Old 11-02-2010, 03:10 PM   #1246
Trader Rating: 77 (100%+)
Originally Posted by Apex View Post
Planning on picking up a TCX soon. What parts usually break the most\need to be replaced the most? Also, for mod will the plastic diff outdrives do or should I go ahead and get the aluminum diff halves?
And what is the popular servo all are running?
goin2drt is offline   Reply With Quote
Old 11-02-2010, 05:29 PM   #1247
AGNO's Avatar
Default PRO-D shaft
I discovered that you can use the drive shafts HPI PRO-D(HPI 88914) in the front, they are steel and therefore much more resistant.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 11-02-2010, 05:39 PM   #1248
Korey Harbke's Avatar
I was under the impression those were 44mm driveshafts? I could be wrong. I switched to the Pro 4 CVDs with great success so far.
-Korey
Pro Spec America/Apex RC - Team ORCA - Awesomatix USA - Roche RC USA - AVID - Sweep - Protoform - Pro-One RC - Slapmaster Tools - Hebiki Design Works - Turtlemaster Racing - Seattle RC Racers - Timezone Hobbies
Korey Harbke is offline   Reply With Quote
Old 11-02-2010, 06:18 PM   #1249
AGNO's Avatar
-Korey
PRO-D shafts is 46mm , I also use the PRO4 driveshafts, but PRO-D shafts is a great alternative.
Old 11-02-2010, 10:50 PM   #1250
rendcool's Avatar
Is this car durable enough ??
which is more durable, tcx or t3'11 ?
rendcool is offline   Reply With Quote
Old 11-02-2010, 11:14 PM   #1251
unknownmember's Avatar
The car is durable but that really depends on the driver. My cousin went through countless swing shaft on a monthly basis whilst I haven't yet, well I only got myself a TCX lately but it shows. Because we both had TT-01 in the past and the same thing happened.
unknownmember is offline   Reply With Quote
Old 11-02-2010, 11:26 PM   #1252
Originally Posted by VooDooPH View Post
rccartips, i'm thinking you have the same rubbing issue too? i guess its ok since i,ve ran the car a few times already. it was only a few nights ago that i noticed the rims rubbing the lower arms.
anyway, tried diffferent rims... all with the same rubbing issues...
Tamiya (white with no tire)
Yokomo (TW-0312-2)
TOP
Are the steering knuckles side-specific? If so, maybe you've got them on the wrong side?
-Mike
Old 11-03-2010, 01:05 AM   #1253
Originally Posted by Luke Hobson View Post
hi,
yes they pretty much all have a little slop in the steering, ive shimmed a little bit of it out, but you dont want to get rid of all of it, otherwise it will cause a slight bind.
the only part of the steering ive shimmed is on the post itself, added about 0.3mm on each side. this takes about 90% of the float away.
hope that helps
Luke
AAhhhhh I see. That clears it up a bit, thanks man.
Old 11-03-2010, 01:51 AM   #1254
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
-Mike
nope they're not. tried switching them over and even tried the stock composite hubs... same problem...
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 11-03-2010, 03:33 AM   #1255
AGNO's Avatar
Yokomo (TW-0312-2)
TOP
The old rims TOP give problems also with the Photon ... same Take off rims, rims SOREX, LRP V-TEC and Sweep no problem
Old 11-03-2010, 12:27 PM   #1256
Suspended
Trader Rating: 86 (100%+)
-Korey
where can you buy pro 4 cvd? i looked but not many online stores carry it
littlealex is offline   Reply With Quote
Old 11-03-2010, 04:31 PM   #1257
Pit-racer's Avatar
Is this the car to get? Looking for a new electric ride.
www.igthobbies.com / Serpent Cobra GT / 748 TQ / Serpent Eryx 3.0 / Desoto Racing / Veytrex.com / JZRacing / Flo-Control
Pit-racer is offline   Reply With Quote
Old 11-03-2010, 05:41 PM   #1258
What is a good starting out gearing? I assume run the stock 115 with what pinion?
Old 11-03-2010, 06:00 PM   #1259
Hebiki's Avatar
Trader Rating: 26 (100%+)
do it! you won't regret it.
Hebiki is offline   Reply With Quote
Old 11-03-2010, 06:06 PM   #1260
rendcool's Avatar
which is more durable one ,, tcx or xray ?
I am planning to get a new car too, but still hesitate about those two ..
SEO by vBSEO 3.5.0
