between 6.5 and 8.5 for gearing a 10.5, but that range is so wide it's not even helpful.
-Korey
Old 11-10-2010, 04:29 PM   #1311
stitchy's Avatar
More TCX suspension parts have come in
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 11-11-2010, 02:27 AM   #1312
windstar's Avatar
Originally Posted by FrankH View Post
On my Home Track with the TCX out of the Box (almost) from the beginning I managed to run 2/10th faster with the TCX then ever with the BD5. Maybe its the "New Toy" Factor, and like stated before I am not known to drive very smooth
Hi Frank,
(it's me, Ivo) what oil do you use in the shocks of the TCX carpet? I have mine back home :-)
What else did you to the TCX for carpet?
cheers
windstar
Team Durango DETC410, Team Associated RC5.2 x 2, Tam Associated RC10 B6, T.O.P Racing Rebel 12 (2013), Sanwa M12
windstar is offline   Reply With Quote
Old 11-11-2010, 02:21 PM   #1313
jackdani's Avatar
hi guys,
this topic looks very interesting to me.
i own a mi4lp pro version which means no carbon fiber chassis, no adjustable shocks, not so much fancy alu, but well worth 240 euros to start!
had a couple of mouths practicing and gettin better and better and next week i'll do my first race.
for the new year i woul like to change my car, choises are:
tcx, tc6, t3 '11
however tcx was always my favourite, and now, that i m really considering to buy one i would like to know from u if i should.
all i know is:
car is pretty solid, handle seems to be very good and very driver-friendly (as moore and hara always repeat)
nice build and very interesting chassis flex adjustability,
furthermore spares are not so expensive compared whith others even here in italy.
what i ignore is all the rest...
its worth the money? how really feels to driver?
there is something in particular that is very good or bad?
everything that u can tell me i will really apporciate!!
thanks a lot!!
jackdani is offline   Reply With Quote
Old 11-11-2010, 11:50 PM   #1314
Originally Posted by windstar View Post
Hi Frank,
cheers
Hi Ivo
For the shocks we use 3 hole with 40Wt Oil.
Springs - Yokomo Pink/Blue or HB Pink/Blue
The biggest Modification is the Lipo Chassis by Marcel. How does it compare to the Standard ? Well, it is narrower and designed and balanced to hold the LRP 5900 Lipos. Lots of Flex too.
We are running the Yokomo Steering Blocks, but I believe thats not a big change to standard. More a Mind thing ;-)
The Steering we mount at the lowest position (shims on Top).
I tried the Standard Front Blocks as well as the FF1,5/FR1,5 , for me it really didn't make a difference in Beerfelden.
On Low Grip Front Rollcenter 1,0/1,0, when Grip goes up 1,5/1,5.
Hope to see you on the Race Track
FrankH is offline   Reply With Quote
Old 11-12-2010, 02:26 AM   #1315
FrankH, Do you test this new chassis in outdoor? , in low grip asphalt.
And is possible to buy this chassis, some shop, or direct to Marcel ?
JackDani , i donīt have the car yet, iīm waiting for my order to arrive, but i race 3 years with a old Cyclone Surikan Edition, and then i run for Schumacher, this year with Mi4LP.
My old cyclone, are a very solid car, very fast in turns and a litle more difficult to drive then the Mi4, the Mi4 are more stable car, but not than fast in turns.
For me, the best are the ressistance of materials, turnnukles, belts, pulleys,...
The 2.5 mm chassis of cyclone, was not very flexible even with holes for NiMh batteries, the cardans were not very hard and in some tracks the steering blocks broken in a strong impact, the first diferentials broke the screws, but this was solved with the Pro version.
I think all of this is solved in TCX, for this reasson i choose this car for the next year, is one of the best
Sorry for my english, Luis C.
## NOSRAM ## YOKOMO BD5W ## BMI DB12RR+ ##
luic is offline   Reply With Quote
Old 11-12-2010, 03:02 AM   #1316
@Luic
I just got my TCX and the chassis about two weeks ago, so I had no chance to test it outdoor yet. I believe Marcel did, but not sure at this point. Got mine straight from Marcel, not available in shops (yet).
I had a similar Lipo chassis in my TC with a long Top Deck with lots of Flex
The TCX Cardans are still kind of week, at least for Modified. Broke one in a crash and the other side is worn out already.
By the way, I manged to get the Black Tamiya Delrin Spool Outdrives onto my TCX Spool. The whole was just a little to small but with some minor rasping it fit on. Now I am able to run Yokomo BD5 45,5mm Cardans in Front and in the Back I am running the Yokomo BD5 44mm Cardans. They fit perfect in the SpecR Gear Diff and the Tamiya Outdrives.
Old 11-12-2010, 03:42 PM   #1317
ark
Hi guys I thought Id share my gear diff conversion with everybody. Its a Spec R Xray 38tooth diff giving a 1.9 final drive and no need to change any belts. The diff needs about 1 mm of shimming. Xray 50mm driveshafts and blades. The driveshafts are a perfect fit into the axles. Front pulley is a xray ball diff pulley which has had the centre hole enlarged a little with a body reamer and elongate two holes for the screws.
Hot Bodies TCX-2010-11-12-19.21.00.jpg   Hot Bodies TCX-2010-11-12-19.21.43.jpg   Hot Bodies TCX-2010-11-12-19.22.37.jpg
ark is offline   Reply With Quote
Old 11-13-2010, 10:08 AM   #1318
Anybody hear the latest about when there will be one for specifically for the TCX? been talked about for a while now.
Old 11-13-2010, 10:37 AM   #1319
steveonamission's Avatar
December. TBC
www.fuller-paint.blogspot.com
steveonamission is offline   Reply With Quote
Old 11-13-2010, 05:09 PM   #1320
Hello,
anybody has a setup for a medium size medium bite carpet track?
This for a 10,5 motor.
stofke is offline   Reply With Quote
SEO by vBSEO 3.5.0
