Old 10-13-2010, 01:20 AM   #1096
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
Thank You!
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 10-13-2010, 08:49 AM   #1097
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
Originally Posted by David Galdo View Post
VooDoo, that looks very much like what was mention on page 54 or 55...
Nice work!
yup and thanks! just thought i'd try it out using shims instead of fabricating a one-piece spacer... although i think the one-piece spacer you made would be less prone to warping the spur...
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 10-13-2010, 09:01 AM   #1098
Well, I prefer the extra purple to the black I have.
V-Dezign 4.0
Old 10-13-2010, 09:14 AM   #1099
Airwave's Avatar
The MVP Pro4 are a perfect fit, but whar are they made for? Alloy or Steel?
Airwave is offline   Reply With Quote
Old 10-13-2010, 09:29 AM   #1100
am
Agno, is it Radiosistemi that have Hb distribution in Italy?
am is offline   Reply With Quote
Old 10-13-2010, 10:32 AM   #1101
AGNO's Avatar
No, Radiosistemi only provider HPI, HB is distributed by Sprint RC, but perhaps it will become distributor DM Model for sector Electric car.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 10-13-2010, 12:58 PM   #1102
am
Thanks Agno. I am importer of Crono cars to Norway..
How is Crono RS9 in Italy now? Is it only Lenzi of the good drivers running it? Looks like the stalled a bit when Davide left and the RS7 was not so good, sadly..
Old 10-13-2010, 01:00 PM   #1103
Barry_Hughes's Avatar
Originally Posted by Luke Hobson View Post
What grease or or anti wear grease are you using Barry?
I don't use any - should I?
It doesn't say put any grease on it - would you just put it in the slot of the alu dog bone and what grease would be best?
The original bone that is still in the car the slot probably double the width of when it was new and really needs replacing.
Never had this problem with my TC with the steel bones
Built it !
Raced it !
Wrecked it !
Barry_Hughes is online now   Reply With Quote
Old 10-13-2010, 02:40 PM   #1104
Luke Hobson's Avatar
Send a message via MSN to Luke Hobson
Hi Barry,
yeah, I always build them with plenty of grease, on the joint end I use either AE black grease, or some Mugen stuff I have from years ago, and again yes, i put grease on every face that has metal to metal contact.
For the bone end into both the front and rear, I use tamiya anti wear grease,
That's the only reason I can imagine for there being a difference in the wear between our shafts
Luke
Luke Hobson
Awesomatix - Xenon - Godzilla Paint - Moorespeed - ToniSport - MBmodels
http://luke-hobson.blogspot.com/
Luke Hobson is offline   Reply With Quote
Old 10-13-2010, 06:15 PM   #1105
What is BOOST??
Is this a Cheat with a particular speed controller???
Hermit 713 is offline   Reply With Quote
Old 10-14-2010, 08:58 AM   #1106
Mike Haynes's Avatar
Originally Posted by RaceAce701 View Post
is anyone running the TCX attending the Halloween Classic at the Gate
I will be running one in the open class.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 10-14-2010, 09:33 AM   #1107
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
you switching rides?!?!
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 10-14-2010, 12:03 PM   #1108
Default Ball cup of TCX
Anyone found that the ball cup from TCX have gap with the ball head? Any recommendation of i want to replace the original TCX to other brand?
powis is offline   Reply With Quote
Old 10-14-2010, 01:18 PM   #1109
I have just broken a front drive shaft and currently there are no spares in the UK. I've heard that the TOP Photon one's will fit.
Can anyone confirm this?
markrobinson is offline   Reply With Quote
Old 10-14-2010, 01:29 PM   #1110
RCBuddha's Avatar
Trader Rating: 33 (100%+)
I have run into the same issue...I found the standard cups *seem* to be a little tighter in that respect.
RCBuddha is offline   Reply With Quote
SEO by vBSEO 3.5.0
