Old 11-09-2010, 12:16 PM   #1291
stitchy's Avatar
Originally Posted by Dog Bone View Post
Scratch that - why don't you offer more reasonable USPS shipping to Canada? I didn't realize EMS was a USPS service...
Other hobby shops can ship small packages for less than $10 - if you could as well, I'm sure you'd increase your sales north of the Border...
I'll look into it.
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 11-09-2010, 12:17 PM   #1292
bukil's Avatar
Trader Rating: 37 (100%+)
For TCX parts, brooker tracker r/c has a LOT of them.
Website:
www.brookertrackerrc.com
Phone:
805.498.2222
☆ ActivRC ☆
bukil is offline   Reply With Quote
Old 11-09-2010, 12:57 PM   #1293
steveonamission's Avatar
Originally Posted by hana166 View Post
Thanks FrankH for your answer I've been hearing TCX is a stable car
Depends if you have stable thumbs to match
steveonamission is offline   Reply With Quote
Old 11-09-2010, 02:48 PM   #1294
Originally Posted by Tabushi View Post
Guys,
In January i will start racing the TCX on a 5.5 Brushless class.
Can you help me out on gearing ?, track is medium size, equipment i will be using is Tekin RS PRO ESC and Tekin motor.
This is a small video of C-Main final of a race last week of Nitro 1/10th Class over rubber tires, this same track i will be racing with the TCX. Main straight its 60 meters long = 190 feet :
thanks a lot guys,
Hello Tabushi, here in a similar track, for 5.5 we use 7.3 - 7.5, depend of ESC, i run 4.5 Octawind, is more adecuate, but i see you run 5.5 class.
Greetings, Luis C.
## NOSRAM ## YOKOMO BD5W ## BMI DB12RR+ ##
luic is offline   Reply With Quote
Old 11-10-2010, 02:22 AM   #1295
Originally Posted by SchuMi2 View Post
Hey FrankH,
Which chassis are you running on the TCX?
Cheers
Well,
its a Chassis designed by Marcel G. here in Germany. It is known as "ACE" or as "G-Tech".
FrankH is offline   Reply With Quote
Old 11-10-2010, 02:45 AM   #1296
I have seen Hot Bodies has a "HD Front Universal Drive Shaft 44mm Cyclone". Can this be used up front even though it is not 46mm?
Sorry if this has already been mentioned.....haven't had the time to go back and read
mr lee is offline   Reply With Quote
Old 11-10-2010, 10:23 AM   #1297
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
nope
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 11-10-2010, 10:33 AM   #1298
Does anyone know when the gear diff for this is due out.Nice car to drive.easily faster than my surican.
colin storey is offline   Reply With Quote
Old 11-10-2010, 12:26 PM   #1299
Barry_Hughes's Avatar
Originally Posted by luic View Post
Thanks fo yours comments FrankH, im waiting for my new car (TCX).
For replace the metal spools outdrives, are the Ref. 67731 are POM outdrives for spool, i use it in may old Cyclone, with good results.
The pivots blocks, are the same from cyclone?, and the Shock towers and sway bars same from TC ? , i see the pulleys are the same from TC, rear diff, etc...and anothers parts, i have some spares from my old car.
Greetings, Luis C.
Shock towers are different due to the narrower mounts, think the diff is different for the same reason
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 11-10-2010, 12:34 PM   #1300
Hi guys.
I was wondering what was the lowest FDR possible on the TCX. I have tried to fit/mesh a 26t pinion with a 115 spur (64DP) but due to the upper deck it wont seem to fit. I noticed Hara quotes this on one of his set up sheets. What am I doing wrong?
Thanks in advance for any help
Stephen_102 is offline   Reply With Quote
Old 11-10-2010, 12:44 PM   #1301
sorry, forget that! Motor was positioned in such a way that it was touching the upper deck and stopping a more snug fit! Just turned it slightly and bobs your uncle, oops!
Old 11-10-2010, 12:49 PM   #1302
evostyle's Avatar
Trader Rating: 102 (98%+)
Originally Posted by Stephen_102 View Post
Hi guys.
I'm able to get a 104 / 45 (4.51 FDR) with no problem. That would easily be a lower FDR than your 115 / 26 (8.63 FDR)
I believe your problem is with the motor hitting the upper deck from running a small pinion. If you need your current FDR you may try a larger pinion AND spur to shift the motor forward. A 120 / 27 (8.67 FDR) would move the motor forward because of the larger diameter spur AND move it forward because of the larger diameter pinion. However your FDR will remain as close as possible to your current FDR.
evostyle is offline   Reply With Quote
Old 11-10-2010, 01:05 PM   #1303
RCBuddha's Avatar
Trader Rating: 33 (100%+)
I'm running a 3.0 with a 55 pinion and 86 tooth spur. You can go lower, but you really have to play with the gearing to make it work. Thankfully speedtech has plenty of spurs and pinions available.
RCBuddha is offline   Reply With Quote
Old 11-10-2010, 01:14 PM   #1304
gwhiz's Avatar
Sorry if this is off-topic, and may have been answered before. But will these fit a TCX?
http://www.hotbodiesonline.com/piw.p...=61395&lang=en
Attachment 665439
x
gwhiz is offline   Reply With Quote
Old 11-10-2010, 01:14 PM   #1305
Trader Rating: 45 (100%+)
Hot Bodies Heavy Duty Motor Mount Set
[HBS68752]
Saw there is an option motor mount for the TCX. Is it needed or will the stock motor mount do?
Apex is offline   Reply With Quote
